RE: Kyosho Inferno Us Sports
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Kyosho Inferno Us Sports
Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: Kyosho Inferno Us Sports - 3/12/2008 4:31:40 AM
gbasile77
Status: offline
Jerzferno - I think you are right regarding the steering linakge, I think the reason the one I saw was flipped around is because a turn buckle linkage is quite a bit bigger and it probably won't fit under the front upper plate when the car steers to the . I remember seeing a good article on the web showing how somebody did that exaxt upgrade to a US Sports - I will try to find it and put the link in here.
(in reply to Jerzferno)
       Post #: 376
RE: Kyosho Inferno Us Sports - 3/13/2008 1:43:14 AM
jnc011994
Status: offline
Hello Guys,
just like to ask on why is it that when i fire up the stock pull-start kyosho engine, it doesn't idle. What happens then is that the wheels go fast, thus i push the brake to have it stopped. But after the 2nd, 3rd, or even 4th start, i don't have that problem. It's only on the first start. I have checked the carb opening and its only about 1/3 open. Don't know if i did something wrong with the Radio settings though.
Appreciate the help and guidance
Jojo
_____________________________
Kyosho Inferno US Sports
GO Engine .21 7Port
(in reply to gbasile77)
       Post #: 377
RE: Kyosho Inferno Us Sports - 3/13/2008 5:49:53 AM
Jerzferno
Status: offline
Your carb is open 1/3 at idle? It should only be open approximately 1mm. Reset your idle. Also, make sure your servo is not holding it open when at idle. Sounds to me like it is based on what you are saying, "thus i push the brake to have it stopped. IF.............your throttle is not holding it back and your idle is set properly and this still happens, your clutch spring (if you still have the stock clucth) "may" be stretched. Reset the idle first and let us know what happens? I had the clutch spring problem happen on a differetn model. Drove me nuts. I kept reducing and reducing the idle until it would stall out. the wheels kept spinning. Took the clutch apart and the spring was stretched.
< Message edited by Jerzferno -- 3/13/2008 3:51:03 PM >
We can rebuild it!
MARBETH Motorsports
(in reply to jnc011994)
       Post #: 378
RE: Kyosho Inferno Us Sports - 3/13/2008 9:37:21 AM
tommygun32
From: San Diego but living in Dubai, UNITED ARAB EMIRATE
Status: offline
Jerzferno...thanks for the Dif oil info mate. (and the previous instructions for changing out the oil you posted earlier) Highly Appreciated.
***The only stupid question, was the one you didn''t ask!***
       Post #: 379
RE: Kyosho Inferno Us Sports - 3/13/2008 3:53:38 PM
Jerzferno
Status: offline
Tommy......glad I could offer some assistance. GB........I flipped the servo saver arm around last night just for kicks. It works, but interferes with the body. You can trim the body but there will be a hole in sight. I see no reason to flip the arm unless you decide to lay the servo on its side. Keeping the servo in its stock configuration (top) there no gain in performance flipping it to the other side.
We can rebuild it!
MARBETH Motorsports
(in reply to tommygun32)
       Post #: 380
RE: Kyosho Inferno Us Sports - 3/14/2008 1:44:50 AM
jnc011994
Status: offline
quote:
ORIGINAL: Jerzferno
Hi Jerz,
I'll try to check tomorrow if the carb's 1/3 open. I don't usually remove the Air Filter to check the carb opening. But my point is, why is it that it only happens "once". Only during the first start-up.
I only play during the weekend (sometimes even 2 weeks). So maybe that's why it happens like this. Thanks for the tip
Jojo
GO Engine .21 7Port
       Post #: 381
RE: Kyosho Inferno Us Sports - 3/14/2008 3:26:21 AM
gbasile77
Status: offline
Jerzinferno - Thanks for that servo saver analysis. I looked at some of the manuals and found that the MP 7.5 Kanai has the servo saver 'inboard' however it uses a turnbuckle linkage. So I guess it should not interfere with the top plate. Also the MP 777 has the linkage on the outside for what it is worth.
A Main has the Kanai steering linkage, so I think that might be a direct fit to our cars.
       Post #: 382
RE: Kyosho Inferno Us Sports - 3/14/2008 4:31:16 AM
Jerzferno
Status: offline
Cool. Let me know how you like it? I may go that way too.
We can rebuild it!
MARBETH Motorsports
       Post #: 383
RE: Kyosho Inferno Us Sports - 3/14/2008 7:11:00 AM
gbasile77
Status: offline
I found a page with pics where somebody upgraded to a turnbuckle linkage on the ST US Sports:
http://www.offroad-cult.org/Tracktest/Kyosho_Inferno_ST_US_Sports/Kyosho_Inferno_ST_US_Sports_1_english.htm
       Post #: 384
RE: Kyosho Inferno Us Sports - 3/15/2008 5:13:13 AM
Jerzferno
Status: offline
Looks good. No time to research. Do you have part numbers, manufacturer, etc?
< Message edited by Jerzferno -- 3/15/2008 3:45:28 PM >
We can rebuild it!
MARBETH Motorsports
       Post #: 385
RE: Kyosho Inferno Us Sports - 3/15/2008 6:11:35 AM
rammol
Status: offline
yes yes yes!!! i got my rplacement servo gear, for my futaba s9405 yes! my buggy has been siting in my garage for maybe 4 or 5 months and i finally got my little plastic servo gear for it that was all i needed and that took 5 months jesus but now i have so i put an aluminum servo arm on it since it was just laing in my tool box i'll get some recent pics up soon. adn what body fits the kanai 3
thanks yes!
josh
If you're not first you're last.
       Post #: 386
RE: Kyosho Inferno Us Sports - 3/15/2008 3:47:28 PM
Jerzferno
Status: offline
GEEEEEEEEEEEEEEEEEEEEEEEZ Ram........I thought you left us. Welcome back. Looking forward to the pics. Not sure what body would fit? I guess the 7.5 body will? Thats what I have on mine. I tried the Proline Crowd Pleazer about one year ago. Its narrower than the stock body. Rubbed on the mud sheilds.
< Message edited by Jerzferno -- 3/16/2008 1:59:13 AM >
We can rebuild it!
MARBETH Motorsports
(in reply to rammol)
       Post #: 387
RE: Kyosho Inferno Us Sports - 3/15/2008 6:09:59 PM
rammol
Status: offline
where do you get the 7.5 bodies? do you think the 777 will fit it. i hope the engine didnt get rusted or get full of dust or anything
thaniks
       Post #: 388
RE: Kyosho Inferno Us Sports - 3/15/2008 11:35:50 PM
gbasile77
Status: offline
Here is my US Sports with recently installed GO 7 port and Go 2047 pipe. Still breaking it in but looking good.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 389
RE: Kyosho Inferno Us Sports - 3/16/2008 2:34:52 AM
Jerzferno
Status: offline
RAM.....I got mine from my LHS. Look on www.amainhobbies.com. They have:
The J Concepts Illuzion body for the 7.5
http://www.amainhobbies.com/product_info.php/cPath/1_201_242/products_id/5055
GB.....Looks good. Good luck with it.
We can rebuild it!
MARBETH Motorsports
