Flyboy Dave
CA, USA Status: offline
....let's look at another example. Say a man can produce 1/10 of one HP. Just about everyone knows how the winch on the front of a boat trailer works. The man can pull a several hundred pound boat with the aid of the gear reduction, yes ? The man however, is still producing 1/10 HP....he cannot produce more. Same thing with the tiny engine....you can gear it down, but the power of the engine itself does not increase.... ....the mechanical advantage increases. The man with a lever can move a lot of weight, but his 1/10 HP remains the same, no matter what. If a 100 pound man with 1/10 HP, and a lever moves a 1,000 rock...then his HP goes up by the power of 10, to one full horsepower, right ? Wrong. The tiny engine gets the big rating by spinning a two ounce weight at 20,000 RPM, and end up with a one HP rating. So the tiny engine is a strong as a horse, right ? Wrong. FBD.
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
