RE: Focus Sport 110 YS Powered
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: Focus Sport 110 YS Powered
Page: <<   < prev  4 5 6 7 8 9 10 11 [12] 13   next >   >>
Login
RE: Focus Sport 110 YS Powered - 6/26/2008 6:53:24 PM
Robbidos
Status: offline
http://www.patternflyer.com/troy/
_____________________________
- Robert Beaubien
- Sun Valley Fliers
(in reply to MarkGrabowski)
       Post #: 276
RE: Focus Sport 110 YS Powered - 6/28/2008 11:43:38 PM
RMFISH
Status: offline
Hello Troy.
My Focus Sport has arrived and I am in the process of Looking and checking before building. I would like, for several reasons, to install the DEPS elevator system. Looking at the restricted space available through the former where the rudder servo rails are located, would I have to remove these rails to make a little more space to get ones hand in there? replacing them at a later time. Since, when ones hand is inside the fuselage through the former, one can not see inside to place a support for the DEPS rods, could you give some idea of what "You would do".
Some thoughts on your part regarding my post #266 would also be very much appreciated.
I am looking forward to being able to read all that you have put into this post on your Blog and thank you again for all you have done over the past year. I look forward to hearing from you.
Robert in Vancouver Canada.
(in reply to Robbidos)
       Post #: 277
RE: Focus Sport 110 YS Powered - 6/29/2008 12:56:15 AM
Troy Newman
Status: offline
DEPS in the Focus Sport.
Well we are going to be putting a DEPS in a Focus 2 in the next couple of weeks. I'll post some photos and do it on the Blog regarding this. This was the plan of attack in using the new Blog website for this.
The Focus 2 has a little more room in the fuse, but you can build a ship inside a bottle...or let me say some people can. Its the same process. If you give up and have to be a sledge hammer mechanic you can cut a hole.
I have been putting the Deps in completed fuses on $3500 Oxai models that have one piece wings and no access to the tail at all... You don't need to put your hand down the back...The existing rudder servo rails would stay in place and you could put the rudder servo and elevator servo side by side in the Focus Sport.
I'll post some more step by step how to do this. The Deps deal is not difficult to install with no access...I'll show a couple tricks on the Focus Sport to being able to see down the back end of the model, but reality is you don't need to see very far back in there to do it.
Troy Newman
(in reply to RMFISH)
       Post #: 278
RE: Focus Sport 110 YS Powered - 6/29/2008 6:43:08 PM
RMFISH
Status: offline
Hello again Troy,
I am looking forward to reading about the DEPS on your blog, particularly anything to do with the Focus Sport.
I have just been reading your construction "How to" series at Central Hobbies. Another great source of information. In the linkage section you have a drawing of the Rudder Pull Pull set up in which the wires do not "cross" right to left, left to right but go direct from the left side of the servo to the left control horn on the rudder. The same for the right side. As I mentioned before, I have never installed a pull pull system before and have only seen illustrations. Also, for your recommended 1.25"/1.5" long rudder control horns, how far from the screw hole of the servo would the wires connect to the servo arm to get the advantage you speak of?
Thanks again for all of your help.
Robert, Vancouver Canada.
(in reply to Troy Newman)
       Post #: 279
RE: Focus Sport 110 YS Powered - 6/29/2008 7:01:40 PM
RMFISH
Status: offline
Sorry Troy, forgot to ask, do you use the twisted wire cables or the newer Tetra type filament cables on your rudder set up?
Robert.
       Post #: 280
RE: Focus Sport 110 YS Powered - 7/1/2008 11:10:36 PM
CrateCruncher
Status: offline
RMFISH,
Like you I planned to do a DEPS setup on the Focus Sport I recently assembled for a friend. I discovered there is a laser cut plywood bulkhead inside the fuselage just ahead of the stabilizer leading edge. The DEPS is rather bulky in the same area and there is very little access to modify that bulkhead without damaging the covering or weakening the tail structure. While I am sure anything is possible given sufficient motivation it really is opening a can of worms. I discovered that without completely removing a significant amount of that bulkhead the rods would bind unacceptably. FWIW, Mike.
       Post #: 281
RE: Focus Sport 110 YS Powered - 7/2/2008 2:47:26 AM
Jeff_edge540
Status: offline
I ran into the same issue Mike. I just went with Futaba 9650's in the tail to make life easier.
