RE: Focus Sport 110 YS Powered    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: Focus Sport 110 YS Powered Page: <<   < prev  9 10 11 12 13 14 15 [16] 17 18   next >   >>
Login
RE: Focus Sport 110 YS Powered - 4/1/2010 1:48 PM
crankpin
Score: 103
Last Login: 6/14/2013
Status: offline
Duplicate Post
Crank
< Message edited by crankpin -- 4/26/2010 1:28 PM >
Hide Signatures
(in reply to burtona)
       Post #: 376
RE: Focus Sport 110 YS Powered - 4/1/2010 1:52 PM
crankpin
Score: 103
Status: offline
Burtona is right. When I purchased mine, it came with the thrust plate, offset built in. It would not work for me, as I used the Hyde mount, too thick. Central will not help you here. They told me to call the distributor. They made me a new thrust plate, which gave me the correct spacing. Looks like I made two post's here. Must be gettin' old.
Crank
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 377
RE: Focus Sport 110 YS Powered - 4/5/2010 5:13 AM
hobbyaire
Score: 100
Last Login: 4/18/2012
Status: offline
I didn't use mine, you can have it.
Hide Signatures
(in reply to KLXMASTER14)
       Post #: 378
RE: Focus Sport 110 YS Powered - 4/25/2010 7:58 PM
darylm44
Score: 100
Last Login: 5/21/2013
Status: offline
Finally had time to work on the Focus again. Found that the JR 821 servos listed as a Good Choice in Post 84 are to deep to fit in the wings or the tail. Had to make spacers to fit under the servos in order to use them. Not a big deal but another step. My kit also came without a motor mount. I think they quit including it when most guys were using the Hyde Mount instead. Since I am building this on a budget I wanted to use a hard mount. I email Piedmont to find out which hard mount they had designed the plane around but have not heard back so I order a Glass Filled Nylon Mount from Dave Brown. Hope it fits? I see that Central Hobbies has listed the Focus Sport as out of stock now. I guess I got one of the last ones. I now have all the push rod parts so I should be able to finish this up in another week or so. Anxious to maiden this plane and see if I have done everything right.
Hide Signatures
(in reply to hobbyaire)
       Post #: 379
RE: Focus Sport 110 YS Powered - 4/25/2010 9:09 PM
kthmarks
Score: 100
Status: offline
quote:
ORIGINAL: darylm44
Finally had time to work on the Focus again. Found that the JR 821 servos listed as a Good Choice in Post 84 are to deep to fit in the wings or the tail. Had to make spacers to fit under the servos in order to use them.............
with regard to the servo's in the fuse for the elevators......I painted mine black and they blended well with the servos.
_____________________________
Keith Marks
AMA 49064
Hide Signatures
(in reply to darylm44)
       Post #: 380
RE: Focus Sport 110 YS Powered - 4/25/2010 9:57 PM
maynardrupp
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: darylm44
Hi Daryl..I looked at the Central Hobbies site and they only list the ARC, (almost ready to cover), version of the Focus Sport. I might be too late. I surely could cover the plane, but you don't save any money that way. I also read that the braces for the wing tube where it goes through the fuse sides are not installed on the ARC version.
Hide Signatures
       Post #: 381
RE: Focus Sport 110 YS Powered - 4/26/2010 5:25 AM
KLXMASTER14
Score: 105
Last Login: 6/17/2013
Status: offline
My Focus Sport is now finished, and has 6 flights on it. I have not flown an airplane that tracks as well as this one does since my days of flying real pattern planes back in the day. I set up the airplane using the recommended throws and CG, and it took one click of aileron trim to fly hands-off. All set up is done per the included instructions. Empty weight is 8-1/2 pounds. The OS .120 Surpass III is plenty of power, most flying occurs at 1/2 throttle. I am looking forward to putting many more hours on this airplane.
The attached pics show the engine mounting. I used the plastic mount from my Venus II. I shaved the thrust plate way down and glued it to the firewall. I also had to shim up my JR 821 servos in both the wins and the rear of the fuse. I ended up replacing the 821's in the fuse with Futaba 9650 digitals, and substituting 2-56 rods for the 4-40's to bring the CG to the prescribed dimension without adding weight. The 14 oz tank is located over the CG.
Another issue involved the rudder linkage. The rudder "horn" or screw hole is too far aft to put the clevis attach points over the hinge line. My solution was to machine some aluminum replacement attachment fittings as shown in the second photo. Happiness is having your own milling machine.
I really like this airplane, and I am glad that I did not procrastinate in ordering mine, I got wind that there might be no more available soon. That is a shame, I would consider buying another to keep as a back-up. This airplane is certainly a big step up in performance from my beloved Venus (RIP), and it seems to bridge a gap between entry level aircraft and the more costly 2 meter birds.
