RE: NELSON FAI TUNING?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> General Racing Discussion >> RE: NELSON FAI TUNING?
Page: <<   < prev  1 [2]
Login
RE: NELSON FAI TUNING? - 5/15/2008 1:04:23 AM
Terryoc
Status: offline
Hey is that you Vince heading over for the AMPRA champs, good stuff.
Any way I found with FAI fuel a single cell is not quite enough especially on cold mornings or if you flood it a little it just wont have the burn power. I use 2 C cell 3600 in series with about 1 1/2" nichrome wire to drop the voltage a little.Other guys here in Vic use these http://www.batteriesplus.com.au/pd/810/273/hawker-08000004-x-cell/ and just use long leads of a small diameter wire to drop the power a little, best thing this mob is in WA.
See you in June
Terry
another link
http://www.premierbatteries.com.au/sm/sla/0800-0004/0800-0004.htm
(in reply to djlyon)
       Post #: 26
RE: NELSON FAI TUNING? - 5/15/2008 2:03:00 AM
fizzwater2
Status: offline
That's the same battery that you use in the old Globee fireplugs. They were pretty simple, too - the 2V battery, a small (1 ohm if I remember correctly) 25 watt pot for dialing down the current a bit, one wrap of the wire around a meter movement (not even directly connected, just magnetic coupling) and all in a nice plastic case.
The Cyclon also comes in a 2.5 AH size that's about the size of a D cell. I just picked up one of those, will use like above, just a length of wire and a plug clip. Hard to get much simpler than that!
_____________________________
no matter where you go, there you are..
(in reply to Terryoc)
       Post #: 27
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.188RCU1
