RE: Kyosho Inferno Us Sports    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Kyosho Inferno Us Sports
Page: <<   < prev  56 57 58 59 60 61 62 63 64 [65]
Login
RE: Kyosho Inferno Us Sports - 4/19/2011 2:46 PM
lez1troubles
Score: 133
Last Login: 4/5/2013
Status: offline
Bump
Hide Signatures
(in reply to lez1troubles)
       Post #: 1601
RE: Kyosho Inferno Us Sports - 4/22/2011 11:57 AM
All-or-Nothing
Score: 100
Last Login: 2/12/2012
Status: offline
I picked up this MP9 from a friend thru a friend. He let it go for $200. I know it's a MP9 but I have no idea what version I have. Can anyone tell me.
Here are some pics but if i need to take a pic of a certain area to help identify it than let me know.
_____________________________
Aftershock 8e, Earthquake 3.5
Serpent 811, Kyosho MP9
Hide Signatures
       Post #: 1602
RE: Kyosho Inferno Us Sports - 4/22/2011 12:14 PM
lez1troubles
Score: 133
Status: offline
Hi All or Nothing, nice, you bought that for 200 buck, jeez that was really good, I paid 500euro for one last year also second hand.
Well done, you have a nice buggy there.
Looks like the TKI version but not certain(yet).
Hide Signatures
(in reply to All-or-Nothing)
       Post #: 1603
RE: Kyosho Inferno Us Sports - 6/9/2011 1:51 PM
lez1troubles
Score: 133
Status: offline
Any body still alive???
Hide Signatures
       Post #: 1604
RE: Kyosho Inferno Us Sports - 6/9/2011 5:31 PM
R.lepecha
Score: 100
Last Login: 11/28/2012
Status: offline
quote:
ORIGINAL: lez1troubles
I am, Seems like not much is happening with these buggies anymore. The Inferno mp7.5's and later must be going obsolete.
Hide Signatures
       Post #: 1605
RE: Kyosho Inferno Us Sports - 6/9/2011 7:04 PM
Oskr
Score: 100
Last Login: 2/6/2013
Status: offline
quote:
ORIGINAL: R.lepecha
Indeed. I struggled a lot to find the spur gear. I got an original set from China. But even obsolete the car is still a great car , and I don´t think there will be a serious lack of components in the market.
And maybe in the future I convert my Inferno to electric and keep the xray on nitro.
Hide Signatures
(in reply to R.lepecha)
       Post #: 1606
RE: Kyosho Inferno Us Sports - 6/9/2011 7:06 PM
R.lepecha
Score: 100
Status: offline
quote:
ORIGINAL: Oskr
quote:
ORIGINAL: R.lepecha
I think if i remember correctly the spur gears are interchangable between most of the kyosho buggies. So the m777 and mp9 should fit..
Hide Signatures
(in reply to Oskr)
       Post #: 1607
RE: Kyosho Inferno Us Sports - 6/10/2011 2:24 AM
Oskr
Score: 100
Status: offline
Right. MP777 spur gear(MA050) fits. The problem was the gear was out of stock everywhere. But now I am ok.
Hide Signatures
       Post #: 1608
RE: Kyosho Inferno Us Sports - 7/12/2011 11:46 AM
lez1troubles
Score: 133
Status: offline
All spare parts can still be had at WWW.INFERNOSONLY.COM. Thats for all the Inferno models whether it be the old BURNS all the way up to the MP9limited. even bits'n'bobs from the older Kanai versions are still there to be had.
Had a great weekend racing, next weed I'm going with a couple of freinds to race a guy called Bart Loomans, he is a sponcered driver for pro team KYOSHO and I'm going to kick his butt(not litterally, just in the race), Bart is the current BeNeLux buggy champion.
Hide Signatures
(in reply to Oskr)
       Post #: 1609
RE: Kyosho Inferno Us Sports - 8/19/2011 3:09 AM
Oskr
Score: 100
Status: offline
Hello guys. Hello Lez1!!
Well, I just messed up another pinion & bevel gear set. IT seems it´s missing something. Maybe some washers in the diff/bulkhead to get the right fit?? How to know(measure) the the right fit?
I just run 4 tanks with the new set and the noise on the diffs started again. Maybe this time some washers may solve my problem.
Hide Signatures
       Post #: 1610
RE: Kyosho Inferno Us Sports - 8/19/2011 10:06 AM
R.lepecha
Score: 100
Status: offline
Have you checked the bearings?
Make sure they're not seized.
Other than that are you sure you've got the shims from the bottom of this photo?
Hide Signatures
(in reply to Oskr)
       Post #: 1611
RE: Kyosho Inferno Us Sports - 8/19/2011 12:42 PM
lez1troubles
Score: 133
Status: offline
Like Lepecha said, you will need to shim it otherwise you'll have exece slop inside your diff.
Just shimm the satalit gears and you'll be good to go.
Have you got 2 satalit gears or 4 in there???
