RE: What do you think about JETLEGEND L39?
Tower Hobbies
Logged in as Guest
  Printable Version
JMP Firebird ***Will Ship*** - RTF
Seller:  pilott28
Details:   $7,000.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: What do you think about JETLEGEND L39?
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: What do you think about JETLEGEND L39? - 10/12/2007 9:25:00 AM
ZivBit
Status: offline
Hi Nicolas
Great job so far, I enjoy reading it.
Hurry back to show some more photos...
Have a good trip.
Zivo
(in reply to SpiderJets)
       Post #: 101
RE: What do you think about JETLEGEND L39? - 10/12/2007 1:55:09 PM
jetjohn
Status: offline
Nicolas,
As per Zivo, excellent thread, keep it comming.
John C
(in reply to ZivBit)
       Post #: 102
RE: What do you think about JETLEGEND L39? - 10/12/2007 5:04:16 PM
SpiderJets
Status: offline
Thanks. Just started reading the Tom Pierce website, it's a gold mine of good information on finishing techniques for a paint rookie like me (read : I hate painting ).
Let's pray I can drag myself back to the workshop after a succesful maiden flight, and get that part done too... !
(in reply to jetjohn)
       Post #: 103
RE: What do you think about JETLEGEND L39? - 10/17/2007 12:21:38 AM
WHMC
Status: offline
I too have a JL L-39 basically ready to fly. My problem is also the rudder slop. I am thinking of relocating servo higher in the fin then use a conventional pushrod/horn system. Have you any different ideas. Wayne
       Post #: 104
RE: What do you think about JETLEGEND L39? - 10/17/2007 5:52:26 AM
Kmarks
Status: offline
Hello WHMC,
I received my JL L-39 the other day and have been hard at work. I too found the tail set up less than perfact. However upon your suggestion of conventional placement of servo with horns and linkage to the rudder, if you candle the skin, (to see where the ribs are) you will see the servo needs to be almost in the middle of the tail, and at that point the thickness (cord) of the tail is not thick enough to fit a good quality servo. So back to JL set up. Here is what I did however.
1. I cut away a square of fiberglass material behind the provided circular cut a way. I found that where JL wanted you to set up the steel pin to fit into the track was in the middle of the length of the aluminum channel grove. By cutting away more fiberglass material allowed me to move the "pin" backward and thus having more leverage on the tail. I also found that the pin provided was garbage and I took a spare bolt with an aluminum JR horn and fastened my own stronger set up.
2. I also placed carbon fiber on all area's where servos are to be mounted, with the tail a must. The hatch also was not rigid, and got some stregthening with carbon fiber.
The glue is drying on the tail as I type, so I will follow up with the results.
Kevin Marks
(in reply to WHMC)
       Post #: 105
RE: What do you think about JETLEGEND L39? - 10/17/2007 7:32:57 AM
ZivBit
Status: offline
Hi Kevin,
Thanks for the info.
Can you post some pics as I am about to begin building mine.?
Thanks!
Zivo
(in reply to Kmarks)
       Post #: 106
RE: What do you think about JETLEGEND L39? - 10/19/2007 8:47:08 PM
jetjohn
Status: offline
Zivo,WHMC & Kevin,
What do you think about the quality of the kit.
Is it good value for money.
Also what turbine will you be using?
All the best,
John C
p.s. Do you fly from tarmac or grass?
       Post #: 107
RE: What do you think about JETLEGEND L39? - 10/19/2007 9:06:50 PM
jetjohn
Status: offline
Tailhook,
Any news on how you achieved the weathered look on your JL39.
Regards,
John C
       Post #: 108
RE: What do you think about JETLEGEND L39? - 10/19/2007 11:43:15 PM
Kmarks
Status: offline
Hi John,
I just posted to your other blog, I guess I will post here to. But first I will answer your question about quality etc.
I read the other post on quality, and I bought the kit. I have bought 3 other Sky Master Kits so I have some experience to compare it too. Here is my opinion:
I think the engineering is great. Very well thought out and design is a winner. The parts fit almost perfect some need a little sanding but that is expected. Gear doors are double ply and give that thickness appeal that looks great. All gear doors fit very well in the pocket, and after figuring out the geometry of where the hinges go and how much flange needs to be trimmed away for proper movement, the doors work great. The hatch latch for the canopy seems a bit weak, and I will carbon fiber the back plate of the canopy for strength. Also as I learned from another kit, I will never attach a servo to the balsa under side of a wing or elevator. This kit has Flaps, elevator, and tail install directly on these balsa surfaces. So once again I got out the resin and Carbon fiber cloth and strengthened the undersides. I also CF the spine and front portion of where the air break mechanism goes. The Fuse seems rigid, but I am sure once I get the turbine, goodies and fuel in the bird, I think the fuse will need some carbon fiber stringers for that added strength. As noted, I build a jet to fly, not to crash. However the little extra weight added for the benefit, in my mind is well worth it.
So now onto the landing gear, well I am used to using beefy, strong, high quality gear which in my opinion is one of the most important aspects of jets. The stock gear as supplied by JL is IMOP the weakest gear possible that may be OK for this size jet. The struts and wheels look good. I decided to use these first instead of pimping this ride out before seeing if I will like the flight characteristics. If everything goes great and I think the gear sucks I'll than replace with some better. I'll know more in the next week.
Good luck in your decision,
Kevin Marks
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 109
RE: What do you think about JETLEGEND L39? - 10/20/2007 6:58:39 PM
SpiderJets
Status: offline
OK, I'm back on track.
I have redone the main RX board completely, for use with flat Lipo's, gyros and Weatronic 10-20R RX.
For the JetCAT ECU and main batt for the Wea, I've installed DN-Power 4100 MAh / 20C / 2-cells.
The Wea back-up batt is a DN-Power 1350 MAh / 20C / 2-cells.
All cables and wires are lead UNDER the main board, which is also removable with 4 bolts.
The ECU and fuel system will be a separate board aft the main board.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 110
RE: What do you think about JETLEGEND L39? - 10/20/2007 7:02:46 PM
SpiderJets
Status: offline
Today, the JetCAT P-160 found his new home in the SJ bypass as well.
Tomorrow, the five Futaba BLS 451 servos will be installed. These new brushless servos run really very smooth and have a remarkable torque...
Click for fullsize
       Post #: 111
RE: What do you think about JETLEGEND L39? - 10/20/2007 7:07:39 PM
SpiderJets
Status: offline
Anyone else having had problems with the wheel brakes ?...
Mine still brake when the air pressure has been released... ?!?
       Post #: 112
RE: What do you think about JETLEGEND L39? - 10/20/2007 8:10:21 PM
cairoman
Status: offline
Very neat installation Nico.
Chris
_____________________________
IJMC-Cyprus, JET-TRONICS' REP
WREN'S REP in Cyprus
