What's the cut-off voltage for a 9.9V 3s A123?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> What's the cut-off voltage for a 9.9V 3s A123?
Page: [1]
Login
What's the cut-off voltage for a 9.9V 3s A123? - 9/19/2007 4:02:41 AM
hobbygoblin
Status: offline
Hi! I have a Mamba Max ESC that has the ability for the user to set the cut-off voltage for lithium batteries. My question is... Since A123's are rated at 6.6V for 2s, and 9.9V for 3s, it fools the MM ESC because the MM ESC's auto lipo cut-off is custom programmed for 7.4V for 2s, and 11.1V for 3s. But I can also choose what cut-off voltage I want with the Castle Link software. Is there a specific voltage I should set the cut-off to for a 2300mAh 9.9V A123? Thanks for any help with this.
Joe...
_____________________________
~Traxxas XL-5 Stampede~Mamba Max 5700kV BL system~
       Post #: 1
RE: What's the cut-off voltage for a 9.9V 3s A123? - 9/19/2007 4:18:19 AM
bobferguson
Status: offline
Cut-off voltage for A123 cells is two volts per cell. I set mine about 2.2 volts per cell just to be safe. I try and not fly to lvc but use my timer to time my flight.
quote:
ORIGINAL: hobbygoblin
Joe...
(in reply to hobbygoblin)
       Post #: 2
RE: What's the cut-off voltage for a 9.9V 3s A123? - 9/19/2007 4:36:12 AM
hobbygoblin
Status: offline
Thanks for the quick help Bob. I'm guessing that since I drive an r/c Monster truck that a 6V cut-off would be fine since I would notice it slowing down before it actually goes down to 6V? Since you fly a plane, I'm assuming you'd have to give yourself enough extra time to land, hence the reason for the slightly higher LVC setting?
(in reply to bobferguson)
       Post #: 3
RE: What's the cut-off voltage for a 9.9V 3s A123? - 9/19/2007 4:39:37 AM
snellemin
Status: offline
I don't use any cutoff voltage. I just stop when I loose power. The drop in power is huge, so you can't miss it. But in the beginning I did set the voltage at 2 volts per cell. But it got annoying after a while since used 2, 3 and 4 cells packs.
< Message edited by snellemin -- 9/19/2007 4:49:18 AM >
check out www.Hamdrl.com
Snelle-RC,6S A123 FLM Rustler Dragster ,4S A123 Old school Promod, FrankenRusto Dragster
       Post #: 4
RE: What's the cut-off voltage for a 9.9V 3s A123? - 9/19/2007 4:43:45 AM
hobbygoblin
Status: offline
Ok, good to hear. Thanks snellemin. I'll be using the 3s primarily so I'll try the 6V cut-off. I won't be using my 6-cell IB4200 pack much any more, lol.
(in reply to snellemin)
       Post #: 5
RE: What's the cut-off voltage for a 9.9V 3s A123? - 9/19/2007 4:51:29 AM
bobferguson
Status: offline
Yes the like the extra time to land, but I also don't like pushing the limits, even if they are A123 cells.
       Post #: 6
RE: What's the cut-off voltage for a 9.9V 3s A123? - 9/20/2007 5:46:43 PM
SS Pede
Status: offline
Do you guys store your A123's at whatever voltage they ended up at after the run, or do you charge them back up part way?
       Post #: 7
RE: What's the cut-off voltage for a 9.9V 3s A123? - 9/20/2007 7:17:43 PM
snellemin
Status: offline
sometimes I store them depleted. But I usually fully charge them before storing them. Sometimes I use them after a week and it still has all its "power".
(in reply to SS Pede)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
