RE: Lets see your Ultimate 120's!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RE: Lets see your Ultimate 120's!
Page: <<   < prev  1 [2]
Login
RE: Lets see your Ultimate 120's! - 3/18/2008 4:55:58 PM
cje0114
Status: offline
BTW, I never did get those parts for the Ultimate. I was on the Nitroplanes replacement parts thread also. NP finally just started ignoring my emails and phone support was no help.
I'll still never buy another plane from Nitroplanes.
Chris
(in reply to rashmore)
       Post #: 26
RE: Lets see your Ultimate 120's! - 3/18/2008 5:07:24 PM
opjose
Status: online
You should PM John here about parts.
If you do not get a response within 3-4 days, repeat, lather and rinse until done.
E-mails may not get through to John.
I am surprised that you did not get a response since your initial post.
I have on several occasions since then and most people have been responded to.
Did you get any PM's?
< Message edited by opjose -- 3/18/2008 5:10:18 PM >
_____________________________
Build em'', fly em'', crash em'' and build more.
(in reply to cje0114)
       Post #: 27
RE: Lets see your Ultimate 120's! - 3/18/2008 5:12:35 PM
cje0114
Status: offline
I had a PM responded to, but that's about it. Never did get any real info on getting my parts. I don't care anyway. I sold the plane
(in reply to opjose)
       Post #: 28
RE: Lets see your Ultimate 120's! - 3/22/2008 5:34:49 AM
rashmore
Status: offline
Quick Question!
The manual that came with the ultimate shows the elevator and rudder AND throttle servos all packed under the canopy. The Servo tray in the plane however just has cutouts for the elevators and rudder. I noticed that there is still a couple places that you can mount the elevator servos under the horz. stab. (by cutting the covering away). That would probably be a better set up for me, but im concerned about the cg when that happens. Im using an OS FS-120. Would i have to glue a brick to the front of the plane to get it to balance?
Anyone else using a glow engine with dual elevator servos under the stab?
Rod
       Post #: 29
RE: Lets see your Ultimate 120's! - 3/23/2008 4:26:03 AM
opjose
Status: online
The holes are there so you can do whatever you want.
Either will work.
If you are using a heavier engine, you can use the servos in the tail to help balance out the plane.
The OS 1.20 will NOT "require" this, if anything the plane may need that you move the battery FORWARD to help balance it out.
       Post #: 30
RE: Lets see your Ultimate 120's! - 4/10/2008 5:18:59 PM
SRimer
Status: offline
I have the pink white and blue one with spe26, but I'm not sure where the CG should be, could someone post that number for me please, thanks
       Post #: 31
RE: Lets see your Ultimate 120's! - 4/10/2008 6:23:51 PM
opjose
Status: online
quote:
ORIGINAL: SRimer
I'll post it later for you.
I also have one of these, it's a WONDERFUL flyer...
(in reply to SRimer)
       Post #: 32
RE: Lets see your Ultimate 120's! - 4/27/2008 8:21:06 PM
SRimer
Status: offline
Mine flys great with spe26, I think it is nose heavy, I'm not sure what CG should be , can someone post the number please.
I have 450cc of fuel on board, maybe I can go down 350cc to make it fly better.
       Post #: 33
RE: Lets see your Ultimate 120's! - 4/27/2008 8:44:21 PM
RR24
Status: offline
quote:
ORIGINAL: SRimer
I have the yellow version, and the manual say to balance 4.17 (Quote form the manual: the ideal C.G. is 106mm (4.17in) behind the leading edge measured at the top wing center line.)
I hope to have mine ready in the next couple of weeks, I am almost there!
       Post #: 34
RE: Lets see your Ultimate 120's! - 4/27/2008 8:51:09 PM
RR24
Status: offline
I forgot i also have BCMA-SPE 26cc, hope this combo works great
(in reply to RR24)
       Post #: 35
Jump to:
Google
SITE MAP!   : :   FORUM RULES
