Kyosho 1/8 Scale Mamba Powered.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Motorcycles >> Kyosho 1/8 Scale Mamba Powered.
Page: [1]
Login
Kyosho 1/8 Scale Mamba Powered. - 9/6/2007 11:17:25 PM
Biscuit
Status: offline
Hi all,
Just got my Mamba powered 1/8 scale going again, 3cell lipo, thing is cant remember the gearing, so thought I would run the little pinion, but its to crazy, cant pull away without it fliping, taken the throttle curve down and its better but I am still gluing it together as we speak !! so might try the big gear anyone tamed this set up?? running the high grip tyres and the 68000 Mamba, alloy swinging arm and a 3 cell 600mah battery, maybe try the 2 cell, but on the 3 it pulls fantastic wheelies but like I said still gluing it back together. :-) Any views on this or set up help?
Thanks.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: Kyosho 1/8 Scale Mamba Powered. - 9/7/2007 8:42:08 PM
Biscuit
Status: offline
Ok I guess the old kyoshos not in favour any more, never mind been running mine tonight again with a modified throttle curve but still way to much plus I seem to have a range problem, sure I had this before on 40 meg fm, and had to run 27meg, but cant see why, anyone else out there still run the Kyosho ??
Biscuit
(in reply to Biscuit)
       Post #: 2
RE: Kyosho 1/8 Scale Mamba Powered. - 9/9/2007 11:09:47 PM
Biscuit
Status: offline
Well still going it alone, but found that the 12 tooth pinion works the best, still got to be mega carefull on the throttle, but only 2 big crashes tonight, I love this little bike, makes my 1/5 scale i/c seem slow !! just ordered another 600mha lipoly battery, runs for 8mins and only get 440mah back in the cells, need the metal pinions as the plastic ones come off when the motor gets hot. The Kyosho ones are ok but the grub screws are too small, looking for some better pinions with bigger grub screws, any one got any Ideas??
Biscuit
Ps Cured the range problem, new pcm rx.
< Message edited by Biscuit -- 9/9/2007 11:11:45 PM >
       Post #: 3
RE: Kyosho 1/8 Scale Mamba Powered. - 9/10/2007 12:14:17 AM
dicko
Status: offline
try RCGroups motorbike forum, there's lots of traffic there. plenty of HOR threads.
_____________________________
The answer is always more power.
       Post #: 4
RE: Kyosho 1/8 Scale Mamba Powered. - 9/10/2007 1:55:06 PM
Biscuit
Status: offline
Thanks Mate ! hope to have a bit more interest. seems to be all 1/5 scale.
(in reply to dicko)
       Post #: 5
RE: Kyosho 1/8 Scale Mamba Powered. - 9/10/2007 11:47:02 PM
dicko
Status: offline
there's plenty of 1/8th on there. & they've been upgrading HORs for a while.
       Post #: 6
RE: Kyosho 1/8 Scale Mamba Powered. - 9/12/2007 11:56:48 PM
SirSmokeAlot
Status: offline
Need to know how to set the curve for the motor.... have the 8000kv and the USB link...
Would like help with the curve.... hestant start..... needs lots of input on the trigger of the radio to even get it respond.... How do I take this out?
(in reply to dicko)
       Post #: 7
RE: Kyosho 1/8 Scale Mamba Powered. - 9/13/2007 12:01:43 AM
dicko
Status: offline
have yuo got teh latest software installed on your ESC? you can download it from castle creations & install it. the old software on the ESCs used to have a cogging problem that you describe. otherwise put somepositive expo on your curve throttle curve
(in reply to SirSmokeAlot)
       Post #: 8
RE: Kyosho 1/8 Scale Mamba Powered. - 9/13/2007 12:15:36 AM
SirSmokeAlot
Status: offline
Alright I will try....
Whats with the check points?.....
Need help understanding the program I guess.
(in reply to dicko)
       Post #: 9
RE: Kyosho 1/8 Scale Mamba Powered. - 10/24/2007 2:58:12 PM
2002denali
Status: offline
Just bought one and picking it up sunday.Going to start with a modified brushed motor but have already been looking at lippo's and have a brushless esc but no motor yet.
       Post #: 10
RE: Kyosho 1/8 Scale Mamba Powered. - 11/13/2007 4:26:09 PM
2002denali
Status: offline
I have the mamba 6800 in mine.Using a 13 tooth pinion from my micro RS4.They are metel a work great.Only had it out a few times.Found I have to glue the tire to the rim as under accelleration the rim spins on the tire.Haven't tried it yet but will later today.So far this bike has been alot of fun.Looking at getting a lippo or two.What's it like with a 3s?Is it driveable?Will most likely get a 2s and 3s just because I think the 3s will make the bike just stupid fast.
(in reply to 2002denali)
       Post #: 11
RE: Kyosho 1/8 Scale Mamba Powered. - 11/14/2007 1:33:52 AM
Barika
Status: offline
Hi
can you tell me the name of the bike i mean what kyosho is it?
Bar.
       Post #: 12
RE: Kyosho 1/8 Scale Mamba Powered. - 11/14/2007 2:15:48 AM
2002denali
Status: offline
Kyosho HOR
(in reply to Barika)
       Post #: 13
RE: Kyosho 1/8 Scale Mamba Powered. - 11/14/2007 3:11:04 AM
Barika
Status: offline
where i can get one of these?
Bar.
       Post #: 14
RE: Kyosho 1/8 Scale Mamba Powered. - 11/14/2007 6:38:44 PM
2000-redrider
Status: offline
quote:
ORIGINAL: Barika
Bar.
If you're looking for a Kyosho HOR (or other r/c motorcycle), go to www.2wheelhobbies.com. You can get the kits as well as parts and hop ups.
       Post #: 15
RE: Kyosho 1/8 Scale Mamba Powered. - 11/15/2007 12:56:06 AM
Barika
Status: offline
THANKS VERY MUCH BROTHER!
(in reply to 2000-redrider)
       Post #: 16
RE: Kyosho 1/8 Scale Mamba Powered. - 11/17/2007 1:07:15 PM
