RE: Extra 260 75cc
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: Extra 260 75cc
Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: Extra 260 75cc - 10/7/2007 2:30:29 AM
bodywerks
Status: offline
P2W should be OK with that engine and that weight . I just picked mine up today and will be using the DA 85 and one A123 on the rx and some smaller capacity cells with the same chemistry as the A123's. I forget the name of the website, but there is such a source. I will also be lightening it up with CF and removed wood and expect 22 pounds or less...
_____________________________
STRAIGHTEN UP AND FLY LIGHT!!!
(in reply to sukhoi26mx)
       Post #: 51
RE: Extra 260 75cc - 10/10/2007 5:26:21 PM
zzw26n
Status: offline
Mark Dennis -
On your web-site is shows the canister tunnel painted White, did someone do that as a part of the build to look good? or to seal it? Mine is sealed with clear and looks good, just wonder why the prototype was showing a White canister Tunnel?
thanks Ward
(in reply to bodywerks)
       Post #: 52
RE: Extra 260 75cc - 10/10/2007 11:09:39 PM
sukhoi26mx
Status: offline
quote:
ORIGINAL: bodywerks
I'm interested in the source for the smaller same chemistry source (A123) cells if you can find it...
Scott
       Post #: 53
RE: Extra 260 75cc - 10/11/2007 12:55:13 AM
bodywerks
Status: offline
http://www.splendidbattery.com/products.asp
They are not A123, but they are the same chemistry. Don't let the non-a123 thing fool you. As a matter of fact, A123 cells are also made in China by the same manufacturer that makes the Dewalt batteries. It's all the same chemistry, just with a different brand name. And A123 isn't the brainchild behind this stuff, anyway - some nerds at MIT or some other technical University are.
If you are interested in his batteries, his name is Robert Chang and you can email him at allbattery@21cn.net.
I have not yet placed an order, but I was told he is willing to sell in small quantities. I think I am going to go with a single A123 pack on the rx and the no. 110004 1200mah batteries on the ignition. I imagine they only weigh about 1.6oz/cell. If so, I may just order 6 of them and have a little redundancy on the Rx while still only having a 10 ounce battery power system
< Message edited by bodywerks -- 10/11/2007 1:03:11 AM >
       Post #: 54
RE: Extra 260 75cc - 10/11/2007 2:47:14 AM
Ferocious Frankie
Status: offline
quote:
ORIGINAL: sukhoi26mx
Just finished mine up as well. I've been documenting the build as I go and intend to do a build thread later this weekend or early next week. Initial thoughts are that it is every bit as high quality as the 150cc. Can't wait to maiden it, but expect it will be next week before I can make that happen. Specs:
75cc AeroWorks Extra 260
(5) Hitec 5955TG servos
stock control hardware
Smart-Fly Power Expander and flag switch
Smart-Fly Optical Ignition Cutoff
(3) A123 Systems 2200 mAh Li-ion packs
NO REGULATORS!!!
BME 110cc twin
Menz 27x10
Stock mufflers
AUW 22 lb. 6 oz.
In all, I expected closer to 23 lbs, and I could be under 22 with a single receiver pack and a smaller ignition pack. Couldn't be happier with that weight and the overall assembly and appearance of the model. First rate.
Scott
Scott,
Where did you buy your battery packs from? I could only find 2300 mAh on Horizon for 60$.
"To fly is everything." -Wright Brothers
Club Site: www.sccmas.org
       Post #: 55
RE: Extra 260 75cc - 10/11/2007 5:12:23 AM
Mark Dennis
Status: online
quote:
ORIGINAL: zzw26n
Mark Dennis -
thanks Ward
Originally we planned to have the tunnel come painted in all white like it shows in the pictures, unfortunatley it was not very easy for the manufacturer to do and so we decided to have it come with the clear just like the firewall.
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
(in reply to zzw26n)
       Post #: 56
RE: Extra 260 75cc - 10/12/2007 5:13:53 PM
zzw26n
Status: offline
quote:
ORIGINAL: Mark Dennis
quote:
ORIGINAL: zzw26n
Mark Dennis -
thanks Ward
Thanks Mark ................
