Wiring issues with separate ESCs
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> Wiring issues with separate ESCs
Page: [1]
Login
Wiring issues with separate ESCs - 9/12/2007 3:27:25 AM
AFDrifter
Status: offline
Well, I took the plunge and went with separate ESC for my Axe. I thought I had everything wired correctly but I'm not getting any power to the Rec'. I have the pos/neg wires from the esc's soldered together to a Deans ultra plug. The Main ECS has the Blue/White wires soldered to bullet connectors and connected to the Main motor, and the three wire plug from the ESC (BEC) is connected to position three on the Rec. The Tail ESC is connected to the Tail motor and to the GY240 which is connected to the Rec'. Maybe someone can check my work. Do I need a power plug to go to position Five on the Rec? Any suggestions would be appreciated
EDIT 1: Yes the BEC fromt he Tail ESC is disabled.
< Message edited by AFDrifter -- 9/12/2007 3:28:51 AM >
       Post #: 1
RE: Wiring issues with separate ESCs - 9/12/2007 8:17:05 PM
AFDrifter
Status: offline
Well, it turns out the reciever is dead. I plugged the BEC connector from the Main ESC into a different reciever and it worked. I tried this with a separate reciever battery pack as well and the other reciever works. Looks like I'm grounded for a while.
(in reply to AFDrifter)
       Post #: 2
RE: Wiring issues with separate ESCs - 9/12/2007 9:05:21 PM
MMatheny
Status: offline
Any idea what killed the RX?
_____________________________
Mike
"Never use your shins as a blade tracking device" - Mike
       Post #: 3
RE: Wiring issues with separate ESCs - 9/12/2007 9:23:36 PM
thestratcat
Status: offline
you've got a pm dude!
"If guns cause crime, all of mine are defective" ~ Ted Nugent.
(in reply to MMatheny)
       Post #: 4
RE: Wiring issues with separate ESCs - 9/13/2007 3:01:21 AM
AFDrifter
Status: offline
Thanks for the PM bud. Not sure what exactly killed the Rx, but, I think it was a combination of the crash and the new battery. I bought a 910mah LiPo last week and this was its first full flight. I think the crash messed up the 3n1 board which may have spike the current to the Rx. That's really the only thing I can think of. The new ESC works just fine. I plugged the BEC plug into a receiver from one of my cars and it powered up and moved the servo just fine. Would the crystal have anything to do with the power situation? Maybe it destroyed the crystal?
(in reply to thestratcat)
       Post #: 5
RE: Wiring issues with separate ESCs - 9/13/2007 3:08:01 PM
123Splat
Status: offline
What killed your recvr was feeding BOTH BECs to the recvr. You only need to feed one BEC to the recvr. Disconnect and wrap up the other one.
Splat
It's not the takeoff or the flying, it's the landing and repairing, so I can takeoff and fly again...
       Post #: 6
RE: Wiring issues with separate ESCs - 9/15/2007 5:47:53 AM
AFDrifter
Status: offline
I said the BEC from the tail ESC is disabled. 1st post.
Only the negative wire is still in the plug, per the Helimax instructions.
< Message edited by AFDrifter -- 9/15/2007 5:53:45 AM >
(in reply to 123Splat)
       Post #: 7
RE: Wiring issues with separate ESCs - 9/15/2007 6:31:43 AM
osterizer
Status: offline
Well, you might have spiked the receiver, of course, and if you've tried different power sources and it doesn't work with any of them that's pretty telling. You might want to pop the case and look for physical damage-- sometimes it isn't a component that fails, but instead a solder joint or a trace on the circuit board, and those are easily repaired.
A bad crystal won't stop the receiver from powering up, but it will keep it from receiving a signal, and the two have pretty much the same results. If you can try another crystal it wouldn't be a bad idea.
       Post #: 8
RE: Wiring issues with separate ESCs - 9/17/2007 2:55:35 PM
123Splat
Status: offline
I missed that. Maybe I replied before your edit. Sorry anyway.
Check the chrystal and the antenna lead then.
Splat
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.750RCU1
