12Z and "LOGIC" Help!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Futaba Radios Direct support forum >> 12Z and "LOGIC" Help!!
Page: [1]
Login
12Z and "LOGIC" Help!! - 9/18/2007 3:03:57 PM
cfv007
Status: offline
If you are in the AFR/DR menu and you are at the screen where you select and assign switches to operate your rates, you come upon an option to select "single or logic". If you select "logic", you get another section below full of more selections regarding "single, logic, AND, OR, EX-OR".
I don't have a clue what ANY of this is about and of course there is not a single word about it in the wonderful manual.
Can someone explain to me clearly what all this stuff about logic is? I tried messing around with it to see what it does but just got WAY more confused. Maybe someone could give me a real life scenario about how it is used and what it means.
This "logic" stuff my also show up in other areas of the radio too, I'm not sure yet. I'm still learning the system.
Charles
_____________________________
If I'm flying it ... I built it.
       Post #: 1
RE: 12Z and "LOGIC" Help!! - 9/18/2007 10:31:35 PM
Bax
Status: offline
With the "Logic" function, you can set a dual-rate or condition to be active only if a certain event happens:
You can "OR" something...the setting takes effect if switch "X" is in one position OR switch "Y" is in a given position, or both are in the given position.
You can "AND" them...so the setting works only if switch "X" AND switch "Y" are in specific positions.
You can "EX-OR" them...so the setting works only if switch "X" is in a given position, or Switch "Y" is in a given position, but not both in the given position.
So you could have a surface go to a low rate when you flip a switch AND have the throttle below a certain point (or above a certain point). You're telling the system that you need to have two switches/controls a certain way before the rate (condition, action) happens.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to cfv007)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
