Best Prop for engine pipe combo
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> TEAM RCU >> Team RCU - Don Szczur >> Best Prop for engine pipe combo
Page: [1]
Login
Best Prop for engine pipe combo - 9/1/2007 11:32:08 PM
yearn23d
Status: offline
Don,
I just purchased an Oxai Pinnacle sporting a YS 160 DZ with an NMP Header and Hatori 693 Pipe. It currently has a 2 blade 16.5 x 12W APC and was wondering if that combo is perfect, or should I order a 4 blade. (The plane only has 12 flights and I am told everything is new to the plane. )If so what size, namebrand and place of purchase would you suggest? I will be flying Intermediate if that bears any supporting relavence.
Thanks in advance,
J. Tucker
< Message edited by yearn23d -- 9/2/2007 12:47:28 AM >
       Post #: 1
RE: Best Prop for engine pipe combo - 9/2/2007 4:44:30 AM
Don Szczur
Status: offline
4 Blade will give you slower speed. I'd suggest trying out what you have and if you like it you can always continue or experiment with different prop combinations at a later time.
Coming to the FARM Warrenton, VA pattern contest in 3 weeks? I'd be happy to let you try a 4 blade on your plane to see what you think.
Don
(in reply to yearn23d)
       Post #: 2
RE: Best Prop for engine pipe combo - 9/3/2007 3:35:47 PM
yearn23d
Status: offline
Don,
Oh how I wish I could attend. I'm still in Iraq. I won't be home until Oct 20th or so. I don't know if you remember me, I came to several contest with Carl Zal..... in 06 and one in 07. I talked with you about your Comp Arf Extra because I wanted to do a tribute scheme SX. I just ordered a 3.3m Yak with the old Giles 202 Flag Scheme so I can complete that tribute scheme. I look fwd to seeing you again and I will probaly just order a 4 blade so as I'm practicing over the winter I can experiment.
Do you have a recommeded diameter and pitch or place to purchase.
Thanks again Don,
James Tucker
(in reply to Don Szczur)
       Post #: 3
RE: Best Prop for engine pipe combo - 9/7/2007 8:29:27 AM
Don Szczur
Status: offline
Best Place I've found in Central Hobbies. www.centralhobbies.com
15.5x12 has worked well for me.
Don
       Post #: 4
RE: Best Prop for engine pipe combo - 9/7/2007 6:40:10 PM
ddd
Status: offline
Don, Why do you recommend high pitch propellers for pattern?
       Post #: 5
RE: Best Prop for engine pipe combo - 9/15/2007 3:18:13 AM
Don Szczur
Status: offline
The 4 blade prop high pitch keeps the noise down. We get very paranoid when it comes to the noise checks before each flight at the finals/ team selections. 4 blade- I found has the best "thrust to db ratio coupled with speed range" for glow planes (at least from testing on the Brio).
Don
(in reply to ddd)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.797RCU1
