35%extra260q.b firewall factory install upside down
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> 35%extra260q.b firewall factory install upside down
Page: [1]
Login
35%extra260q.b firewall factory install upside down - 9/22/2007 1:59:50 AM
winginit69
Status: offline
35%extra260 q.b firewall factory installed upside down!, if you are looking at the plane from the front the off set is to the left,should be on the right, anybody else have this problem?
       Post #: 1
RE: 35%extra260q.b firewall factory install upside down - 9/23/2007 1:02:08 AM
winginit69
Status: offline
can i get some help here please.i want to fill the wholes and drill new ones in the right place i am waiting for a reply to make sure before filling the holes, am i wrong should the thrust line be on the right side if you are sitting in the plane? thank`s
(in reply to winginit69)
       Post #: 2
RE: 35%extra260q.b firewall factory install upside down - 9/23/2007 1:40:07 AM
reyn3545
Status: offline
If you are sitting in the pilot seat looking forward, the center hole, engine mount holes and cross-hairs (if they're on there) should be to the LEFT. The engine will mount to the box, pointed slightly to the RIGHT, so you need it mounted slightly to the LEFT of center in order to keep the spinner somewhat centered on the cowl.
< Message edited by reyn3545 -- 9/23/2007 1:41:08 AM >
       Post #: 3
RE: 35%extra260q.b firewall factory install upside down - 9/23/2007 2:17:00 AM
bodywerks
Status: offline
That is the first I have ever heard of from any arf. Do you have pics? If it is offset as you say, it is wrong and the holes do need to be redrilled. No biggie, just find center, measure the current offset to the left and duplicate it to the right. Also make sure the height is correct. If not, correct it.
_____________________________
STRAIGHTEN UP AND FLY LIGHT!!!
(in reply to reyn3545)
       Post #: 4
RE: 35%extra260q.b firewall factory install upside down - 9/23/2007 4:43:59 AM
winginit69
Status: offline
here is a pic of the firewall, i didn`t notice until i mounted the engine , i didnt even give it a thought after using the template ,i new it was back words but i had to hear it from someone,thank`s for your help
Click to see fullsize image.
Click for fullsize
< Message edited by winginit69 -- 9/23/2007 5:05:52 AM >
(in reply to bodywerks)
       Post #: 5
RE: 35%extra260q.b firewall factory install upside down - 9/23/2007 5:42:08 PM
reyn3545
Status: offline
Yep... it looks backwards to me. Never seen that before. I'd send AW the picture and see if they can shoot you a new fuse, or you could just re-drill, depending on how much work you've done on the fuse already.
       Post #: 6
RE: 35%extra260q.b firewall factory install upside down - 9/23/2007 7:37:23 PM
winginit69
Status: offline
yep im going to ask for a new fuse,
       Post #: 7
RE: 35%extra260q.b firewall factory install upside down - 9/25/2007 2:25:19 AM
bodywerks
Status: offline
Dude, I'd just redrill it. You will in no way compromise the structure as a result, and you won't have to wait another 3-5 days for the new fuse and hope it gets to you undamaged! You know how those UPS goons handle packages...A redrill will cost you 45 minutes and a little extra wear on your drill bit and pencil.
       Post #: 8
RE: 35%extra260q.b firewall factory install upside down - 9/25/2007 1:00:01 PM
3D Joy
Status: offline
Having a spare fuselage is what is actually interesting here...
If I can use the supplied template and drill 4 holes, everybody can.
       Post #: 9
RE: 35%extra260q.b firewall factory install upside down - 9/25/2007 5:41:45 PM
zzw26n
Status: offline
quote:
ORIGINAL: bodywerks
bodywerks,
I've followed a few of your Threads, you would be the 1st one to send it back! your a perfectionest.
       Post #: 10
RE: 35%extra260q.b firewall factory install upside down - 9/25/2007 7:11:01 PM
reyn3545
Status: offline
OK.... here we go! An Arizona Michigan slugfest!
Come on, bodyworks, don't just stand there and take that kind of abuse!
< Message edited by reyn3545 -- 9/25/2007 7:13:51 PM >
(in reply to zzw26n)
       Post #: 11
RE: 35%extra260q.b firewall factory install upside down - 9/25/2007 8:42:02 PM
bodywerks
Status: offline
LOL! I have changed a bit over the past year or so, especially after accepting the fact that there are no absolutes when it comes to chinese ARFs. Everyone remembers the EF 50cc twisted fuse situation, right? I fixed that instead of sending it in. I also have another ARF that had structural failure, causing damage to the fuse. I offered to fix the fuse if they would just expedite the other replacement parts. They replaced the whole kit, anyway, but I still repaired the fuse since the repair would be quicker than reinstalling all my equipment.
Don't get me wrong, the guy has every right to want a new fuse, but redrilling it would be easier/quicker/less hassle.
I am thinking that this should cue Aeroworks to understand that the only way to make sure it doesn't happen again is to have the engineers key the firewall and engine box asymmetrical so that it will only fit one way...
       Post #: 12
RE: 35%extra260q.b firewall factory install upside down - 9/26/2007 1:05:40 AM
winginit69
Status: offline
3djoy i resent the fact of you are accusing me of just wanting another fuse! where were you when i asked for help 4 day`s ago? if you read the thread you would see that i asked for reassurance to the correct position of the thrust line,before i RE DILLED NEW HOLES, i didn't mention a new fuse till somebody said it.after all ,should it be right for the money?
and i already re drilled new holes and mounted the engine BEFORE i even called aeroworks to let them know ,and i didn`t ask for a fuse!
       Post #: 13
RE: 35%extra260q.b firewall factory install upside down - 9/26/2007 1:21:53 AM
bodywerks
Status: offline
I don't think he was accusing you. I think he meant that Aeroworks might not even have a spare fuse to send to you. I am also sure they would give you a shipping label to return your fuse, too, if they did have spares. I am glad you simply drilled new holes. You're gonna love this plane!
       Post #: 14
RE: 35%extra260q.b firewall factory install upside down - 9/26/2007 1:52:02 AM
3D Joy
Status: offline
I guess I was having a bad day telling that...
I'm not on RCU every day and even less in the AW forum, sorry for not catching your thread when it was time.
Bodywers is right, they should only key the firewall for one way install.
Bodywerks is also right in that you will love this plane! I do love mine and even though a 40% is in the way, I still plan to fly it next year!
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
