opjose
MD, USA Status: offline
quote:
ORIGINAL: Tailspincharlie Clowdniner, I don't think a 10" prop will clear the ground. My 9x6 only leaves about a half inch clearence. Tailspincharlie I just finished my Bobcat .25 I have an APC 9x7 three bladed prop on it. There seems to be adecuate clearance with this prop. Mine will be flying ( I hope ) with a 10oz 3900mAh 11v Lipo battery and a 1250KV motor. To make the canopy easily removable I put a piece of wood just in in front of the existing former... accross the fuselage like the former. This was epoxied in place. I put two matched Carl Goldberg Angle Hold downs on the wood with screws, with the "C" clip side facing forward on both. I then inserted a small metal rod accross the canopy in the correct position, and epoxied it in place. To install the canopy, I push it backward from in front, until it latches into place. To remove I just push it forward until it unlatches... Very easy to install and do. I also added small plastic air scoops just forward of the canopy, and cut the door "oval" out of the covering, to provide an airflow path to help cool the battery and ESC.
_____________________________
- Build em'', fly em'', crash em'' and build more.
