Setup For Older Simple Smoke Pump
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Setup For Older Simple Smoke Pump
Page: [1]
Login
Setup For Older Simple Smoke Pump - 3/19/2003 10:50:10 AM
danmilo
Status: offline
I have one of the older units, looks like a big rectangular pack of gum. I am trying to figure out how to wire it up. It has one radio lead on it. I imagine this would be hooked to a 4.8 volt battery with an on-off switch and a micro switch activated by a servo?
I visited TME's site and they had plenty of instructions on the II pump but it has two radio connections and plugs directly into the receiver.
Dan :
       Post #: 1
Setup For Older Simple Smoke Pump - 3/23/2003 10:56:37 PM
repinfl
Status: offline
I have two of the "old" units and they both have TWO leads
coming from the unit. One is for the battery and the other plugs
into a spare channel in the receiver. It is activated at about 50%
of travel of that channel. If it does not activate try reversing the
channel. I also have the instruction manual for this pump and
could send You a copy if You feel it necessary.
Now it is possible that You have an even older model that does
not have two leads coming from it but I have never seen one like
that!
Robert
(in reply to danmilo)
       Post #: 2
Setup For Older Simple Smoke Pump - 3/24/2003 6:43:50 AM
danmilo
Status: offline
Thanks for your comments. Now that I am curious, I am going to pry open the case to see if one lead was removed. Would you mind mailing me a copy? I'll gladly cover your costs associated with the effort!
Dan
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
