RE: What do you think about JETLEGEND L39?
Tower Hobbies
Logged in as Guest
Users viewing this topic: asw_35
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: What do you think about JETLEGEND L39?
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: What do you think about JETLEGEND L39? - 11/2/2007 12:17:31 PM
ZivBit
Status: offline
Hi MOnica,
I cant see the cockpit and pilots in your website.
Can you quote for cockpit + 2 pilots set for the L-39?
Zivo
(in reply to FlyingboyD)
       Post #: 176
RE: What do you think about JETLEGEND L39? - 11/2/2007 8:19:22 PM
SpiderJets
Status: online
My throw settings, JetLegend L-39
All throws are measured at the surfaces at the closest side to the fuselage.
Elevator : 35 mm UP/DOWN and -20% exponential
Ailerons : 25 mm UP/DOWN and -15% exponential
Rudder : 45 mm LEFT/RIGHT
Nose wheel : approx -35% exponential, with very short turning circle at max deflection and very soft and precise correction in the center range of the rudder stick.
Flaps : 0 mm horizontal, 72 mm down at max flap
Throttle : the P-160 has most power in the top range, I had too little 'feel' in the lower throttle positions (bottom 3/4), so I added a lot of exponential to spread the top RPM range over more stick movement and for having steeper RPM increase from idle position to 3/4 position.
My CG = exactly as per the plan, the plane hangs perfectly flat on these points (w/ only BVM UAT filled with fuel).
Had to add 796 grams in the tip of the nose to achieve this point !
Not sure yet if this is the best CG, hence : to be confirmed.
PS. 1 inch = 25,4 mm
Nicolas.
< Message edited by SpiderJets -- 11/2/2007 8:59:38 PM >
(in reply to ZivBit)
       Post #: 177
RE: What do you think about JETLEGEND L39? - 11/2/2007 8:22:24 PM
SpiderJets
Status: online
One more....
Click to see fullsize image.
Click for fullsize
(in reply to SpiderJets)
       Post #: 178
RE: What do you think about JETLEGEND L39? - 11/2/2007 8:57:53 PM
SpiderJets
Status: online
One more...
(Slow fly-by with fully opened belly air spoiler, 30% flaps, and gear down.)
Click for fullsize
       Post #: 179
RE: What do you think about JETLEGEND L39? - 11/2/2007 9:31:57 PM
Inconel
Status: offline
Hello Nicolas,
what is the weight without fuel of your L39 ?
regards
Jörg
_____________________________
http://www.airtech-factory.de/
       Post #: 180
RE: What do you think about JETLEGEND L39? - 11/5/2007 12:53:29 AM
Kmarks
Status: offline
Hello To All,
Well Today I flew my JL L-39 with a new JetCat Titan, I have been flying it with a JC P120 and my conclusion is that the Titan is a better match up with this Jet. The Take Off was right on the step, with authority and quick response. The Gear went up nicely, and cruising at 1/2 stick gave a quicker nicer handling plane. The landing was no different, and it seems that fuel consumption is only slightly more. I had a 5 minute flight with fuel left over, and I plan now to add a third tank to acheive the 7 to 9 minute flight. I have 20 flights on the L-39 now and each flight is getting better and better. I really like this bird, and spectators really like the profile in flight and on landing.
Have Fun.
Kevin Marks
(in reply to Inconel)
       Post #: 181
RE: What do you think about JETLEGEND L39? - 11/5/2007 6:19:06 AM
SpiderJets
Status: online
Hi,
I have made some more flights on mine too, with better throttle control due to exponential throttle curve (more spread of the top RPM over wider stick range).
My landings are now as per Kevin's posts : full flap and 1/3-1/2 power. Really nice. P-160 gives it superb performance, my flights are 6 minutes, the alarm is set to 7 and I have just enough fuel for safe flights. Digitech's larger UAT hopper tank might be an option, or install 2 cola bottles of 2 liters ? Anyway, I am happy with the capacity myself now.
Batman and his latest chick took the controls and without any doubt, the plane flies now much better.
