Just bought a Tmaxx 2.5
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> Just bought a Tmaxx 2.5
Page: [1] 2   next >   >>
Login
Just bought a Tmaxx 2.5 - 3/20/2003 10:25:03 PM
PigMan Buggerus
Status: offline
Well actually it is on order. So what I was wondering is this: What should I do to this truck, or will it be fine to run stock? I haven't owned an RC truck(or car for that matter) before, but I do fly RC planes. Tuned pipes: Does this come with a tuned pipe? Should I get one? I noticed MACS makes one for this truck, I do like my Macs tuned pipe that I have on my plane. Should I get a tuned pipe, and what kind of power difference will I see. I think I saw that someone recommended getting a different servo for the steering? Is the stock servo weak? I know these are a lot of questions, but I want to have as good of an experience as possible.
Thanks for your time!
_____________________________
The Voice of the Angry!
http://www.voxirati.com
       Post #: 1
Just bought a Tmaxx 2.5 - 3/21/2003 1:00:01 AM
hagur
Status: offline
Congratulations on your T-Maxx.
The T-Maxx has a tuned pipe as standard, as almost all nitro trucks do. I believe the standard pipe is pretty decent. However, there are always better-than-standard aftermarket parts, and that goes for tuned pipes like everything else.
I don't think you need to think about a new tuned pipe right away. I think it's an upgrade you can think about later. Maybe some T-Maxx 2.5 owners can recommend an aftermarket pipe for the car.
Servos .... I don't know how the stock servo is. Generally we want the steering servo to put out as much torque as possible, to swing those big tires easily in the rough terrain we usually drive in
Hitec makes a damn good servo which has a whopping torque of well over 100oz/in which should be more than sufficient in a truck like this.
Here's the servo: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXUZ90&P=K
Although I'm pretty sure the stock steering servo will do, I think this will be a worthy upgrade later on.
Good luck with the truck!
(in reply to PigMan Buggerus)
       Post #: 2
Just bought a Tmaxx 2.5 - 3/21/2003 1:28:18 AM
PigMan Buggerus
Status: offline
Thanks for the info. Anyone else have any info on a tuned pipe that would be good for this truck? Has anyone done any power and acceleration tests with different pipes?
       Post #: 3
Just bought a Tmaxx 2.5 - 3/21/2003 1:35:14 AM
crash_me_over
Status: offline
Steering Servo upgrade would be good.
Roll Cage is also a good upgrade to keep from damaging your rig.
Not sure what brand of glow plug you use in your airplane engines....but the OS #3 & #8 plugs work very well in the 2.5 engine. I use these same plugs in my airplane engines and think they are worth the $$$.
Some guys use an on board temp gage to monitor the temps of the engine. Or...they'll by the Raytec temp gun so they can use it on several rigs if they have more than one rig.
The body posts are a weak spot if your flip or roll over. I have broken the rear ones as they are simply easy to break.
Some guys upgrade to RPM skids to protect the undercarriage. I would stay with the plastic parts for now...unless you stay on road and just want to show it as nice looking truck. For off-road....breaking a part is better than bending it...if it's an aluminum part....plus the aluminum gets expensive.
Congrats on your new TMaxx and good luck driving it.
CMO
       Post #: 4
Just bought a Tmaxx 2.5 - 3/21/2003 2:03:25 AM
PigMan Buggerus
Status: offline
I don't think I will be beating the truck too much. So I would imagine that the plastic will be ok for now. I think I will probably get the high torque servo, I'll see how well the included one works. Still looking for info on the tuned pipe though.
       Post #: 5
Just bought a Tmaxx 2.5 - 3/21/2003 2:19:45 AM
XR2PROBE
Status: offline
well as for a decent pipe i would check into an Associated GT pipe, .........i have 2 on order for my MAXXES and they seem to give the Maxxes alittle more UMPH on getting out of the hole without giving up low end
       Post #: 6
Just bought one too - 3/21/2003 2:20:02 AM
FairlyNew
Status: offline
I just bought a T-maxx also and was looking around the web for stuff.
This article seems to have alot of the questions you have aswered. I believe it is for the older T-Maxx but alot of the stuff should cross over.
http://www.rccentral.com/article.asp?ATCL_ID=57
       Post #: 7
Just bought a Tmaxx 2.5 - 3/21/2003 4:05:58 AM
Wookie
Status: offline
Congratulations on the new TMaxx. I've had mine for almost a month and a half and have beat the crap out of it in a small amount of time. I've had my Mad doing kart-wheels at 20+ MPH, end over end flips, landed it on it's top off of a 6 foot jump and had several nose dives into the ground off of the same 6 foot jump.
