millipede
LA, USA Status: offline
The FS-CT-6A is a programmable 6 channel radio not unlike the Spektrum DX_6. However, you have to have the cable and software to do this as it does not have a display. The small cable attached to your antennea it the binding cable for the unit. To bind the rx to the transmitter, or another rx if you have two of thier rxs on different planes: 1. remover all servos and batterys from the rx 2. Put jumper plug in battery spot. 3. Plug batter (or ESC with battery attached to it) into any other rx spot. (LEDs will be blinking now) 4. Press and hold "Bind" button on TX then power on (Kepp holding "Bind" button) 5. When LEDs go steady on, rx is bound to TX. Still trying to obtain the cable for connecting to PC but I did mangae to get a manuial and the software. Good luck ps mail me if you want the manual. quote:
ORIGINAL: jcervantes11 Ok look, ka planes are now offering, not only the nitro powered heli but also the helicopter with same radio. He is now offering these 2.4 radio system 6 ch radio. It say it is from Fly sky model FS-CT6A. When move the right stick side to side up and down, that actually effect my tail which goes a bit crazy!! At right stick which is tail and trouttle well when i do right and left it moves but twitches. On chanel 4 which is the main connector from gyro that is connected to, well I placed a servo and it doesn't get crazy. Only when I have the gyro connected. Connector is connected right because I checked also I went and fallowed how my gyro in black hawk 450 was connected. It was fine so I switch gyros. My gp still have the problem. My black 450 with gyro from nitro, well that works. So gyro works. But when i tried gyro from 450 to my nitro it got rid of some twitching. Ok on my nobs right one is label as vr(A) and switch next to it says SW.A and left one switch is SW.B and nob is VR (b). Also I don't understand I found mail connector each end with a sleve ( to hook up the other male side) which is not even connected with the antana of my transmitter. Well kindof it is. Ah I don't know how to explain it. I just don't know **** is that for. I might setup my cam and record, but dunno yet. Anybody know whats up? What I should do and whats these nubs for? Also it didn't came with NOOOOOOOOOO instruction also I found this link http://www.globalrchobby.com.au/product_info.php?cPath=39&products_id=347&osCsid=930fa1013d186f6bab6043a6603d612a which is selling this radio system and hell, it comes with usb cables to use ur own computer to program this radio. But I cant find any information. Right now I am working on my blackhawk 450 to go flying tomarrow. I need to redo and tie up everything up. Darn. So any ideas guys?
