Jerzferno
NJ, USA Status: offline
REEG - A good habit to get into is tighten all screws on a regular basis. I tighten everything after each heat/main. If you are bashing, you should make that part of your after run procedure. A few extra minutes can save you some serious headaches and reduce the strain on your wallet. What did you find wrong with your clutch? Worn shoes? Broken/stretched spring? Clutches are often forgotten by most RCer's. Probably because its no easily seen, and most clutch access requires removing the engine to get to it. I neglect my clutch sometimes for these reasons, but try to look at it routinely. What after maket clutch/flywheel are you looking to purchase and why? I dont upgrade unless I have continual problems with a particular part. For example, My engine started going down hill after about 2 gallons of fuel through it. There were several air leaks (which I repaired) leaking fuel from the front bearing, erratic tuning, (Had to tune it every time I ran it), and it ran extremely hot. After loosing opportunities to bump up to the A-Main, and loosing opportunities to get good A-Main finishes because of this eninge, I replaced it. Plus the countless hours of wrenching on this, I got tired of wasting my time. Congrats on your successful repair of the clutch. Its very satisfying to troubleshoot a problem, then do the repairs on your own. Theres no better way to learn about your buggy
< Message edited by Jerzferno -- 10/16/2007 11:00:52 PM >
_____________________________
We can rebuild it! MARBETH Nitro Sports