Click for fullsize
Click for fullsize
2012 NSRCA D7 Intermediate Champion
West Coast Regional Director- Classic Pattern Assn
Hide Signatures
(in reply to maynardrupp)
       Post #: 382
RE: Focus Sport 110 YS Powered - 4/27/2010 8:08 AM
hobbyaire
Score: 100
Status: offline
Wonderful Job - had the same issues with the elev servos & rudder linkage.
Just maidened mine last Mon (week ago) as electric conversion. Very pleased, albeit heavy overcast/poor visual (Mon) and too much wind this past Sun here in Austin.
Expect a much great flying with this fine bird. Too bad its going MD.
BTW, didnt use the special glow motor mount spacer, since with electric, the thrust angles can be done with the e motor mount.
Hide Signatures
       Post #: 383
RE: Focus Sport 110 YS Powered - 4/28/2010 10:52 AM
darylm44
Score: 100
Status: offline
I have a question regarding mounting the fuel tank. It was recommended to use a Perry pump if I was going to mount the fuel tank over the CG. With my magnum 120 there is little room above the inverted engine and the carb is in the way if I try to mount it below the engine center line. How much offset do you really need from the engine centerline. Perry calls for an inch or so. I might be able to modify the pump bracket and get it behind the engine with a 1/2 inch offset from the engine centerline. Worth a try? This is my first try to use a Perry pump.
I could mount the fuel tank over the CG and try it without the pump or I could move the tank forward behind the firewall. What are my best options. Any ideas or advice will be appreciated.
Hide Signatures
       Post #: 384
RE: Focus Sport 110 YS Powered - 4/28/2010 4:15 PM
cmoulder
Score: 106
Last Login: 6/18/2013
Status: offline
Perry instruction sheet says "about 1-1/2 inches above the crankshaft centerline", so if you include the crankcase itself you've already got a little to work with.
My suggestion is to mount it as high as you can (opposite the carb side) and give it a shot. Remember that the pump is somewhat adjustable for flow. Also you don't want to use a super-stiff engine mount. The GF plastic mount used by klxmaster above is good, and a Hyde mount would give plenty of mechanical action for the oscillating pump.
Once you get it up and running, you will not regret putting the fuel tank on CG. Putting it in the nose will lead to constant fuel draw issues and elevator trim changes. On CG, the engine will run well with the airplane in any attitude.
< Message edited by cmoulder -- 4/28/2010 4:49 PM >
Bob
Hide Signatures
       Post #: 385
RE: Focus Sport 110 YS Powered - 4/29/2010 2:25 AM
maynardrupp
Score: 100
Status: offline
I called Central Hobbies yesterday and was told that the YS 115 might be available by September or October. I then decided to order a Focus Sport and power it with an OS 120AX. Next I was told that the Focus Sport is no longer being produced. They do have a few ARC planes in stock though. Well, I can cover as well or better than they can but I am not sure I want to get involved with a plane that has no repair parts available and they don't supply full size plans so I can make what I need. What a dilema.
Hide Signatures
(in reply to cmoulder)
       Post #: 386
RE: Focus Sport 110 YS Powered - 4/29/2010 2:40 AM
kthmarks
Score: 100
Status: offline
quote:
ORIGINAL: maynardrupp
I've been flying mine for a couple of seasons now......I have not required any replacement parts....if you're concerned, see what they'll charge for an extra cowl and wheel pants....for grins. I have a Saito 120 in mine...it flies great! The 120ax will be plenty.
Keith Marks
AMA 49064
Hide Signatures
       Post #: 387
RE: Focus Sport 110 YS Powered - 4/29/2010 2:50 AM
cmoulder
Score: 106
Status: offline
Did they mention any plans for another model to replace it in the 1.10-sized pattern range?
Seems they would want to have an updated design in stock when the YS 1.15's finally arrive.
I keep hoping that any day now Great Planes will come out with an up-sized Sequence. It is merely a hope, not based upon anything I've seen or heard.
Bob
Hide Signatures
       Post #: 388
RE: Focus Sport 110 YS Powered - 4/29/2010 2:54 AM
maynardrupp
Score: 100
Status: offline
quote:
ORIGINAL: cmoulder
Nope, the lady I talked to knew of nothing in the works.
Hide Signatures
       Post #: 389
RE: Focus Sport 110 YS Powered - 6/29/2010 9:05 PM
darylm44
Score: 100
Status: offline
Got back after a 3 week trip and finished the Focus Sport. I have flown it 3 days last week and all I can say is wow!! It has unlimited vertical with the Magnum 120 and flys strait as an arrow. I had a little bit of a learning curve with the Perry pump. I hooked up the line from the muffler to the tank to pressurize it. Wrong, I had fuel spitting out of the carb all over the plane. Disconnected the pressure line from the muffler and adjusted the flow down wards and it is working fine now.
It is a shame they are not making this plane any longer. I would certainly recommend it!!!!
