Taco - FAT FREE
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> Taco - FAT FREE
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
Taco - FAT FREE - 4/1/2003 9:46:38 PM
latch66
Status: offline
Paul,
So far, which method do you prefer? The landing gear straps or the ply supports?
Thanks.
_____________________________
Proud Member of the 1% RC Community!
(in reply to PaulSwany)
       Post #: 51
Taco - FAT FREE - 4/1/2003 9:49:59 PM
PaulSwany
Status: offline
Not sure yet... Jurry is still out.... If I had to pick today... I like the ply supports, but build a little closer to the fuse.. The last set I did, the rods ran about 3/16" from the fuse.. I'd like to do it again, but with only 1/16". Would look cleaner.
       Post #: 52
Taco - FAT FREE - 4/1/2003 10:03:55 PM
m.gramling
Status: offline
Paul thats a sweat looking plane.
Everybody wants to go to heaven, but nobody wants to die...
       Post #: 53
Taco - FAT FREE - 4/1/2003 10:28:53 PM
latch66
Status: offline
Paul,
Have you tried using a ply spacer between the landing gear strap and the fus side?
       Post #: 54
Taco - FAT FREE - 4/1/2003 10:45:29 PM
PaulSwany
Status: offline
no.... I used a tube inside of the lg strap... worked okay... the 2x56 rods I used were just a little tight in the tubes....
       Post #: 55
Consider this method - 4/1/2003 10:54:42 PM
kevin4hsrcm
Status: offline
Run short sections of Sullivan Golden Rod Jackets (red). About 3" long. Then cut 1/8" lg. sections of the golden rod and slide them on your 2-56 control rod so that they run inside the jacket. I prefer to run the entire 2-56 rod thru the red jacket, then put an 1/8" pc. of yellow golden rod about every 2 inches. Then support the red jacket every 2 - 3 inches when pull-pull is out of the question, or a Dave Brown rod set-up won't work. I would have to say that this method is my third choice, though sometimes the set-up will not allow for my 1st & 2nd choices Thats life! Hope that this helps with another alternative.
Kevin
Kevin
http://www.hsrcm.com
       Post #: 56
Oh WOW! - 4/1/2003 10:55:35 PM
ChuckAuger
Status: offline
Man, I haven't looked in on this thread in a day or so..
That thing is just ultra-cool. Really, you have one great scheme there Paul.
Breaking the Speed of Sound, Straight Down!
       Post #: 57
just an idea... - 4/1/2003 11:37:15 PM
matlok
Status: offline
Try putting the elev/rud. servos in the tail on the next one....
Moving the motor all the way foreward and putting the throttle servo right behind the motor (use motor rails as servo rails) was enough to balance mine w/o adding any extra weight. Then the linkages are only about 3" long, and much tighter.
       Post #: 58
Taco - FAT FREE - 4/1/2003 11:37:28 PM
PaulSwany
Status: offline
Thanks Chuck!!
       Post #: 59
Taco - FAT FREE - 4/3/2003 1:39:20 AM
PaulSwany
Status: offline
Just got back from flying the Fat Free Taco!!! Awesome!!! I can't believe how nimble this thing is... It was waaaaay to windy to do a maiden... but I couldn't wait... Climbing flat spins, both upright and inverted... Loops on it's tail.... Knife edge with very little coupling... Seems to harrier and hover good... but it was hard to tell with the wind... Did some knife edge hovering 'cause the wind was soo strong... Very cool...
I like this design better that the sheeted version... You can frame up this plane in 3 - 4 hours!!! I'm going to kit it.... Mark Shope is gonna do the cutting.
Fully CNC machined kit, all you need is some 3/16 sq, 1/4 sq 1/4 x 3/8 and 1/16 sheeting. Kit includes 1/4 fiberglass rod, carbon fiber for spars and pre bent landing gear with blocks.
All the main pieces are machined for you... all you have to do is some sq. cuts.. hardly any fitting.... Mark has really got it going on with engineering the kit for a strong easy building plane.
I'm gonna sell 'em for $43.
< Message edited by PaulSwany -- Apr 2 2003 8:59PM >
       Post #: 60
Taco - FAT FREE - 4/3/2003 1:41:49 AM
Billy Hell
Status: offline
Now you are "Paul Swany - designer of the Fat Free Taco". Congrats man!
       Post #: 61
ProBro - 4/3/2003 1:42:25 AM
Billy Hell
Status: offline
Maybe you would like to donate one for the Pro Bro Funfly!
       Post #: 62
Taco - FAT FREE - 4/3/2003 1:42:59 AM
PaulSwany
Status: offline
Sure... I'll donate one for the fly in...
       Post #: 63
Taco - FAT FREE - 4/3/2003 1:45:32 AM
Billy Hell
Status: offline
That's my first prize! You are number one on the vendor list.
       Post #: 64
Taco - FAT FREE - 4/3/2003 1:55:50 AM
latch66
Status: offline
[QUOTE]Originally posted by PaulSwany
Sure... I'll donate one for the fly in... [/QUOTE]
Paul,
Your allright Man!
I don't care what I've said about you in the past!:p