Perhaps it has also to do with the CG being a bit more forward. The pilot and his girlfriend weigh in at about 280 grams, I took some 100 grams lead from the nose (the pilots are half way the CG and the nose). The stall tendency is much less now too.
The oleo spring in the nose was replaced with a heavier spring from an old Robart strut, cut off at length 2". Now it is perfect and the plane 'sits' correctly on the tarmac.... errr... grass.
PS. Note the purse and sexy boots which my friend Pedro taped in the cockpit interior while I was having a coffee !
Enjoy,
Nicolas.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SpiderJets -- 11/5/2007 6:27:57 AM >
(in reply to Kmarks)
       Post #: 182
RE: What do you think about JETLEGEND L39? - 11/5/2007 11:41:51 AM
icepilot
Status: online
Nicolas, it's great to have you back in the jet community again! I see you still have the router machine,
very nice details with the perfectly done parts with words routed into them!!
It's also fun to see the old SpiderJets bypass, air gauges and other stuff that I recognize from my two
F-16's. You remember there is still an unbuilt SJF-16 here in Norway - I'm not sure this guy will ever build it..
Congratulations on the maiden, and I hope to see you in Norway soon!
Tor
       Post #: 183
RE: What do you think about JETLEGEND L39? - 11/5/2007 6:31:47 PM
Miquel
Status: offline
Hi Im Miguel from Spain Im a dealer of FB and JL in Spain, yestarday I made 4 fly of this mode and the models fly very very vell with a P-160 titan I made a short video http://es.youtube.com/watch?v=RJS4hUNMrCk and a link in Spain foro abaut this model http://www.miliamperios.com/foro/viewtopic.php?t=87566
(in reply to icepilot)
       Post #: 184
RE: What do you think about JETLEGEND L39? - 11/5/2007 7:09:47 PM
jetjohn
Status: offline
Miguel,
Nice video the L39 looks very good in the air. Lovely landing & roll out.
Nicolas & Kevin,
Looks and sounds like you are both having a lot of fun with the L39.
Just waiting for mine to arrive.
Nicolas,
Are you using same c of g as Kevin?
What is the tank capacity as standard?
All the best,
John C
(in reply to Miquel)
       Post #: 185
RE: What do you think about JETLEGEND L39? - 11/5/2007 7:15:27 PM
Miquel
Status: offline
yes I use the CG recomendate for JL ant the tanks is 3 litres
(in reply to jetjohn)
       Post #: 186
RE: What do you think about JETLEGEND L39? - 11/5/2007 7:34:03 PM
SpiderJets
Status: online
Thank you Tor, I really love this hobby !
Nicolas.
       Post #: 187
RE: What do you think about JETLEGEND L39? - 11/5/2007 7:43:35 PM
SpiderJets
Status: online
Miguel,
Very nice video but such a shame that two different planes are mixed.
Your L-39 seems to be less stable than mine ; but at least I see you have the same landing approach glide angle and speed as well. When reading Kevin's posts, I thought I was doing something wrong and flying too fast. I'll test also the opened air brake during landing with some more throttle next time, just like you... Who knows...
Tank capacity of the fiberglass tanks is exactly 1660 ml each, check it out ! (+ BVM UAT : 125 ml // or Digitech's UAT : 250 ml)
John,
The CG, I haven't re-checked it, but I will not be wrong saying that if you have the CG as per the plan with the plane hanging perfectly horizontal, it is a tiny bit tail heavy. I would add the weight of one single servo (about 45 grams) in the nose from that point and you should be perfect. Give us some more time to test it all....
Two 2 liter bottles for 8 minute flights wouldn't be bad... (see previous posts)
Todd,
The air brake hinge line : exactly 1" (=+/- 26mm) from the front of the airbrake ! Sorry for being so late ! I wrote it on my arm not to forget it this time !
Nicolas.
       Post #: 188
RE: What do you think about JETLEGEND L39? - 11/5/2007 10:57:10 PM
ash 26
Status: offline
Hi John
how long ago did you order your L39 ?
I have mine on order since JETPOWER I did get a few e-mails from JETLEGEND telling me it was ready for delivery but still no signe
or tracking No .
regards
Andreas
