RE: What do you think about JETLEGEND L39?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: What do you think about JETLEGEND L39?
Page: <<   < prev  26 27 [28] 29 30 31 32 33 34 35   next >   >>
Login
RE: What do you think about JETLEGEND L39? - 3/28/2008 8:05:20 PM
dbarrym
Status: offline
quote:
ORIGINAL: yeahbaby
cut a hole in the door to clear the servo screw and then cover it with a blister.
you can call it an ECM sensor or cows tiits (as they are often referred to on the Hornoooot)
you know my philosophy, it's a ............for criist sake
Yep....I think we ALL know your philosophy...kind of "Chuck Yeager meets Larry the Cable Guy"... you bozo!
Actually the entire width of the arm is a problem, not just the nut holding the ball link.
Barry
(in reply to yeahbaby)
       Post #: 676
RE: What do you think about JETLEGEND L39? - 3/28/2008 8:07:42 PM
Doug Cronkhite
Status: offline
You're such a Marine Buck (I mean that in a good way btw)
Functionality First!!
_____________________________
Doug Cronkhite
       Post #: 677
RE: What do you think about JETLEGEND L39? - 3/28/2008 9:12:48 PM
jetjohn
Status: offline
As shown on Video link on post 664 no problem with servo arm on door.
Servo fitted to upper surface of mount, standard JR591 with standard arm.
Works perfectly.
All the best,
John C
Andreas,
Looks like a blow out again this weekend.
(in reply to Doug Cronkhite)
       Post #: 678
RE: What do you think about JETLEGEND L39? - 3/28/2008 10:22:40 PM
dbarrym
Status: offline
Guess I'll need to get a low profile servo, because my setup is not any different than yours, John. (Nice job on the lights, BTW). I doubt my nose gear or bulkheads are any different from the other L39's out there, so it must be the deck height of the servo.
Here's a shot of the door closed on the servo and the servo install. It is a JR Sport ST126MG...need to go to the local hobby shop and sort through their stock of servos with a pair of calipers....
Barry
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to jetjohn)
       Post #: 679
RE: What do you think about JETLEGEND L39? - 3/28/2008 11:03:35 PM
ash 26
Status: offline
Hi John
I got myself a few springs to experiment with
your lights lock very well where did you get yours from?
like you said it looks like a right blow out again this week end ,hopefully we are going to get some good weather for the rest of the season
any one any experience with a JL T45?
Have a nice day
Andreas
       Post #: 680
RE: What do you think about JETLEGEND L39? - 3/28/2008 11:53:18 PM
yeahbaby
Status: offline
Hey F' that bro', it looks like a plane in the sky right? oh no I see a hole in the nose gear door!! harumph harumph harumph geez the nerve of that guy. burn 'em he's a witch!!! let's see if he floats!!!
heck poop can the nut on top and use a z-bend on the steering rod......then cut a hole in the door and some cowz tiitz
quote:
ORIGINAL: dbarrym
Barry
(in reply to dbarrym)
       Post #: 681
RE: What do you think about JETLEGEND L39? - 3/29/2008 2:04:10 AM
lov2flyrc
Status: offline
Barry... two options here....
1) loose the servo grommets, will most likely drop the servo enough to clear the door.
2) use an aluminum arm, thread the bolt in and cut flush with the top side of the arm (then thread lock!)
I'll have to go back and look at the pics I took of the one I built, don't remember this being an issue at all
T
Owner/President: Dreamworks Model Products LLC
www.dreamworksrc.com 386-852-4793
       Post #: 682
RE: What do you think about JETLEGEND L39? - 3/29/2008 2:03:49 PM
jetjohn
Status: offline
Barry,
Just put the servo on the other side of the mounting plate. Use a clevis it all lines up perfectly.
Regards,
John C
Andreas,
Light kit from Maplins with a few home mods.
Put it on earlier post.
All the best,
John c
Click for fullsize
Click for fullsize
(in reply to lov2flyrc)
       Post #: 683
RE: What do you think about JETLEGEND L39? - 3/29/2008 6:22:13 PM
snobird
Status: offline
Ok, I'm getting a number of CG locations. Can we settle on one solid lacation before I fly ...........
       Post #: 684
RE: What do you think about JETLEGEND L39? - 3/29/2008 10:32:52 PM
lov2flyrc
Status: offline
Barry...here is how I did it...
Click for fullsize
(in reply to snobird)
       Post #: 685
RE: What do you think about JETLEGEND L39? - 3/30/2008 8:26:40 PM
mustangjb
Status: offline
Hi All,
I try to find the best place to put my aerial.....
Can you post some pictures about your aerial fixation on the plane.
I have seen JetJohn have put just at the back of the canopy in the center of the fuselage, how do you have do it?
       Post #: 686
RE: What do you think about JETLEGEND L39? - 3/31/2008 1:24:10 AM
WHMC
Status: offline
Whats the bellmouth on inner pipe for? WHMC
(in reply to mustangjb)
       Post #: 687
RE: What do you think about JETLEGEND L39? - 3/31/2008 6:42:24 AM
mustangjb
Status: offline
Me I have removed her, like this the turbine housing fit perfectly
(in reply to WHMC)
       Post #: 688
RE: What do you think about JETLEGEND L39? - 3/31/2008 8:28:49 AM
aerialcameraman
Status: offline
Sandor
I have a new ECU for my Nexus but I need the Autostart parameters for this turbine, Can't get any replies from Simjet, are they still in business?
Denny
dennyrowland@mac.com
(in reply to digitech)
       Post #: 689
RE: What do you think about JETLEGEND L39? - 3/31/2008 4:49:45 PM
F106A
S
