Colombo-Anderson Models 27% 300L Build by RSlocum
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Trex 450 Pro a dealer cost! - Kit
Seller:  flyinghighrc
Details:   $475.00   |  11/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Kit Building >> Colombo-Anderson Models 27% 300L Build by RSlocum
Page: <<   < prev  1 2 3 4 [5]
Login
Colombo-Anderson Models 27% 300L Build by RSlocum - 6/17/2003 6:46 AM
William Robison
Score: 109
Last Login: 1/30/2007
Status: offline
Roger:
Let's see if it's small enough to post now.
Bill.
Click to see fullsize image.
Click for fullsize
_____________________________
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
Hide Signatures
(in reply to Slocum)
       Post #: 101
Colombo-Anderson Models 27% 300L Build by RSlocum - 6/17/2003 6:53 AM
William Robison
Score: 109
Status: offline
One more.
Bill.
Click for fullsize
Hide Signatures
       Post #: 102
Colombo-Anderson Models 27% 300L Build by RSlocum - 6/17/2003 10:12 AM
sizam
Score: 100
Last Login: 11/30/2004
Status: offline
Rslocum, could I get you to take a really close up picture of one of the top hinged robart hinges, I'm have a world of trouble getting it right on my test block.
Hide Signatures
       Post #: 103
Colombo-Anderson Models 27% 300L Build by RSlocum - 6/21/2003 7:56 PM
capthis
Score: 100
Last Login: 8/16/2009
Status: offline
Rog, are you still working on this? Don't give me any excuses like you are busy or anything.
Been there, crashed that!
Hide Signatures
       Post #: 104
Day 38 - 7/3/2003 7:13 AM
Slocum
Score: 100
Last Login: 12/12/2008
Status: offline
Finally back at it! Busy does not really cover the last few weeks. My car died, bought a new one, work out the kazoo and assorted family stuff. Also Thunder on the Ohio happened last weekend. This was the air show I was hoping to be done by, but on the plus side I got the meet the Firebirds and the Bulldog’s Jim LeRoy. They were all great and let me take some nice detail shots of the real planes. The Extra’s were shorter and better looking than I ever expected. The Sukhoi was taller then I expected and the engine smaller. A Pitts may be my next major project.
Tonight I got most of the right aileron hinging done. I have attached a photo from the end of the wing with the aileron pulled out to show how I am doing it. I did not get to glue the hinges in tonight do to a fit issue with the end of the aileron rubbing against the wing when it is lowered. It will be easy to fix but I did not have time tonight.
Click for fullsize
Independent AMSOIL Dealer
http://amsoil.poseyflyers.com
Hide Signatures
       Post #: 105
aileron hinges - 7/3/2003 7:43 AM
johnb300
Score: 100
Last Login: 11/19/2004
Status: offline
i have the same plane and was looking forward to this part of your post as i have never seen this type of hinge done before.just wondering did you use a jig or just real careful with the drill.and help you can give would be greatly appreciated.
thanks for this post...
Hide Signatures
       Post #: 106
Colombo-Anderson Models 27% 300L Build by RSlocum - 7/3/2003 8:27 AM
capthis
Score: 100
Status: offline
Last I heard he used a Jig Jig! Sorry Rog, but I just couldn't resist.
Hide Signatures
       Post #: 107
Colombo-Anderson Models 27% 300L Build by RSlocum - 7/3/2003 8:48 AM
InsaneFoamie
Score: 100
Last Login: 10/10/2009
Status: offline
just had to show a pic or two.second kit i have ever built.only had one flight but felt great!!!!
Click for fullsize
Hide Signatures
       Post #: 108
Colombo-Anderson Models 27% 300L Build by RSlocum - 7/3/2003 8:49 AM
InsaneFoamie
Score: 100
Status: offline
Click for fullsize
Hide Signatures
       Post #: 109
Colombo-Anderson Models 27% 300L Build by RSlocum - 7/3/2003 8:50 AM
InsaneFoamie
Score: 100
Status: offline
#3 HERE IS THE CAN I PUT IN IT.