Hide Signatures
       Post #: 390
RE: Focus Sport 110 YS Powered - 6/30/2010 5:35 AM
maynardrupp
Score: 100
Status: offline
Yup Daryl.. It is too bad that they quit making it. I am glad to hear that yours is now finished. I have about 2 hours work left to have my new Venus II ready to fly; some radio programing and screw the canopy on. It doesn't look like this is the year for our Alaska trip. I will be coming to visit you one of these years though.
< Message edited by maynardrupp -- 6/30/2010 3:13 PM >
Hide Signatures
       Post #: 391
RE: Focus Sport 110 YS Powered - 6/30/2010 7:30 AM
KLXMASTER14
Score: 105
Status: offline
quote:
ORIGINAL: darylm44
I am glad to see that the Perry pump worked out for you. I would presume that it is the "VP20" pump. I see that you discovered that you do not use muffler pressure with a pumped engine. Some folks still argue about this. Enjoy your awesome bird, I have 7 hours on mine now, and it just keeps getting better.
-Robert
Hide Signatures
       Post #: 392
RE: Focus Sport 110 YS Powered - 7/2/2010 7:04 AM
darylm44
Score: 100
Status: offline
I have about 2 hrs on mine now and I agree it just keeps getting better. Knife edge is really easy and I have just started working on 4 point rolls.
Hide Signatures
       Post #: 393
RE: Focus Sport 110 YS Powered - 7/2/2010 3:39 PM
Mastertech
Score: 108
Status: offline
I talked to Steve Wall, replacement parts are going to be available for a good while.
I just ordered a part for a Focus 1 they had in stock, the 1 hasn't been made in years and the part is different than the 2.
Be a kid forever, fly models.
Hide Signatures
       Post #: 394
RE: Focus Sport 110 YS Powered - 7/2/2010 6:35 PM
KLXMASTER14
Score: 105
Status: offline
That's great news!
Hide Signatures
(in reply to Mastertech)
       Post #: 395
RE: Focus Sport 110 YS Powered - 7/4/2010 10:35 PM
darylm44
Score: 100
Status: offline
Have you seen the Phoenix 7 http://www.horizonhobby.com/Products/Default.aspx?ProdID=HAN4755#quickSpecs
What do you think better than the Venus II???
Hide Signatures
       Post #: 396
RE: Focus Sport 110 YS Powered - 7/4/2010 11:12 PM
Diver09
Score: 100
Last Login: 6/8/2013
Status: offline
darylm44, The Phoenix 7 can't really be compared to the Venus II. Venus II is more of a modern design that can fly competitively in the lower to middle classes. The Phoenix 7 on the other hand would have been awesome many years ago but will not be able to keep with the modern sequences today.
-Chris
-Chris
Hide Signatures
       Post #: 397
RE: Focus Sport 110 YS Powered - 7/5/2010 12:32 AM
KLXMASTER14
Score: 105
Status: offline
quote:
ORIGINAL: Diver09
-Chris
That is correct, it was designed for a style of pattern that is not flown today, save for SPA/BPA/CPA events. However, that should not dissuade you from experiencing the flavor of ballistic style pattern flying. There is nothing like the arrow like tracking of an old school pattern plane up on the pipe with the gear up blazing across the sky!
Hide Signatures
(in reply to Diver09)
       Post #: 398
RE: Focus Sport 110 YS Powered - 7/17/2010 2:47 AM
darylm44
Score: 100
Status: offline
A couple of weeks ago I had a senior moment and forgot to connect the ailerons up to the Rx while getting the plane ready to fly. Then I compounded the error by not checking the controls before trying to take off. I know stupid, stupid, stupid. The plane immediately started to roll to the left and when it did not correct with right aileron input I shut it down as I was just barely off the ground and had a lot of strip ahead of me. Scuffed up the left wingtip and bent the landing gear. Also broke one of the wing adjustor's and tore a hole in the wing where the right wing screw goes through the wing. Flattened the right leading edge near the wingtip when I hit one of the pilot stations.
Got a new wing adjuster and fixed the rest of the damage. It could have been a lot worse and I probably won't do that again in the near future. If I had just checked the control surfaces I would have caught this before any damage was done. Hope to remaiden it again this weekend. I have checked all the alignments, etc. Sure hope it flys as perfectly as it did before.
Hide Signatures
       Post #: 399
RE: Focus Sport 110 YS Powered - 7/20/2010 12:26 AM
maynardrupp
Score: 100
Status: offline
Ouch Daryl...That is one that I haven't done yet. I could though. My new Venus II has the tank up against the firewall. I flew for 10 minutes and noticed that I needed some down trim. I got it re- trimmed and landed, fueled up and went for takeoff again. I really scared myself as it took full up to lift off and half up to fly level. Needless to say I re-trimmed and pressed on. That is the first time that I have ever noticed a trim change from full to low fuel. The tank is only 14oz. I do love the Venus and really like the OS 120AX. That engine runs very smooth with tons of power, and the throttle response is awesome.
Hide Signatures
       Post #: 400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
