Walter D
CA, USA Status: offline
I built one many years ago, and if you don't change the wing airfoil you're doomed, do not go for the scale airfoil, it will not work at this reynolds numbers, cheat on the wing design a little, do not make it as tapered and most important, thicken that airfoil to generate lift, I would go with a Clark Y airfoil, add about 3-5 degress washout, with its stock wing, it will be tip stalling at 40 MPH, mine met its demise on landing (had to, one engine was overheating), I deployed about 30 deg. flaps, lined her up with the runway and coming in high with the nose pointing down at about 25 deg., this thing started tip stalling (gear was still up) to the point of being uncontrollable, it went in. My airplane weighed in at 12 lbs. ready to fly and it was fully decked out, after mine I so four or five more at different scale meets do the same thing, at full throttle they flew very well, but you know, you gotta come down some time! These are not Sunday fliers for sure!