Click for fullsize
Hide Signatures
       Post #: 110
Colombo-Anderson Models 27% 300L Build by RSlocum - 7/3/2003 8:51 AM
InsaneFoamie
Score: 100
Status: offline
LAST ONE, SORRY SO MANY
Click for fullsize
Hide Signatures
       Post #: 111
Colombo-Anderson Models 27% 300L Build by RSlocum - 7/3/2003 9:06 AM
William Robison
Score: 109
Status: offline
Asher:
The airplane looks good in both pictures, but the second should have been forgotten.
Why? Same reason I shouldn't post this one. Builder's picture.
Haw.
Bill.
Click for fullsize
Hide Signatures
       Post #: 112
Day 39 - 7/10/2003 7:46 AM
Slocum
Score: 100
Status: offline
Tonight I got the right aileron glued on. Then I completely mounted the left aileron.
My method for these went something like this. I start by taping the aileron on with masking tape on the top. Then I fold the aileron up onto the wing so that it looks like large piece of triangle stock. With it in this position it is easy to measure where I want my hinges and mark both pieces at the same time. I used about 10 cm spaces between. This may be over kill but I have never seen a plane crash because it had too many.
After I have the marks I use a hinge to mark the bottom of the hole using the thickness of the hinge in the middle. I do this for each mark. Then I used a piece of ¼ inch stock I had laying around and connected the dots for the bottoms of the hinges. Then I hand drilled using the balsa stock as a guide. There is a photo of this stage on page 5 post 93. It would make more sense if you flip the photo upside down.
Then I oil each hinge at the pivot point. This helps keep glue out. Then I put the glue in each hole in the wing. After the glue is in I also put a light coat on one side of the hinge to make sure the glue keys on the barbs and insert the hinges into the wing. After that I put glue in the aileron holes and on the barbs sticking out of the wing and press them together. Then I make sure the aileron moves fully in both directions. This will twist the hinges into alignment. I put a bit of masking tape on the joint just to make sure it does not separate and wait until morning.
Hide Signatures
       Post #: 113
RE: Colombo-Anderson Models 27% 300L Build by RSlocum - 10/25/2003 3:42 PM
capthis
Score: 100
Status: offline
Alright Rog, its been over three months now. Are you finished yet?
Hide Signatures
       Post #: 114
RE: Colombo-Anderson Models 27% 300L Build by RSlocum - 10/26/2003 1:11 AM
Slocum
Score: 100
Status: offline
Nope. Work over the last month or so has been a Witch! I have been making progress at a much slower than usual pace. At this point both wings are done. The fuselage is about 30% covered.
More as it happens.
Hide Signatures
(in reply to capthis)
       Post #: 115
RE: Colombo-Anderson Models 27% 300L Build by RSlocum - 10/26/2003 4:27 AM
capthis
Score: 100
Status: offline
pics, pics, pics! Please!!!!!!
Hide Signatures
       Post #: 116
RE: Colombo-Anderson Models 27% 300L Build by RSlocum - 12/2/2003 12:37 AM
Slocum
Score: 100
Status: offline
I know, I know, but finally some progress. Most what is left will not show. There is still some radio work to do. Also after I decide how much I like it, there is a lot graphically I want to do.
Click for fullsize
Hide Signatures
       Post #: 117
RE: Colombo-Anderson Models 27% 300L Build by RSlocum - 12/2/2003 1:40 AM
capthis
Score: 100
Status: offline
Bout, friggen time!
Hide Signatures
       Post #: 118
RE: Colombo-Anderson Models 27% 300L Build by RSlocum - 12/2/2003 1:44 AM
capthis
Score: 100
Status: offline
3/21/03 till 12/2/03. not quite 9 months to build. Unless of course the ending date is when you actually maiden the thing!
Did you run that DA yet?
Oh, and since I have heard it from you so many times. Where are the wheel pants?
Hide Signatures
       Post #: 119
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.438RCU1
