View Poll Results: A poll
Voters: 20. You may not vote on this poll
1 or the other
VA
I had my kyosho st-r every since i started the tread in the truggy section. Well it needs engine, pipe, flywheel, clutch, clutch bell, servos, wheels/tires, wing mount and front knuckles(probably will get kingheadz). I wanted to get it running so bad i decided to put the serpent for sale so i can finally get it going. I have the difference to add to the money i get from the serpent to get all the good stuff. Yesterday i went to sears. They had 2 Bowflex machines and i got on them and boy do you get a good workout! Its just like they advertised on tv and i use to want one but now that i got to try one out, i really want to get one now. Personally im leaning toward the bowflex now but i also want to drive my truggy real bad. What should i go for and why.
It could go both ways..
1. You have enough rc's (looking in your sig) so you could go ahead and get the bow flex..
2. You could get your car running and keep doing squats, push ups, situps, running, and so on..
Andrew
Andrew
VA
Well the 950R is on its way out and the menace might be too later on because i dont have much of a need for those 2 no more. The only thing running is the jammin, i also need the same stuff i mentioned for the kyosho for the fusion. But i see what your saying... and working out w/o the machines sucks to me.
Banned
my dad has a bowflex in our basement i work out on it preettty much everyday and im only 14 holy crap its been llike 3 weeks and i can bench like 160, it works so well and it comes with a leg thingy witch is good for me because im a swimmer!
CA
ORIGINAL: ProRCRacer88
VA
nope, its either one or the other, and then the one i dont pick comes later on.
i need to still see if i have the space for the bowflex because the garage is a storage area right now and the only place left really is my room. Was thinking of symple taking the entertainment center out with the tv and put it there but not quiet sure how that will work yet. If i see i have the space i will go with it, if not, then the kyosho will be up and running.
thanks for all your replys, any more are welcome.
NY
1. if u get a new engine, go with a pullstart, and u get a serious workout.
2. get a bowflex, and have no fun.
go with the bowflex, u have the car for later.
CA
ORIGINAL: ferrarimk13
CA
lol or better yet I could use the whole pitbox with the starterbox inside.
VA
around 15lbs
everyone except calvino basically said go with the bowflex but yet there are more votes on the st-r.[&:] those who vote the st-r please explain.
CA
around 15lbs
around 15lbs
, get the vehicle running, that is what you said you wanted to do, then get in shape flipping the car... make a policy that every time you crash.. you have to do xyz squats, pushups... sounds good hunh
i think a bowflex will be better in the long run health wise...fun wise, well, unless your a body builder you may not find it too fun. if you already have a couple RC's then i say the bowflex is the way to go
CA
ORIGINAL: jatoracing33
, I am allways right[8D]
ORIGINAL: calvino
don't listen to him, listen to me
are we running for president now?
CA
ORIGINAL: calvino
VA
well on ethings for sure i wont ge tnothing out of spending mor einto the hobby like i would working out. Push ups, crunches, are ok but its just more fun to do it on the machine.
CA
CA
working out prevents heart disease, but can cause heart attacks. smeling nitro kills brain cells but is pretty fun to drive