For the most part it's proven to be a very durable truck. Upgrading parts really should take place after you break them, which may be a while if you take it a little easy.
As far as tuned pipes check out some of the TMaxx sites for reviews on certian pipes. I know MIP makes a stinger pipe for the older max but I'm not sure if they have one for the 2.5. Just do a search for T-Maxx and it will pop up all kinds of sites, weed through them and you will find lots of reviews for hop up parts.
When I first got my Maxx I thought a lot about upgrading to certian aluminum parts but after thinking about it I don't feel the cost justifys the means. The only parts I've broken are the rear body posts (several times) and one front bulkhead. I'd rather spend the $8.00 for a set of stock front bulkheads than $45.00+ for some aluminum ones. 5 plastic bulkheads will last me all year or longer (the one I broke is only broke on the front bumper mount and is still totally functional). Plus upgrading to Aluminum will either be expensive when it does break or bend and may lead to other parts breaking due to the stronger part transmitting the shock to the weaker parts.
Aluminum does look cool though.
Parts that (for me) would be worth upgrading would be:
-Better tires if you plan on spending any time on a track, maybe getting some beadlock wheels so you don't have to buy new wheels every time you want to try new tires.
-Changing the oil weights in the shocks
-Upgrading to a new pipe either for better performance or quieter sound (stock is loud)
-Maybe some RPM shock towers so you can get their body posts (which should be a little more durable)
-An allen head screw set if you don't like stripping out phillups head screws.
Other than that, unless you want to spend a lot of money I would suggest you just enjoy the truck.
       Post #: 8
Just bought a Tmaxx 2.5 - 3/21/2003 6:02:26 AM
Dlock
Status: offline
I have had my new 2.5 Maxx for about 3 months now, and I love it!!!!
Here are the things I have upgraded and a little info on how I like them.
Venom Temperature Monitor - Great for getting quick readings on the temperature of your motor. The thing that sets this particular model apart from the others is the ability to read the min/max temp readings. This is very handy, because you don't always get the highest temperature reading when you look at the LCD display. I would recommend this, unless you have multiple rigs then putting one on each rig could get expensive.
Venom Failsafe - Have not needed this so far, but when I do I will be thankful. I think the only downfall to having this is that it needs power to operate. So if for some reason you loose total power to your rig, it won't help at all. Some people us this in conjunction with a Throttle Return Spring to help with the previous problem. I will probably eventually get a throttle return spring also. http://www.venom-racing.com/
Fuel Filter - Easy and cheap upgrade. The way I figure it, the less garbage you get into your engine, the longer it's going to last. I would really recommend one of these.
Hitec 945-MG Servo - This thing is sweet. It has metal gears inside making it stronger. 122 oz/in torque at 4.8v and 153 oz/in torque at 6v. I got this thing used otherwise it is pretty expensive new, about $75. A cheaper and almost as nice alternative is the Hitec 645-MG. $40 for that one. I am still running at 4.8v, but there is a definite increase in steering speed and power. The stock one is a little weak, and I would suggest getting at least the Hitec 645MG sometime down the road. http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNZ35&P=K
1800 NiMH Batteries - I got these because I did not want to pay a ton for Duracells or Energizers. They have been great, they hold a great charge and are easy to deal with.
50wt Shock Oil. I wanted a stiffer suspension. SO I replace the stock 30-35wt oil with 50. I am still not sure if this is the suspension response I want, but it's better than stock. I would suggest going up to 40 or 45 wt oils in the stock shocks.
CVEC z700 Tuned Pipe - Being this is my first nitro vehicle, I can't really tell you if this is the best pipe. I will tell you what I have noticed. It is made especially for the TRX 2.5, it's rear exiting, and is adjustable. The thing I probably like most about this pipe is that it exits out the rear of the truck. It keeps mu truck much cleaner and looks neater with the smoke coming from the rear. You get a new header with the pipe and it mounts right behind your rear body posts. It's adjustable. You move a cotter pin inside the pipe increasing or decreasing the tension on a spring. The spring acts like a baffle. The more tension on the spring the higher the rpms it takes to move th baffle back. I have yet to really mess with this too much because of inconsistent weather. Eventually I will try all the settings to find out how they effect performance. As of right now there is a definite increase in low end torque. I am not popping wheelies because of colder temperatures, but I did notice the last time I was out the definite possibilities of them. As for high end not a big difference, but there is some. The biggest thing I noticed was a lot smoother acceleration through all speeds. Another pipe I have heard a lot of goo things about is the Ritter Pipe. I will provide the link to that as well https://www.ssl-stormerhobbies.com/cgi-bin/seekpart.pl?pn=CVECZ700S https://www.ssl-stormerhobbies.com/cgi-bin/seekpart.pl?pn=RCR5152
I have a couple more products that will be coming tomorrow. Pro-Line Steering Kit, and RPM Skids. I am hoping the steering kit will take up some of the slack in the stock steering. It comes with ball bearings, so should make it smoother. It also has a built in servo saver, so no more need for the one on my steering servo. The RPM Skids will add needed protection to the underside of my truck. They mount over the stock skids, and also give you a tranny skid to protect the tranny.
