RE: What do you think about JETLEGEND L39?
Tower Hobbies
Logged in as Guest
Users viewing this topic: ash 26
  Printable Version
Fei Bao 1/6 Scale F-9F Panther - ARF
Seller:  rcjetmodels
Details:   $1,800.00   |  8/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: What do you think about JETLEGEND L39?
Page: <<   < prev  28 29 [30] 31 32 33 34 35 36 37   next >   >>
Login
RE: What do you think about JETLEGEND L39? - 4/29/2008 7:18:23 PM
jetjohn
Status: online
Hi Jeremy,
Attached shot shows tanks,header & air cylinder for mains & doors.
Hope this helps,
Regards,
John C
Click to see fullsize image.
Click for fullsize
(in reply to Jeremy_D)
       Post #: 726
RE: What do you think about JETLEGEND L39? - 4/29/2008 7:50:49 PM
dbarrym
Status: offline
quote:
ORIGINAL: Jeremy_D
Can you guys post some pics of where you have put your header tanks.
Also how many air tanks are you using, I was thinking of using two 350cc air tanks for the mains and doors and a 300cc tank for the brakes. Will this be enough?
THanks guys
No access for pics till later...but visualize this.. for UAT mount, I made a small inverted "V" shaped tray from 1/8" lite ply that is epoxied in the rear half of the fuse, just behind the seam/flange, and ahead of the main tank tray and to the side of the airbrake hinge. The UAT is Velcro-strapped to this tray.
I am using both of the supplied air tanks (look like "medium size" Robarts to me) T-ed together for brakes, mounted below the radio tray in the nose (way overkill, one is fine). I have two XL Robart air tanks, mounted on the fuse sides with Velcro, just behind the engine hatch opening and just above the engine mounting rails. These are T-ed together to provide high pressure air (not volume) for the retracts and doors. From 105psi, I can get 5 full cycles before the pressure drops to 80 psi, at which point the gear gets too s-l-o-w on the up cycle. I am using BVM high flow air valves as the stock valves leaked (and those mains are HEAVY).
Pics later.
Barry
       Post #: 727
RE: What do you think about JETLEGEND L39? - 4/29/2008 10:32:58 PM
Jeremy_D
Status: online
Thats excellent guys, thanks.
_____________________________
Aussie Jet Legend Rep
www.aussiejet.com
(in reply to dbarrym)
       Post #: 728
RE: What do you think about JETLEGEND L39? - 5/4/2008 6:35:38 PM
mustangjb
Status: offline
Hi all,
Maiden flight this WE in Italy Eolo Jet meeting.
The plane is prefect with the CG or JL, just a little bit slow with the P-120 but enough to take off.
I have doing more than 10 flights, but the front wheel strut have broken during landing, so check this point with yours.
       Post #: 729
RE: What do you think about JETLEGEND L39? - 5/4/2008 8:11:25 PM
cairoman
Status: offline
Gentlemen,
I don't wish to disapoint any of you, but please be warned about the strength of the wing carbon (supposedly) tubes!!! they are a joke, so you really need to strengthen them (carbon rod inserts probably) before you experience what happened to me: The front left carbon tube was cut like a cucumber for no apparent reason, two minutes after take-off and the whole wing parted the airframe in two seconds after that leading to an uncontrolled spin and the inevitable crash and burn thereafter. Total equipment lost worth €6000/U$9000....not to mention workmanship from the Guru himself..Mr. Spiderjets!!!! I only had three flights on it and not a scratch before that...BTW not even a warning!!!! and no flutter!!!
I have emailed Yang at JL informing him about the incident, but as you all already know.....absolute silence from him!!!
Chris
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by cairoman -- 5/6/2008 8:56:44 PM >
IJMC-Cyprus, JET-TRONICS' REP
WREN'S REP in Cyprus
(in reply to mustangjb)
       Post #: 730
RE: What do you think about JETLEGEND L39? - 5/4/2008 11:03:11 PM
lookilook
Status: offline
OH NOOOOOOOOOOOOOOOOOOOOOO! CHRIS.........ITS SO UNFAIR LOOSING A PLANE FROM BAD MANUFACTURING......IT WAS AN AMAZING MODEL WELL BUILT UP AND GREAT COLOURING.....PITY PITY PITY.......DONT THEY REFUND WHEN ITS THEIR FAULT WHEN SOMETHING LIKE THIS HAPPENS??I HOPE THEY DO CAUSE ITS A GREAT MODEL OR AT LEAST OFFER YOU SOMETHING ELSE IN EXCHANGE!!!
my wife wants the world and i give her universe
that's how i keep flying,its tough out there!
