cwharper -> RE: killed my power supply, any ideas on how to fix? (4/5/2008 9:55:20 PM)
Update: My Mastech HY5020E doorstop is fixed and regulates like a new one now (no longer a doorstop, will have to find something else for this purpose). John Mardock (john4648) contacted me from this thread and through me was able to pinpoint the problem by checking for voltage at various points. The symptoms were a totally dead supply with no display and no obvious blown fuses. So he started at the control board. This is a modular board located near the on/off switch. (see picture) The motherboard supplies this modular board with 340v dc, so be careful as it will kill you. With the dead supply turned on, it was getting 340v dc to the board. Next to check for output voltage, the lower three pins of the molex connector should have +/- 5v with the bottom pin as common. (see picture) My dead supply had nothing here and this is where the display gets its power so with no voltage then no display, aaaahaa. He then suspected the pulse width controller (TOP223) had gone bad since there was no ouput from the control board. So I mailed him this modular board, he confirmed the bad part, replaced it, and mailed it back. After I put the board back in, the supply turned on the first time. I checked output voltage at the terminals and tried various loads and it regulates just fine. The part cost a little over $3 and with priority mail postage turn around time was six days. Can't beat that with a stick. This of course is only a solution to the specific problem of my power supply, which we now believe to have been caused by a power surge. However, he said one of his mastech's burned up when he connected a 7s pack when it was set for a 4s pack and caused a lot more damage than just the pulse width controller. (reverse current?) But he was still able to repair it. He also said that if anyone else wanted help in repairing their mastech to send an e-mail, but warned if the problem was any of the transformers inside it could be nearly impossible to fix since they are unique to this power supply and getting a replacement from the manufacturer isn't easy. I've learned a bunch from this.