As far as aluminum parts. I think the only ones I would consider would be alum. bulkheads. These are the heart of your front and rear ends and could stand to be a bit tougher.
RPM A Arms would be a good investment. They are plastic, but are a lot tougher than the stock ones. They come with lifetime replacement too, or so I have heard. If you break one you send it back and they send you a new one.
I hope this helps some. I know it's kind of long, but hopefully it will be of a little use to you. Congratulations on entering the world of the T Maxx. You will have a ton of fun. I know I am and there is more to come.....
"If it aint broke, then it's time to upgrade....."
       Post #: 9
Just bought a Tmaxx 2.5 - 3/21/2003 6:13:32 AM
PigMan Buggerus
Status: offline
Fantastic info! Thanks a lot guys!
       Post #: 10
T-Maxx 2.5 - 3/21/2003 6:16:57 AM
BigSkyRCFlyer
Status: offline
Hello All, I'm new here from the Airplane section. I just had to comment on the T-Maxx 2.5, I just bought one too. Man, I like this truck. The engine really woke up only after about the 2nd tank, it really started running well. I will however say I second the fact the Body mount posts are weak, I broke my rear ones only after the 3rd tank. I hit a small dip in the area I was running it, and it went straight up and landed on it's top. It also broke the Throttle Bell-Crank Post, and bent the Header slightly. Man does this truck have some power out of the box. I have all the parts on order now from Tower, except they were out of the body mount posts. I can't wait to break it in all the way and run it full bore. I am using Top Fuel 20%, and Trax Plugs. The only other RC Truck Experience I've had was with a Kyosho Wild Dodge Ram, and man does the T-Maxx Eat that up, about a 150% Difference , I am so happy with this truck. I can't wait to start adding after-market parts. It's great to read all of your tips and other's experience. RCU is great!
AMA-321950 A Day Flying-IS-a good Day-Period!
       Post #: 11
Just bought a Tmaxx 2.5 - 3/21/2003 6:40:16 AM
nitroman88-RCU
Status: offline
you should get some aluminum body posts
       Post #: 12
Just bought a Tmaxx 2.5 - 3/22/2003 9:43:56 AM
PigMan Buggerus
Status: offline
One other question. I have seen several suggestions to change the steering servo. What are the specs of the steering servo that comes on the truck? I am goin to upgrade my rudder servo on my Super Kraft cap 232 Sport, so I will have a Hitec hs-605 bb servo to put in the truck, if of course the 605 is better than the stock servo. The 605's specs at 4.8 volts are:
.17 sec. 60 degree travel
76.37 oz/in torque.
Is this better than the stock servo?
       Post #: 13
Just bought a Tmaxx 2.5 - 3/22/2003 11:14:30 AM
Wookie
Status: offline
It's about the same as the stock servo.
I upgraded to a Cirius Servo. I don't remember the model number off hand but it has complete metal gears, BB's and 121 oz/in of torque @ 4.8v. It's a little slow but works very well and only cost $25.00.
Check Tower Hobbies for some good inexpensive servos. You can get something similar to what I've got for around $29.00.
       Post #: 14
Congratulations! - 3/22/2003 12:29:36 PM
old skool
Status: offline
I would definitely invest in a high-torque steering servo. While there are some that go up to 200 oz-inches of torque (Airtronics 94258), if you get a quality ball-bearing steering kit you won't really need too much torque, since the steering will be more efficient than it would with mere bushings.
An old racer's trick is, once you get an aftermarket steering servo, to replace the stock throttle/brake servo with the original steering servo. More torque for better braking, you see.
RPM skid plate covers are a good idea.
Use NiCd or MiMh 1000MAh receiver batteries.
Break in the engine as per stated in the manual. You'll be rewarded with a sweet-running and powerful mill. The stock pipe is fine ( XR2PROBE, the AE will not work on the 2.5 header due to its downward slope). Wookie, I think that the stock plastic pipe is much quieter than that racket-maker on HPI's Savage!
Stock shocks are fine, I haven't touched my suspension settings for the past two months.
Where are you going to run? If you're going to race the T-Maxx, almost nothing beats Pro-Line's Bow-Ties!
