Slo-V Flyer
TX, USA Status: offline
quote:
ORIGINAL: weracerc what are you trying to accomplish? racing or bashing? speed or handling? 11.25:1 FDR is way to high (low) depending on how you see it.......for racing we run 72/28, 29, 30, 31........brushed and brushless 13.5 we run 66/33, 34, 35 or 69/33,34,35 FDR's in the 4.85 - 5.15:1 area...... With really tall gearing he is more likely to heat up the motor. Make sure nothing in the transmission is binding. The other reason the motor would heat up is if you have it geared with a pinion that is too large or maybe even too small. Have you tried a bigger pinion? That way the motor won't spin as fast. It is entirely possible you're pinion is too small, and so the 7700 motor is reaching it's max rpms and the bearings are actually spinning so fast it is heating up your motor? It might sound weird, but try a larger pinion. Being a touring car, I think you might be too under geared for that motor like Weracerc mentioned.
_____________________________
Emaxx+Feigao 7XL+full CVDs, Bandit+GTB 3.5R, Rustler+Feigao 9L, TC4+Mamba 5700kv, Mini-T+Mamba 8000kv, Recoil+3800kv, 3s lip
