RE: The Better HeliPro Black Hawk
Tower Hobbies
Logged in as Guest
  Printable Version
E-Flite Blade CP Pro - RTF
Seller:  TheRealSuperDave
Details:   $350.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> RE: The Better HeliPro Black Hawk
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: The Better HeliPro Black Hawk - 10/29/2007 5:30:58 PM
Old Rotorhead
Status: offline
Helihap -
The FS8 for use on eCCPM requires replacing the rec. in the Blackhawk for the one that comes with the FS8. You order a crystal to match the freq. your tx is on. Seems to be a good rec., but is 3 times the size. Also has a small control panel that has to be mounted somewhere. Lotta stuff to hang on a 450 size heli. As I said before, I still don't have it working right.
(in reply to Helihap)
       Post #: 126
RE: The Better HeliPro Black Hawk - 10/29/2007 9:32:13 PM
PaulLee
Status: offline
complicated but I have heard that a lot of people like them.
(in reply to Old Rotorhead)
       Post #: 127
RE: The Better HeliPro Black Hawk - 11/1/2007 1:48:15 AM
SteveCink
Status: offline
thought about it but didn't indulge. I am doing good with this helicopter and can't risk another thing to think about, at least not right now.
(in reply to PaulLee)
       Post #: 128
RE: The Better HeliPro Black Hawk - 11/3/2007 7:19:54 PM
PaulLee
Status: offline
agreed - once one become comfortable then using for big steps in progression make good idea too.
(in reply to SteveCink)
       Post #: 129
RE: The Better HeliPro Black Hawk - 11/4/2007 1:55:08 AM
TomOver
Status: offline
sort of a bummer that winter is approaching but there is always warm clothes. How do the motors and electronics perform when its real cold outside???
       Post #: 130
RE: The Better HeliPro Black Hawk - 11/4/2007 11:38:27 PM
Helihap
Status: offline
Seems like they would be ok considering other electronics that maintain their utility and prob runs cooler. There may be some RF drift but not sure on that either.
(in reply to TomOver)
       Post #: 131
RE: The Better HeliPro Black Hawk - 11/5/2007 11:53:39 AM
MiniCwik
Status: offline
Yes, winter is definitely knocking on the door here in MI ... I finally got the Spectrum lipo battery monitor installed and got some flights in this weekend, yesterday evening was great with little to no winds but temps were in the low 50's to upper 40's with the sun going down, now an hour earlier (time change bs).
I hope I will be able to fly outdoors until it gets into the 30's because I don't know that I will be able to wait until Spring to fly
But man the heli flew great yesterday, it's really a sweet bird! I received my Pro-Line Assault canopy and hope to get it painted and mounted soon. It's definitely not as bulky as the stock one, not sure if that's a good or bad thing yet.
_____________________________
Nitro Trk - Himoto Eldorada 1:10 4WD (w/bling)
EP Helis - T-Rex 500 CF (401/9257) & 450 SE V2 (Scorpion -8V2/401/9257)
       Post #: 132
RE: The Better HeliPro Black Hawk - 11/6/2007 12:03:08 AM
ea01bg
Status: offline
Looking forward to a pic
(in reply to MiniCwik)
       Post #: 133
RE: The Better HeliPro Black Hawk - 11/6/2007 12:06:23 AM
srouthouse
Status: offline
i just got the BH450se from mike showed up in 2 days and a follow up email. great service and his parts are cheap.
i have a question regarding the charging. my rtf came with a charger and balancer am i correct thinking you use both at once???
(in reply to ea01bg)
       Post #: 134
RE: The Better HeliPro Black Hawk - 11/6/2007 12:16:56 AM
gino198
Status: offline
no he believes the one with the light is faster but it is not a balancer so he throws that one in. I alternate between the quicler charge and the balancer. Sometimes I just use the balancer/charger. They both charge the batteries.
(in reply to srouthouse)
       Post #: 135
RE: The Better HeliPro Black Hawk - 11/6/2007 12:19:30 AM
srouthouse
Status: offline
what kind of charge times are you looking at?
(in reply to gino198)
       Post #: 136
RE: The Better HeliPro Black Hawk - 11/6/2007 12:58:49 AM
srouthouse
Status: offline
another quick question. the blades hit the ground and power was cut. i lost a half inch to a inch of the woode blades on both sides it pushed the motor back in its mounts instead of stripping the main gear. i have new blades and the motor is remounted properly and now when i turn the heli on the servos will move but now i get no power to the blades at all. is this normal for such a small oops??? and what is the remedy?
       Post #: 137
RE: The Better HeliPro Black Hawk - 11/6/2007 1:54:26 AM
gino198
Status: offline
actually 1/2 of wood could be a tough blade strike, good news on the gear not stripping though - some ideas and things to check
does the motor turn when you fire it up?
is the pinion still tight on the shaft and properly seated with the gear teeth?
are the plugs from the motor to the ESC still tight?
if you manually turn the motor does the gear turn?
did you strip the one way bearing inside the main gear?
       Post #: 138
RE: The Better HeliPro Black Hawk - 11/6/2007 2:21:56 AM
srouthouse
Status: offline
i just went out with a fully charged battery and it fired up and ran perfect
it was running fine before the crash and i charged the battery for 30 minutes with the balancer so go figure.
oh well all is good now. the heli held up good for a small crash.
on a side note now im using the trex 315mm plastic blades and i think they will hold up a little better then the cheap woodies
       Post #: 139
RE: The Better HeliPro Black Hawk - 11/6/2007 11:59:23 AM
MiniCwik
Status: offline
I too had a blade strike last night, what's with that?
Anyway, I was playing around with piro'ing a little and I think the radio glitched on me and then being that I was in my basement I didn't have much room for error and the blades struck a PVC downpipe and shattered both of them. I was powering it down and nothing else appears to have been affected, so I will pickup new blades today and learned a lesson ... if flying in a basement or other confined space, don't try and do too much
       Post #: 140
RE: The Better HeliPro Black Hawk - 11/7/2007 12:01:37 AM
TomOver
Status: offline
that is what is good