Hide Signatures
       Post #: 1612
RE: Kyosho Inferno Us Sports - 8/19/2011 5:07 PM
Oskr
Score: 100
Status: offline
Thanks guys, but I think I wasn´t clear in my explanation. I messed up the bevel and pinion, not the internal gears. By the way I have 4 planetaries with the shims. Lez1, I went to 4 planet. following your suggestion when I was changing the engine to a LRP .28.
There is a shim (BS53) that goes between the diff. bearing and bulkhead (not the one in the photo) and is supposed to improve the bevel and pinion match, moving the diff toward its side. I will order some of these shims and try to change (for better) the match.
Hide Signatures
       Post #: 1613
RE: Kyosho Inferno Us Sports - 8/22/2011 11:01 AM
lez1troubles
Score: 133
Status: offline
Sorry Oskr, slight brain fart there.
Its the one in the middle that you want to shim, I am using a 0.2mm shim if that helps.(I get my hardwear from a hardwear store, not a modeling store as they mostly have a larger selection of bits'n'bobs at a better price and also most nuts and bolts come in different materials or strengths.
Later dude.
Hide Signatures
(in reply to Oskr)
       Post #: 1614
RE: Kyosho Inferno Us Sports - 9/28/2011 12:55 PM
lez1troubles
Score: 133
Status: offline
Just ordered the BCE SPEED chassis for the MP7.5, real piece of art.
Hide Signatures
       Post #: 1615
RE: Kyosho Inferno Us Sports - 2/27/2012 3:43 PM
Oskr
Score: 100
Status: offline
Hello all.
Just want to share with you my last set up for the GXR28. After so many lost fights to it, now it is in its best shape ever!!!
Hide Signatures
       Post #: 1616
RE: Kyosho Inferno Us Sports - 2/28/2012 1:43 PM
lez1troubles
Score: 133
Status: offline
Hi Oskr, your High speed needle is in to far and your low speed needle is out to far.
Hide Signatures
(in reply to Oskr)
       Post #: 1617
RE: Kyosho Inferno Us Sports - 8/3/2012 8:39 PM
Oskr
Score: 100
Status: offline
Hello all. I hope this topic is kind of stuck because everybody is using the time to bash their cars!!
I have a question: since I don´t remember when, I am having some problem to make my inferno steers in a proper way in the corners. In the beggining I touhgt was the original servo. I replaced it by a fut. 3305. Then the tires, toe out, and for last, the diffs silicones. After all these it is a little better but not as much as I tought and want. The goal is to have the same cornering hability from my other car (xray xb808).
Along the years, aftet wrecking the original shocks I replaced them by the big bores from xray. Can this be the problem?
Hide Signatures
       Post #: 1618
RE: Kyosho Inferno Us Sports - 8/4/2012 7:49 PM
lez1troubles
Score: 133
Status: offline
Hi Oskr, could be that you oil in the front diff is a tad to thick. or give it some more toe out. Nice to see your still using the Kypso mp7.5 though. Me to, still no major problems after how many years????
Hide Signatures
(in reply to Oskr)
       Post #: 1619
RE: Kyosho Inferno Us Sports - 8/10/2012 4:55 PM
Oskr
Score: 100
Status: offline
...after 5 year, Lez!!!!...and regarding the steering issue, I don´t think the oil thick is the issue. Basically I am using the same grades from my xray. But what I do saw these days, was the connecting link (from servo to servo-saver) was a little short. I lenghtened it and now is ok. And also, now the servo-saver arm is touching the steering plate when it is totally steered. But this is not a major issue.
Thakns for the reply, Lez. And I will keep seaching a solution.
Hide Signatures
       Post #: 1620
RE: Kyosho Inferno Us Sports - 11/28/2012 7:36 PM
R.lepecha
Score: 100
Status: offline
Any one still using these a lot?I lent mine to a friend a few months back, it came back with a bent front shock shaft.
I haven't looked at it since. I might look at it at soon. It still runs but shock shafts are difficult to find.
Hide Signatures
(in reply to Oskr)
       Post #: 1621
RE: Kyosho Inferno Us Sports - 11/29/2012 6:03 PM
Oskr
Score: 100
Status: offline
quote:
ORIGINAL: R.lepecha
Still using my inferno but not a lot or as much as I want. It´s been hard to focus on RC lately: new baby girl, new home, moving to a new city. The only thing I´ve been doing is to start the engines so it doesn´t get stuck and also charging and discharging the baterries. Just trying to keep everything working.
Lepecha, could be much worse than a bent shaft...so, you´re lucky.
Hide Signatures
       Post #: 1622
RE: Kyosho Inferno Us Sports - 12/28/2012 12:56 PM
lez1troubles
Score: 133
Status: offline
Papa Oskr, lol. Got yourself a new hobby. My son is 21 today. Have fun and enjoy it now they she is still young.
I am still running the old mp7.5 and still no problems.:-) I got 4 of them now.lol thats how much I like em.
Hide Signatures
(in reply to Oskr)
       Post #: 1623
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.703RCU1
