Rounding Landing Gear Edges, Etc.
Tower Hobbies
Logged in as Guest
  Printable Version
Jet Hangar Hobbies LTV A-7 Corsair II - RTF
Seller:  mikegpresario
Details:   $2,850.00   |  8/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> Rounding Landing Gear Edges, Etc.
Page: [1]
Login
Rounding Landing Gear Edges, Etc. - 2/27/2002 12:25:45 AM
Jazzy
Status: offline
Someone told me that if you round the LE of landing gear the aerodynamic properties will increase. I.E. the plane will fly faster.
I also just heard that rounding the TE on control surfaces that otherwise, according to plans, just need the edge taken off will cause flutter at high speeds. Credence to any of this?
Jeff
       Post #: 1
Drag - 2/27/2002 12:36:59 AM
Mike James
Status: offline
Rounding the leading edges of your landing gear (I assume you mean sheet metal type) will reduce the drag. Whether you can actually see the difference or not is hard to predict.
About the sharp trailing edges. Ollie can probably answer this more definitively then me. I've done both sharp and dull trailing edges, and can't say that I've noticed a difference. I'm sure it has a big effect on certain types of planes, at certain speeds.
_____________________________
Mike James
RC Design and Building - www.nextcraft.com
(in reply to Jazzy)
       Post #: 2
Flutter - 2/27/2002 2:53:41 AM
Ollie
Status: offline
Every control surface and its associated linkages has a natural frequency of vibration. The stiffer and lighter the system, the higher the frequency. When aerodynamic forces produce deflection that also is periodic, the stage is set for flutter. Blunt trailing edges and rounded trailing edges can produce vortex shedding. The frequency of vortex shedding is a function of airspeed. When the natural frequency of vibration of the mechanical system matches the natural frequency of vortex shedding, flutter results. There are other, more common aeroelastic, causes of flutter too.
Use sharp, gradually tapered trailing edges to minimize vortex shedding and reduce weight. Make the mechanical system as light and stiff as you can. This will generally raise the natural frequency of the mechanical system well above the vortex shedding frequency in models. Mass balancing around the hinge line makes the mechanical system aperiodic. Aerodynamic balance (hinging through the aerodynamic center) minimizes the aerodynamic forces.
< Message edited by Ollie -- Feb 26 2002 9:59PM >
Regards, Ollie
(in reply to Jazzy)
       Post #: 3
Rounding Landing Gear Edges, Etc. - 2/27/2002 9:51:39 AM
Jazzy
Status: offline
Shoot!
I knew I should have gone further in my college education, (ASME).
I do understand quite well what you are saying and thank you for your insights.
Jeff
(in reply to Jazzy)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.314RCU1
