ktaylor
IL, USA Status: offline
quote:
ORIGINAL: CaptainRandy Doug, Ken, The 8 X 4 prop that I was using on the Ploat was the same motor as the SU. It doesn't vibrate on the Ploat, so I guess it's either the motor on the SU, or the mount can't take it. I guess the slightest vibration gets magnified with the larger prop. It would most likely kill the flight time anyways. The 7 X 4 is probably the right choice for the motor/plane. I have to try it again on a calm day, to get a real feel for it. I just have to be faster than Bob's new Jet http://yardbirdrc.com/Airplanes.htm What size bearing was that that fit in the Bp-21's ? I looked on BP site, but there was too many to pick from. Pappy, your prop adapter could have a slight bend in it (or are you using a prop saver?) if you're using a prop saver, then it could be the motor shaft. If not, it could be the same problem as the $5 motor you and I fixed, where you lost your balls.. I mean ball bearings. Those bp-21 bears are 3x6x2 or 3x6x2.5 (3 is inside diameter, 6 is outside diameter, and 2 or 2.5 is the thickness. These are the ones that I bought from BP http://www.bphobbies.com/view.asp?id=V414811&pid=U886131 They're OK for these cheap motors, but if you're going to mod a motor & try to start pushing 50,000 rpms, these guys are the way to go, ceramic, http://www.vxb.com/page/bearings/PROD/3mm/Kit7748 I'm still working on plans for a 40 inch plane, twin BP-21 style motors (I'll probably rewind them for 1600 kv myself to make sure they can handle the amps) replace the bearings & crank the motors up to about 32,000 rpms (6cell lipo) with 5x5 props. Should sound like two really really pissed off bees. 140mph pitchspeed though.. Hmm still gotta play with the idea some more...
< Message edited by ktaylor -- 9/16/2007 4:58:08 PM >
_____________________________
blisters, aka Ken If 4 out of 5 people SUFFER from diarrhea...does that mean that one out of five ENJOYS it?
