Jerzferno
NJ, USA Status: offline
REEG - The only thing you will have to do when changing from 20 to 25 is to retune. I just changed from Trinity Platinum 20% to Byrons Gen2 25%. All it took was a little retuning. If you get into the 30-33 percent range, I think head shimming needs to be done? Dont know for sure but I read it somewhere? Regarding your turning problem. I can really help you with that. I have mine set up so it turns on a dime. I can turn so tight if I want to. Did lots of experimenting, and some upgrades too. I need to know what servo you have? What servo arm you have? Where you have your suspension points set up? Example top shocks inner hole, bottom outer, etc. What springs do you have? What diff oils do you have? What tires do you use? After that, Ill be able to help you out. All of that in combination is important for good steering. Oh, and sway bars or no sway bars? Pics of your set up would help too.
_____________________________
We can rebuild it! MARBETH Nitro Sports
