SSC -- Let's can the rpm limit!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> SSC -- Let's can the rpm limit!! Page: [1]
Login
SSC -- Let's can the rpm limit!! - 9/8/2007 7:20:56 PM
glowplugboy
Status: offline
Fellas, since SSC has become only a ever so slightly slower version of Open B, let's can the 17,500 rpm rule and "let them run". Keep the stock $65.00 max price engine rule, and have a $50 dollar engine buy out rule where any competitor can buy another competitor's engine for $50 on the spot. Ok, I have on my body armour, lexan face mask.... ready, aim, fire away!
Regards,
GPB
       Post #: 1
RE: SSC -- Let's can the rpm limit!! - 9/8/2007 9:15:14 PM
RC MANIAC119
Status: offline
It will never happen........
_____________________________
RC MANIAC-PRO BRO 1900-AMA# 95841
(in reply to glowplugboy)
       Post #: 2
RE: SSC -- Let's can the rpm limit!! - 9/8/2007 10:05:04 PM
combatpigg
Status: online
To make it a slower form of SSC, what about making the LA .15 engine turn a 9x3 prop at whatever rpm it can? I agree that SSC isn't all that S or S, just C.
Diesel .15s with 8x6 nylon props is SSC.
Led Zeppelin is NOT "old fogie" music.
(in reply to RC MANIAC119)
       Post #: 3
RE: SSC -- Let's can the rpm limit!! - 9/8/2007 10:33:02 PM
glowplugboy
Status: offline
quote:
ORIGINAL: combatpigg
hmmmm, I like the idea of diesel .15 and an 8 X 6. Not only do they run bad, but they smell bad too.
(in reply to combatpigg)
       Post #: 4
RE: SSC -- Let's can the rpm limit!! - 9/10/2007 2:42:53 AM
Lou Melancon
Status: offline
Mike,
Slow and Survivable Combat was based on a max airspeed of 49mph, which is the theoretical speed of an 8X3 at 17,500 rpms. Initially no one could reach 17,500 and it was thought to be a silly limit till folks figured out how to get to 19,000. Mike Fredricks warned us all of scope creep and he was right. The scope has crept up by the following changes (and I was behind some of them):
  • Allow the muffler to be drilled out and the baffle removed.
  • Allow use of pressurized fuel systems
  • Allow substitution of needle valves and backplates in the name of reliability
  • Variation from contest to contest of rpm check process
  • Allowing electrics into event without enough testing to assure a level playing field
  • Lack of enforcement of minimum weights
If the event stayed true to the "slow and survivable" concept many of these things would not have been allowed, and I was one of the ones who let them happen without realizing just what the consequences would be. Now I would suggest going to larger wing area minimum and upping the minimum weight to slow things down.
Waco Brotherhood Member #110
       Post #: 5
RE: SSC -- Let's can the rpm limit!! - 9/10/2007 3:09:08 AM
glowplugboy
Status: offline
quote:
ORIGINAL: Lou Melancon
Mike,
Hi Lou,
You make some very good points and I did not realize how the little changes add up to what we have today as you listed them here. For Sunday fun combat, I fly a three and a half pound Tuff Flight Panther, and unless my .15 is running in the mid 18's, I wouldn't be able to loop! Obviously, that is quite heavy for an SSC competition model, but maybe if the minimum weight for SSC was two and three quarter pounds, with wing area minimums in the 650 square inch range, that would return the class back more to a finesse event. Other opinions???
GPB
(in reply to Lou Melancon)
       Post #: 6
RE: SSC -- Let's can the rpm limit!! - 9/10/2007 5:14:21 AM
AirScharnell
Status: offline
Hey Mike, you could change the rules by state?
At 5800 elevation we need every RPM the engine puts out too fly.
       Post #: 7
RE: SSC -- Let's can the rpm limit!! - 9/10/2007 12:03:06 PM
glowplugboy
Status: offline
Ha! Yes, that thin, clean, Colorado air does create it's own set of issues. Perhaps increasing the minimum weight and wing area and eliminating the rpm rule would be the next evolution in the SSC revolution.
(in reply to AirScharnell)
       Post #: 8
RE: SSC -- Let's can the rpm limit!! - 9/10/2007 1:16:28 PM
Alex Treneff
Status: offline
A class without an RPM limit exists. Open A.
Alex Treneff
TreneffRC - Team Battle Axe
       Post #: 9
RE: SSC -- Let's can the rpm limit!! - 9/10/2007 1:35:11 PM
combatpigg
Status: online
Increasing model weight won't make them slower, it will increase kinetic energy though. Bringing the rpms down to a managable level and LIMITING model weight to a MAX will help bring about a class where you can fly all weekend with one plane and a back up. The target air speed can be set even lower if the weight is restricted and limit the power with a 9x3 prop. The 9x3 prop idea isn't something that I've tried yet on my LA .15, but I'm willing to bet it would work on a light enough plane.
Too bad diesels have so many objectional traits, like the smell, nasty clean up, tempermental running in the heat, etc., because they deliver the kind of power that is perfect for SSC [when everything is working right]. You will usually burn barrel the diesel planes after a couple years due to their fuel soaked funkyness instead of retiring them due to massive damage.
< Message edited by combatpigg -- 9/10/2007 1:46:32 PM >
(in reply to Alex Treneff)
       Post #: 10
RE: SSC -- Let's can the rpm limit!! - 9/10/2007 2:55:30 PM
AirScharnell
Status: offline
Alex I mentioned a change for OPEN A in RCCA forum. For US air deprived pilots.
That is one reason SSC has not taken on in the UPPER WEST region.
Also I recieved comments about SSC when I was in UTAH this summer, and why they dont fly it.
We have 4 or 5 pilots east of Denver that still try and fly SSC when we can. My last bird was flying fair at 2lbs 13oz. but the 15 LA was screaming at 17500 on 30% heli fuel
Frank S.
http://airscharnell.com/
< Message edited by AirScharnell -- 9/10/2007 3:01:58 PM >
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
