Mini Showtime
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> Mini Showtime
Page: [1] 2 3   next >   >>
Login
Mini Showtime - 9/13/2007 10:18:36 PM
Taildragger726
Status: offline
I find that the Mini Showtime suffers from a very weak structure. My wings and fusalage both failed about thirty seconds into the maiden voyage. The LG seemed to hold up well,, only one takeoff, not used for the landing. Who would have thought that an encounter with a pine tree would have such an effect? I mean the Mini Showtime was only traveling about thirty mph when It hit the tree! Oh,, the carnage!!!
(I hope all that read this fully understand that the above post is all in jest. The crash was 100% my fault and not the fault of the Mini Showtime. For 30 seconds it was absoulty great !)
_____________________________
Also known as N726AC
       Post #: 1
RE: Mini Showtime - 9/14/2007 1:37:56 AM
stinger40
Status: offline
Uh.... wrong thread, man.
Gravity is a terrible, terrible thing.
(in reply to Taildragger726)
       Post #: 2
RE: Mini Showtime - 9/16/2007 1:21:52 AM
Taildragger726
Status: offline
What a humorless bunch !!
Anyway,anyone have any insight on this Airplane?? I have another on the way,,,,,
(in reply to stinger40)
       Post #: 3
RE: Mini Showtime - 9/16/2007 3:38:48 AM
nitro wing
Status: offline
I have their 260.I love it,wouldnt mind trying the Showtime.
       Post #: 4
RE: Mini Showtime - 9/16/2007 12:37:22 PM
Taildragger726
Status: offline
quote:
ORIGINAL: nitro wing
Yeah, same here. The 260 is such a nice flying plane, I think E-flight has this small electric thing figured out. The MiniShowtime has more wing area,, should be a real floater.
(in reply to nitro wing)
       Post #: 5
RE: Mini Showtime - 9/17/2007 2:39:21 AM
Ifly4fun3d
Status: offline
I love this plane. Started flying again at the begining of summer with a foamie cub. Moved up to the 260edge and then bought this. My friends have larger planes and both have the larger showtime and are very impressed with this.
       Post #: 6
RE: Mini Showtime - 9/17/2007 11:34:04 PM
tcclong
Status: offline
That's a bummer about your plane. I hit a light pole before with my foamie - also not a great idea. What were you doing at 30 mph? That's your problem. If you had been flying 3D (1-2 mph) you may have fared better.
quote:
ORIGINAL: Taildragger726
       Post #: 7
RE: Mini Showtime - 9/18/2007 12:19:21 AM
Taildragger726
Status: offline
quote:
ORIGINAL: tcclong
Short version,, I ask too much from the BEC on my speed controller. This Spectrum stuff is rather intollerant of low voltage. I am NOT bashing any manufacture of any components. It was my mistake in set up. Remember, this was a maiden flight and was sorta high just trimming and feeling her out. First outside snap,, four servos at max deflection,, voltage drop from BEC,, Spectrum signed off, radio in failsafe. Vertical decent arrested by a pine tree. I orignally left out details so it does not sound like product bashing.
Different setup for the next one. THE SPECTRUM STAYS!!! Will run a seperate BEC now.
Ok, got it?
(in reply to tcclong)
       Post #: 8
RE: Mini Showtime - 9/19/2007 3:18:19 AM
John Redman
Status: offline
Hey Taildragger, what ESC were you using? We run our basic 40 amp with our S75 servos all day long and don't have any problems with it. Sorry to hear about the loss. The Mini Showtime flies great I will say.
John Redman; Team JR, BVM Rep, JetCat USA Rep, Horizon Hobby/E-flite Product Developer/Manager
       Post #: 9
RE: Mini Showtime - 9/19/2007 3:25:54 AM
Taildragger726
Status: offline
Ha, John I'm not going there,,,but it was not one of yours. Servos were Hitec HS-65's.(it was over two years old and a little under sized, all my fault). But I appreciate your concern.
(in reply to John Redman)
       Post #: 10
RE: Mini Showtime - 9/19/2007 4:48:41 AM
nitro wing
Status: offline
4 S75 are fine on the battery
4 HS 65 is another story,as told by the thread
       Post #: 11
RE: Mini Showtime - 9/20/2007 12:45:08 PM
Taildragger726
Status: offline
Not the battery Nitro Wing,,, the BEC in the speed controller. I had used an underrated speed controller and the BEC could not 'keep up'.
       Post #: 12
RE: Mini Showtime - 9/21/2007 12:53:22 AM
carter3
Status: offline
I hate that you lost after such a short flight. Just picked up a Mini Showtime myself and highly reccomend the use of a seperate BEC. I had anE-lite extra 260 and loved it but had the same problem with the internal BEC of the ESC that I was using. The 260 splinters the same way. I was using DS285s. Hope the showtime flies as good as the 260.
       Post #: 13
RE: Mini Showtime - 10/14/2007 2:05:05 AM
ARTP47
Status: offline
Just picked up a Mini Showtime from the LHS. I'm a bit of a low timer on the sticks. Have time in on the MUS, and Pulse, the manual has suggested low and high rates, but no Expo suggestions. Will be using pretty standerd stuff.
E480/1020
40amp ESC
Spectum DX6
E 75 servos
Any links or building tips are more than welcome.
Hoping to due more pattern like flying rather than the 3D thing.
(in reply to carter3)
       Post #: 14
RE: Mini Showtime - 10/14/2007 2:46:23 PM
papajeff
Status: offline
Years ago, an ancient seer, sooth-sayer and philosopher once said; "We learn from experience, right????" From now on........go one step up on the rating of your ESC, and you will not have to be concerned about this issue in the future. When using 4S packs, a BEC is going to be your friend! Now, was that a PINE tree..........or a PALM tree that caught your Mini Showtime?
       Post #: 15
RE: Mini Showtime - 10/20/2007 5:25:43 AM
ARTP47
