Mustang Exhaust
- Kit
Seller:tony-howard Details:
$35.00
| 9/21/2008
| Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
Forgot to say, here are the photos of the Yellow Aircraft wing joiners, the small section we are going to fix permantly into the wing centre section, attaching to the main spar, the longer section will be attached to the wing tips, when the tips are fitted the attachment screws can be got at through the retract well, not sure what to do about the trailing edge attachment yet? i may just fit a dowl to locate it? Sure does make me want to get back onto the old Corsair again!!
Joined: 9/18/2007 From: , UNITED KINGDOM Status: offline
HI LADS, A COUPLE OF ENGINE RUNS AT THE FIELD!!!! WHAT A SMOOTH ENGINE. ONE FLICK AFTER THE INITIAL PRIME,THEN IDLE. GREAT MOTOR. BRISON 4.2. MANUAL ADV AND RET. 24/10 MENZ.MORE PICS SOON. RAY
Looks like your just about ready to test fly your Corsair! its looking good! its amazing what 106" wingspan looks like when its put on its wingtip !!! .......well done mate!!
Graham.... you will get to meet Ray at the RAFMAA meeting in April, we will all be there!!
HI EVERYONE. WELL THE OLE GIRL FLEW THIS MORNING!!!!!!!!!! 3 CLICKS OF LEFT TRIM AND 2 OF DOWN TRIM. THE TAKE OFF WAS VERY SMOOTH,LOADS OF EVIDENT THRUST. CLIMED TO A GOOD HEIGHT AND FLEW AT 1/2 THROTTLE FOR 8 MINUTES. PULLED THE LEGS DOWN ,FULL FLAP ON FINAL APPROACH.NO HEADWIND, LANDED AT A SENSIBLE SPEED. VERY HAPPY BUNNY TODAY.
NEED TO MAKE THE COWL FIXING POINTS MORE POSITIVE,AND CHANGE TO GIANT ROBART PIN HINGES AS THE REST OF THE SURFACES HAVE. THEN ALL THE TASTY COCKPIT DETAILS AND MORE FINAL WEATHERING . AT A LATER DATE,I NEED A BASIC IDEA FOR THE FITTING OF MAIN RETRACT DOORS TO THE MAINS.MAY FIT A RETRATABLE TAIL WHEEL WHEN FUNDS ALLOW. THAKS RAY
congrats Ray, seeing as i cannot sell mine for the silly low sum i am asking, i think it will get finished now you have lit my flame again, have a great season
quote:
ORIGINAL: alanc
THANKS FOR YOUR KIND WORDS ALAN. GOOD LUCK TO YOU. SEE YOU SOON. RAY
NE, USA Status: offline
Ray, congratulations. Now you gotta get some video. So does it have what I call "presence " in the air? WE want details man details. Were like druggies and we need a fix.
[/colorGOOD EVENING FOLKS, ENJOYED MYSELF TODAY,FINISHING THE COCKPIT. GREAT FUN.IT`S TAKING SHAPE,THOUGH ITS HARD ALWAYS NOT ADDING WEIGHT. I HAVE AN AH DESIGNS 1/5 SCALE. LOOKS OK FOR SIZE. PICS ON THE WAY. JUST ABOUT TO START A TOP FLITE DUMMY ENGINE. IT LOOKS GOOD FOR SCALE. WILL REPLACE THE PUSHROD TUBES IN THE KIT WITH 2.4MM ALLY TIG WIRE. WILL SEND PICS SOON.
NEED SOME HELP ON FIXING THE LEG FAIRINGS ONTO MY ROBART 150 ZRETRACTS. ANYONE HAVE EXPERIENCE WITH THESE??? OZ
Heres a couple of pics lads. yes i`m still learning,but having fun as well. Will make the leg pants soon. thinking about how to do it at the moment though. REGARDS RAY
Looking good mate!! all those details are what makes a scale aircraft, keep up the good work, i build my cockpits in sections at a time, il try and find some photos, i make fairings from lithoplate with a thin ply backing to strengthen them up, i make 'stand offs' from either ply or hardwood just glued to the keyed leg, you could make up small straps to go round the leg, then bolted through the doors? ill take some close ups while im down the workshop tomorrow night to try to help.