This is one great Airplane, the build for me has been question free and the Quality and fore thought is fantastic, thank you!
Ward
(in reply to Mark Dennis)
       Post #: 57
RE: Extra 260 75cc - 10/18/2007 5:53:49 AM
richiepingi3
Status: offline
All aero-works plane are awesome!
< Message edited by richiepingi3 -- 10/18/2007 5:59:25 AM >
       Post #: 58
RE: Extra 260 75cc - 10/18/2007 5:13:39 PM
sukhoi26mx
Status: offline
quote:
ORIGINAL: Ferocious Frankie
NO REGULATORS!!!
BME 110cc twin
Menz 27x10
Stock mufflers
AUW 22 lb. 6 oz.
Scott
Scott,
Missed your post entirely.
Whoops. They are 2300 mAh. Couple of ways to get them. Lots of vendors sell them and the 2-cell pre-made packs are around $60. The other option if you're good with a soldering iron is to build your own packs. The cells are the same as the 36 Volt Dewalt lithium power pack (available on Ebay.) The 36 volt pack (10 cells) can be had for around $100-110 shipped, and that will make 5 packs, so its dramatically cheaper.
Scott
(in reply to Ferocious Frankie)
       Post #: 59
RE: Extra 260 75cc - 10/22/2007 9:52:32 PM
zzw26n
Status: offline
Another Question for Aero-works and the Pilots who have the 75cc Extra 260; Is one HS-5955 enough for the Rudder? Is the geometry correct with a 3" Arm and Cables straight back?
thanks ..... Ward
       Post #: 60
RE: Extra 260 75cc - 10/22/2007 10:15:57 PM
bodywerks
Status: offline
Yes, and yes. The plane they used for testing only had one 5955. My 35% only had one 5955 and could fly KE no problem, so it should do just fine on a plane that is 4-5 pounds lighter. Mine, however, will have an 8711 on the rudder, mounted in the tail as a push/pull.
       Post #: 61
RE: Extra 260 75cc - 10/25/2007 1:24:06 PM
aspicer
Status: offline
Ward, I have one 5955 on mine and it seems fine. The 2.5" arm is a better choice than the 3". If you measure the distance between the control horns on the rudder you'll find them right at 2.5" and with non cross over geometry you want the servo arm the same length.
       Post #: 62
RE: Extra 260 75cc - 10/25/2007 9:11:24 PM
zzw26n
Status: offline
quote:
ORIGINAL: aspicer
I bought both arms today (3" and 2.5" just incase, glad I did now, thanks. I'll do the dry run with the 2.5" and see how it looks.
Thanks again ........
(in reply to aspicer)
       Post #: 63
RE: Extra 260 75cc - 11/3/2007 2:16:13 AM
zzw26n
Status: offline
Did the maiden on mine today, 54 degree's , SSE wind at 8-9 MPH. On take off I Throttled up pretty fast, I thought the DA-85 was going to rip the Wings off the Plane. Two clicks of Rudder and it was hands off. KE was easy, near 0 coupling and CG was exactly how I like, 45 degree inverted and just a slight arc back to earth, I won't move it. Right thrust might have to be adjusted, but trimming will still need work. Plane took about 12 hours to build and I have zero complaints with the build. And the only hardware I changed was the wheels and I used pro-links, everything else was top shelf. I'm sold on Aero-Works and it appears their service is there to back up the product. It's a keeper!
       Post #: 64
RE: Extra 260 75cc - 11/3/2007 2:52:27 AM
mowery1
Status: offline
I just love mine!! This is probably the best aircraft I've ever flown..On my maiden I didn't have to trim anything!! You're right about the DA 85...It definately has plenty of power!!! Enjoy the Extra!!!
Authorized dealer for Fei Bao, Tamjets, Yellow Aircraft, Jetcat, Aero-Works, FlyEagle Jets, QQ aircraft
       Post #: 65