(in reply to CrateCruncher)
       Post #: 282
RE: Focus Sport 110 YS Powered - 7/2/2008 7:24:26 AM
RMFISH
Status: offline
Thank you both for your input. I wonder what Troy will have to say about this problem?? I have found this post to be the most informative information package that I have ever read. Cheers.
Robert.
(in reply to Jeff_edge540)
       Post #: 283
RE: Focus Sport 110 YS Powered - 7/2/2008 8:50:49 AM
Robbidos
Status: offline
Not sure what he will say other than I can tell you he used the JR equivelant of the 9650's. No DEPS in his.
- Robert Beaubien
- Sun Valley Fliers
       Post #: 284
RE: Focus Sport 110 YS Powered - 7/10/2008 2:24:00 PM
socolofs
Status: offline
quote:
ORIGINAL: Troy Newman
Trial fit the hinges….look at the way the surface lines up on the trailing edge of the stab. One of my elevators the hinge slot in the stab was low….so when you put it together all was good until it got to the tip. Then the surface was about 1/32” low from being perfect on the centerline. This was an easy fix. I re-cut the slot that 1/32” higher on the stab Trailing edge and all lined up very very well. It wasn’t absolutely perfect but it was really really close. I think it will be fine with a little trim work, and it will not show in the flying.
This may be a lame novice question, but how do you cut a new slot 1/32" above an existing slot? Do you move the new slot to the right or left, or do you fill in the existing slot, or just cut a new slot on top of the old one? It seems with just 1/32" of wood between the new slot and the old slot in the stacked method you would introduce a weak link in the hinge attachment. Sorry if this is obvious to everyone else, but I'd appreciate a little guidance before I make the wrong cut.
thanks!
Scott
       Post #: 285
RE: Focus Sport 110 YS Powered - 7/10/2008 4:20:14 PM
Troy Newman
Status: offline
Scott,
You can move the slot to the left or right a little, or you can cut a CA hinge in half and use it to fill the old slot on the mis-cut side. Just don't glue it in until you glue the other hinge in place. Use it was a filler, on the one side. This piece of hinge will not go across the hinge line it just stays in the one side. Leave it in there and trial fit the new hinge location right on top or below the old one. Then when you use CA to secure the new hinge in its location the Thin CA will wick into your filler piece.
This is what I did. But moving the slot to the side also works very easily.
Troy
(in reply to socolofs)
       Post #: 286
RE: Focus Sport 110 YS Powered - 7/17/2008 1:40:33 AM
TomTreese
Status: offline
I am new to this thread and have a few questions. I just crashed my Aero-works Yak 90-120 which had a Saito 150.
I want a good Pattern plane and want to know your opinion of the Focus Sport with the Saito 150??
Any suggestions will be greatly appreciated.
Thanks.
Insanity: Keep doing the same thing expecting a different result.
       Post #: 287
RE: Focus Sport 110 YS Powered - 7/17/2008 4:57:32 PM
onewasp
Status: online
WAY too much power and weigh too heavy (spelling error intended)
The YZ110-S is about all it (or you) could handle. Many will tell you that the 110-S is the equal in power to the Saito 150____simply not so, I own them both. It is closer than you might expect but still a bad comparison.
It balances very well with the 110S or with the Saito125 (move the pack about four inches)
The Saito 150 is seven ounces heavier than the 110-S and that is out of reason.
It is also too wide and too long.
The Focus Sport is a very, very good A/C.
With a Saito 125 on 30% the vertical is unlimited (not high speed but unlimited). BUT, the 110-S puts out 800 to 1000 rpm more on the same fuel and prop. Max the prop for the 110-S and it is even more pronounced in performance difference.
With the Saito 125 you can fly it WOT throughout a sequence. With the 110-S roughly half throttle with whatever you wish to add____particularly vertical.
Note: Thankfully (personal opinion) this is NOT a 3D A/C but a Pattern practice plane.
< Message edited by onewasp -- 7/17/2008 5:39:51 PM >
The ground reached up and smote my airplane
(in reply to TomTreese)
       Post #: 288
RE: Focus Sport 110 YS Powered - 7/17/2008 8:43:49 PM
ROOKIE PILOT
Status: offline
Just finished my Focus Sport, Great flying plane.
Here are a few photos.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to onewasp)
       Post #: 289
RE: Focus Sport 110 YS Powered - 7/17/2008 9:04:06 PM
onewasp
Status: online
What is you all up dry weight?
(in reply to ROOKIE PILOT)
