Hang up on start.
Tower Hobbies
Logged in as Guest
  Printable Version
Fei Bao Velox XL Sport Jet - ARF
Seller:  rcjetmodels
Details:   $1,300.00   |  8/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> PST Jets >> Hang up on start.
Page: [1]
Login
Hang up on start. - 9/12/2007 4:47:51 PM
Moe142
Status: offline
Hello. I have done ALL the trouble shooting and to no avail, the J600R still hangs up on start. At about 10-13,000 RPM. (it just stayes there until I sut the engine down) A couple of times it ramped up and I thought it was going to go all the way but it didn't. It just went back down in RPM's and stayed there for a few seconds til the engine turned off by itself. There is a * on number 4 after shutdown. It sounds like the pump it NOT engaging. I tried to prime the pump and it never turned on. It has always turned on before when primed the pump. The last shutdown showed 18,000 RPM and the pump 2.04. and just an* on number 5 . And I have a FULLY charged battery. Mabey my fuel pump is bad. I will test it with the ECU battery for a second. Kelly help..
< Message edited by Moe142 -- 9/12/2007 6:20:06 PM >
       Post #: 1
RE: Hang up on start. - 9/12/2007 7:48:48 PM
Moe142
Status: offline
UPDATE. It starts! It was a sticky or stuck fuel pump. I took the fuel pump and hooked it up directly to the ECU battery for a second and it pumped or came un-stuck. Put everything back in and did a prime from the GDT and the pump primed. (before when I did this the pump did NOT prime) So I am guessing it was a stuck or sticky fuel pump. I have about 13 hrs on it. So, I went through the start sequence and it came alive and fired right up! GREAT LITTLE TURBINE. I plan on getting a 1300R here very soon!
< Message edited by Moe142 -- 9/12/2007 7:50:04 PM >
(in reply to Moe142)
       Post #: 2
RE: Hang up on start. - 9/13/2007 1:16:29 AM
B777
Status: online
Thanks for the input and update
Fuel pumps do stick from time to time especially after long storage. Priming before start helps to confirm if the pump is sticky or not.
Cheers,
Kraivuth S.
_____________________________
PST Jets Thailand Skymaster Jet Thailand
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
