Campy
CT, USA Status: offline
It would seem that the following is what is wanted (not necessarily in this order, but probably close ): 1. Full figure, painted and detailed in various scales and (ideally ) with some measurements also (height, width, thickness ). 2. Busts, painted and detailed in various scales and (ideally ) with some measurements also (height, width, thickness ). 3. Full figure, NOT painted or detailed painted in various scales and (ideally ) with some measurements also. 4. Busts, NOT painted or detailed painted in various scales and (ideally ) with some measurements also. This would cover 99.9% of the bases. The non painted ones could just be some from the run you didn't want to paint. As mentioned above, weight is ALWAYS a factor, however, many modelers are willing to accept a LITTLE extra weight PROVIDED the detailing and/or painting is accurate and top shelf. The final factor will be the price. I would pay $75 for a 1/8 or 1/7 scale full figure pilot that is painted and WELL DETAILED.
