RE: Focus Sport 110 YS Powered
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: Focus Sport 110 YS Powered Page: <<   < prev  4 5 6 7 8 [9] 10 11 12 13   next >   >>
Login
RE: Focus Sport 110 YS Powered - 1/16/2008 3:45:53 PM
stek79
Status: offline
Great info Troy, thanks for sharing your thoughts!
I can't wait the trimming school.
(in reply to Troy Newman)
       Post #: 201
RE: Focus Sport 110 YS Powered - 1/16/2008 7:24:21 PM
JPal101
Status: offline
Thank you Troy, I will do it as you said and make my own.
_____________________________
JPal101
       Post #: 202
RE: Focus Sport 110 YS Powered - 1/29/2008 3:31:59 AM
JPal101
Status: offline
Troy, earlier in this thread you said that you would be putting this build into a word document. Are there any plans to do that? and if so where can I down load it.
JPal101
(in reply to JPal101)
       Post #: 203
RE: Focus Sport 110 YS Powered - 2/18/2008 1:11:03 AM
JPal101
Status: offline
Hi Troy
JPal101
       Post #: 204
RE: Focus Sport 110 YS Powered - 2/18/2008 1:17:02 AM
JPal101
Status: offline
Lets try that again,
HI Troy
Question about incidence, I glued the stab without checking the incedence. I did check it after eveything was dry and came out 1/4 degree positive at the root and it increases as I go out to the tip of the stab. So, I set the wing incedence to 3/4 degree positive at the root to make up for the stab. Will this adversely affect the performance? And if so, to what degree (no pun intended). By the way I used one of those laser pointer type meters.
JPal101
       Post #: 205
RE: Focus Sport 110 YS Powered - 2/18/2008 5:41:48 PM
Troy Newman
Status: offline
Well it will affect it...for sure....But the question is how much. Likely you will end up with a push to the belly in uplines. And your elevator trim will not track with the stabs...This will make for a speed sensative elevator.
Can it be overcome with some creative mixing...probably yes, and will it be bad enough to really mess things up...probably not...but it will not be as good as doing it right the first time.
You can fly it and trim it and we'll see how thing flush out...if its bad then cut it out and do it again...but I would not do that today....Fly it and trim it out first. You might be better off with a slightly low wing incidence and just taking the elevator trim that ends up there....
But fly it first and see what happens.
Troy
       Post #: 206
RE: Focus Sport 110 YS Powered - 2/19/2008 2:02:14 AM
JPal101
Status: offline
Troy
I spoke with Dave at Piedmont today, he basically said the same thing you said about flying it first then see what happends. I did discuss the increasing incidence of the stab. He said to warm it up with a heat gun and gently twist it until the incedence is straight from the tip to the root. While it is not correct to have that 1/4 degree positive in the stab he felt it would not affect the performance a great deal. He also said as you to fly it and if it is a problem to cut it out and reset it.
JPal101
       Post #: 207
RE: Focus Sport 110 YS Powered - 3/1/2008 3:46:13 PM
JPal101
Status: offline
Hi Troy
I cant find where you drill the holes at the hard points in the wing panels. The instructions say to use a #43 drill, tap the hole with a 4-40 tap the secure the wing with a 4-40X 3/4 screw. Is this how you did it? or is there a more secure way.
JPal101
       Post #: 208
RE: Focus Sport 110 YS Powered - 3/1/2008 6:30:17 PM
onewasp
Status: offline
Hold you wing panel so that it reflects the light.
Roughly 8" out from the root on the black and yellow striping you will see the outline of the hard point.
There are other ways but they involve a lot more work and will accomplish nothing other than to hide the 4-40 screw heads.
The method used on the Focus Sport is well known and well tested.
The ground reached up and smote my airplane
       Post #: 209
RE: Focus Sport 110 YS Powered - 3/1/2008 8:18:44 PM
JPal101
Status: offline
Hi Troy
What I actually meant was that I cant find where you WROTE about drilling the holes in the hard points. What I am concerned about is, how well does the screw fasten and hold the wing. Did you just drill the hole and insert the 4-40 and tighten it down or did you do anything else to insure that it would not back out during flight.
JPal101
(in reply to onewasp)
       Post #: 210
RE: Focus Sport 110 YS Powered - 3/2/2008 2:08:28 AM
Troy Newman
Status: offline
drill and tap the hardwood block that is in the wing. Another option is to epoxy a short section of dowel into the wing tube and drill and tap that hardwood block for the 4-40 bolt.
Tap, then Thin CA, let it soak in and cure. Then tap again. Then CA...and so on the threads will become very strong...
There is nearly zero force needed to keep the wings on the model. The screw just keeps the wing from sliding off the tube....
Troy Newman
       Post #: 211
RE: Focus Sport 110 YS Powered - 3/2/2008 2:53:42 AM
JPal101
Status: offline
Thank you Troy for the info
JPal101
       Post #: 212
RE: Focus Sport 110 YS Powered - 3/15/2008 7:40:37 PM
rc168
Status: offline
Hi Troy,
I don't know about yours, but it seems to me that there is something wrong with my firewall. When I look at my Focus Sport, I am wondering where is the right thrust.
Click to see fullsize image.
Click for fullsize
       Post #: 213
RE: Focus Sport 110 YS Powered - 3/15/2008 9:31:35 PM
Troy Newman
Status: offline
Well The firewall has no thrust in right or down thrust. The angled block in the photo behind you engine mount is what gives the thrust offset.
Does you engine align with the nose of the cowling meaning a equally spaced gap when the cowl is installed. If it does then you thrust line is pretty close to right.
I have not made any changes to the thrustline of my model.
So if it aligns with the cowl you are correct. In your photo to me it looks like the engine has right thrust in it...The firewall does not have any offset its all created by the spacer block.
Troy Newman
< Message edited by Troy Newman -- 3/15/2008 9:32:02 PM >
(in reply to rc168)
       Post #: 214
RE: Focus Sport 110 YS Powered - 3/15/2008 10:06:00 PM
elan120
Status: offline
Troy,
Sorry to jump in here, but I see the picture a little differently, and would like to get your input. Please feel free to correct me if you have different view.
In this case, it appears the photo shows the firewall instead of at zero degree, it has some degree of left thrust built-in already, which cancels out the right thrust from the angled engine block, as a result, the engine as shown in the picture, actually has zero degree of right thrust. Meanwhile, since the firewall already has some left thrust built-in, I think it will make the cowl angled to the left as well, so having the equal space between spinner back plate and cowl will only make the trust line at zero degree, right? Could this be a manufacturing defect?
Kevin
< Message edited by elan120 -- 3/15/2008 10:16:02 PM >