(in reply to cairoman)
       Post #: 731
RE: What do you think about JETLEGEND L39? - 5/5/2008 6:33:10 PM
SpiderJets
Status: offline
Christos,
I feel very very sorry for your loss of this great L-39. The photo was a big shock to me.
I really tried hard to spot the remnants of Batman and his girlfriend to identify this really used to be "my" plane, but in vain. Godspeed them too.
With all my sympathy for your loss,
Nicolas.
PS. ..."Guru"... ?????
(in reply to lookilook)
       Post #: 732
RE: What do you think about JETLEGEND L39? - 5/5/2008 7:09:20 PM
cairoman
Status: offline
Nico,
Your building skills and workmanship is unsurpassed by anyone's I know!!!
Yeah, the strange thing is that no one has commented yet. This is a very serious flaw in the L39 kit and let me tell you...an accident of this type is bound to take place somewhere in the world on a JL L39 pretty soon!!!!
Chris
< Message edited by cairoman -- 5/5/2008 7:15:56 PM >
(in reply to SpiderJets)
       Post #: 733
RE: What do you think about JETLEGEND L39? - 5/5/2008 7:15:29 PM
dbarrym
Status: offline
I am wondering if the aluminum clamps may have cut into the CF wing tubes over time and essentially created a stress riser. I am on business travel now but plan to take a close look at mine on return home.
The L39 can handle a bit of weight, it might make sense to insert an aluminum or steel rod into the tubes with Hysol so that it goes 4" or so into the wing past the root. That at least would provide a more graceful failure than a pure CF rod.
I had wondered about the small diameter of the joiners, there's a LOT of load on them, especially on hard landings.
Barry
       Post #: 734
RE: What do you think about JETLEGEND L39? - 5/5/2008 7:40:38 PM
SpiderJets
Status: offline
Chris,
I'd like to see that wing tube when I come to meet with you in Cyprus next week. It's hard for me to see on the photos how and where the failure took place exactly.
What Barry writes, makes sense. Having two different materials in composite for the wing tubes is a good cure for the eventual material weakness of the other. CF tubes have a weak point and that is eventual splitting...
Nicolas.
       Post #: 735
RE: What do you think about JETLEGEND L39? - 5/5/2008 8:03:33 PM
cairoman
Status: offline
I have it in my workshop. We'll do a more thorough post mortem when you arrive next week.
Chris
       Post #: 736
RE: What do you think about JETLEGEND L39? - 5/5/2008 8:18:59 PM
jetjohn
Status: online
Christos,
Sorry for your loss.
Thank you for the heads up on this issue.
I have just taken a look at the wing tubes on my L39 & they appear to be constructed from three tubes fitted one inside the other.
There are some slight marks on the tubes were the clamps go but nothing to indicate a fracture.
However scince there is an 8 mm hole in the centre of the tubes I think it will be wise to fit an 8mm alloy bar inside, if not a carbon rod.
Once again sorry for the loss of your plane. Especially scince this was the first aircraft/L39 on this forum that helped so many others with construction hints & tips.
All the best,
John C
       Post #: 737
RE: What do you think about JETLEGEND L39? - 5/6/2008 9:06:20 AM
aerialcameraman
Status: offline
IMPORTANT Safety Bulletin JL-L39
I would advise all JL-L39 owners to read this carefully, I was a witness to the total demise of the Christos/Nicholas L39. The model took-off in a normal manor and carried out several high speed level circuits when the right wing came off. I immediately recovered the wing and discovered that the initial component failure was the front carbon rod. This had snapped off next to the alum. clamp. To make a conclusive analysis as to the exact cause one needs to understand certain aircraft design principals. The loads incurred on a wing when subjected to + and - G forces act through the upper and lower surface skin structure and are then focussed into the fus. On full size aircraft the wing is usually attached in three primary positions which are at the main spar - top and bottom close to the wings surface and at the back of the wing to anchor the wing against for and aft movements. The rear carbon spar mount on the JL-L39 is fine for that purpose, but the front one is one of the worst design faults that I have ever seen. 95% of the wing loading is focussed at this point and it is totally unsafe and displays a complete lack of aircraft engineer
