mikek0416
FL, USA Status: offline
UPDATED NOVEMBER 2007 FOR CLARIFICATION PURPOSES quote:
ORIGINAL: mikek0416 The manufacturer's market name is Heli Pro. We have a solid, open and honest relationship with them. After long term testing of the 450SE helicopter, we have made substantial progress improving a couple of the key components and in being able to provide our customers with a solid dependable electric line of RC helicopters. We are in the business of customer satisfaction. These are now sold at www.ka-planes.com The following are the results of the review we went through to determine if we would sell these helicopters as your potential better Kopter. VISUAL The first thing I notice is silver/gray tail boom (450SE Pro). It has the visual look of being very thick and sturdy and the effect of the silver coloring on all of the metal parts and screws is really quite appealing. The second area that I spot, is the head. It looks very thick and sturdy and the design is quite solid. Bearings are added to crucial points in the linkage system to add more responsiveness and smooth movements of the mechanisms. WEIGHT The weight of the 450SE is 675g including the canopy and battery (weighed it with a 11.1v 2200mAh battery 161g) - excludes 34g for stock 310 mm blades DIMENSIONS Though the dimensions are listed by my manufacturer, I always like to measure a heli myself and these are reflective of my measurements. Length: ~550 mm with canopy 650 mm = 25.5" Width: 112 mm = 4.5" Height: 240 mm = 9.4" Main Rotor 675 mm = 26.5" Main rotor blade length: 310 mm ea. = 12.2" Tail rotor blade length: 55 mm ea. ELECTRONICS 3200kv outrunner brushless motor, Powertech 35A ESC HobbyPro head lock gyro 11.1v 2200mah Lipo battery and charger. (charger has the charge-finished light and we add a lipo balancer/charger) 6 channel receiver WFly ( seems like a manufacturer for some big brand labels) Tower Pro 9g servos TRANSMITTER The RTF includes a 6 channel FT06C WFLY helicopter transmitter also has features for an airplane. The feel as with most radios is good and suitable from an ergonomics perspective. The Tx has a pitch dial on the face, idle up (3D), throttle hold and dual rate toggles. This is a very nice radio receiver system and the more I use it the more I like it.. QUALITY CHECK Ka-Planes accomplishes prior to selling 1 visual, nothing bent or broken 2 screws randomly checked for tightness and head looked at for adjustment 3 wires neatly tucked and connected properly 4 fly into a hover and adjust Rx, gyro or Heli as appropriate 5 forward flight and figure 8 to check for adjustment We use our batteries in the radio and heli OPERATING MANUAL The manual is certainly a weakness and I plan to rewrite it or at least tweak it. The photos help clarify different things but the words are not always clear as they could and should be. OTHER OBSERVATIONS The Black Hawk is easy to work on and it seems to be a heli that not only has a great appearance, but it is also very sturdy with reliable electronics. The initial helicopter we tested starting in the March 2007 timeframe has withstood numerous tests.The electronics, now that the gyro has been upgraded, have all been very reliable. No complaints or failures. The Black Hawk releases in November 2007 are assembled with hex head screws other than the head and tail that use phillps head screws. Threadlock is recommened especially in the head and tail. FLYING CHARACTERISTICS The Black Hawk revs up smoothly and efficiently. The power combo (battery, ESC and motor) are powerful and the heli went into a hover with no trouble whatsoever. She is rock solid out of ground effect. Forward flight and rolls is smooth and effortless. Around the back yard and in the field the hawk is easy to navigate and is easy to see. The system is very responsive but not at all sloppy. Upon landing, even a little hard, the heli seems very solid when hitting the ground, pavement and the garage floor. Overall, this heli is a flyer! SIDE-BY SIDES - not a debate, just my opinion Black Hawk 450 and the Falcon 3D Price - both list for $299.99 BH is longer, wider, taller and more stable (BH is the same size as a Trex and the Falcon is more petite) BH motor and ESC are more powerful, durable and dependable BH gyro is more reliable BH quality is slightly better Falcon Canopy is more appealing though paint jobs quality suffers. Hot Pink has come out of the factory, BH canopy is much thicker and sturdier. Falcon cardboard box is better, has a handle and can be used as a case. The outer box of the BH is thin and does not have a handle. Parts availability is better on the BH. Not restricted like with the Falcon's. Trex compatible in lots of areas. However, Zoom 400 parts common to the Falcon are being discovered and is taking some pressure off of the buyers. More online support for the Falcon, as far as owners Falcon tail boom and tail mechanism is inferior Falcon head and linkages is flimsy BH transmitter is superior OVERALL - BLACK HAWK SAME PRICE, BETTER APPEARANCE, BETTER QUALITY, BETTER SUPPORT, BEST INCOMING INSPECTION Black Hawk 450 SE and the Trex The price of a Trex RTF (SE) varies, depending on installed options, from about $699 to over $1,000. The Black Hawk SE , nicely equipped, ranges from about $400 for the 450SE to $699 for a Thunderbolt 450Z Black Hawk is less expensive in all models BH and Trex sizes very similar BH motor and ESC are not known names (HobbyPro) vs Align BH gyro name not internationally recognized as with Align BH and Trex quality, no apparent difference BH canopy is longer but Trex canopies fit the BH nicely BH box includes styro inside but box is not a case with a handle BH parts available and Rex 450 compatible is some areas. Trex parts availability superior. More online support for the Trex, as far as owners Trex head is similar Transmitters vary depending on options selected some parts thickness measurement comparisons (metal version) carbon frame - same metal head - B Hawk thicker tail - B Hawk thicker but has a plastic slider OVERALL - BLACK HAWK QUALITY SEEMS THE SAME OR SIMILAR AS TREX's AND IN SOME AREAS BETTER VIDEOS http://www.youtube.com/watch?v=UpAiCmuLAzw http://www.youtube.com/watch?v=dEOmbOYlxvw WILL UPDATE, AS APPROPRIATE
