Chuck Hartmann
CA, USA Status: offline
Hi Troy, (You may recognize me from So-Cal contests, particularly Riverside; I fly a red and yellow Focus with an O.S. 1.40.) You had to build your Focus Sport according to the instructions, to be fair. I didn't have to, so I built it with some changes. The one I want to tell about here is that I used only one elevator servo. I didn't see a torque need for 2 elevator servos but I thought they may have been used because the plane needed tail weight. I assembled my Focus Sport completely, including the engine and aileron servos, but without the rudder and elevator servos and the battery. (I also made a short tunnel along the bottom of the fuselage and ran a Johnson flex-header through it rather than having the muffler stick out the side of the cowl.) It balanced almost exactly at the recommended CG. So, I mounted the rudder servo on the rails provided at the rear of the canopy hatch, I added another set of rails just forward of those and mounted the elevator servo there, and connected the elevator servo to the elevator control horns using a large MK bell crank (Central's part #MKD1251). With that arrangement, I had to put the battery (5.2oz 4-cell 1200 mah) just ahead of the bulkhead at the front of the canopy hatch to get it to balance at the recommended CG. Doing it this way, I saved the tail weight of a second elevator servo (I did add the weight of the flex header but I don't like seeing the muffler sticking out the side of the cowl). I made the first flight of my Focus Sport last week. So far, I like the way it flies with the CG at the recommened position.
