gasoline engine business for airplane
Tower Hobbies
Logged in as Guest
  Printable Version
Composite-ARF Extra 260 2.6m - RTF
Seller:  96918
Details:   $4,300.00   |  11/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Product Announcements & Manufacturer News >> gasoline engine business for airplane
Page: [1]
Login
gasoline engine business for airplane - 9/22/2007 2:48:56 PM
johnnynb
Status: offline
Zhejiang RCGF Engine &Model Co.,ltd situated in the Foreign Trade Mansion of Longyou City Zhejiang Province ,established in 2003 ,is one of the professional manufactures in various of gasoline engines ,specially in model aircrafts .we are top manufactory,we have best quality.
We have our own research and development department ,and offer OEM Service for you . And we can produce all kinds of engines according to your requirements .
We have sold our engines all over the world ,such as Australia , Germany ,Singapore ,England etc . Now we want to find more agents from all over the world ,if you are interested in welcome to join us
We sincerely look forward to cooperation with you.We will supply you the professional technical supply and best after service .
we offer 26cc,45cc,65cc,50cc etc for R/C airplane
website:www.rcgf.com.cn
Email:rcgfservice@yahoo.com.cn
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by johnnynb -- 9/24/2007 2:28:59 PM >
       Post #: 1
RE: gasoline engine business for airplane - 9/22/2007 8:05:34 PM
pe reivers
Status: offline
I have a few questions for you, all pertaining to fitness for use of the engines:
1) are all crankshafts well in line front to back using a tolerance of within 0.01mm true and straightness?
2) are big end bearings and wrist pin cage ends of the conrods restricted in axial movement?
3) are all bearing seats machined to the required tolerances? (not as-cast?)
4) is the prop drive taper matched to the crancshaft taper, so the drive does not wobble?
5) are prop drives assembled without epoxy glue?
6) are crankcase halves pinned together for alignment retention?
7) are the piston rings bottom sealing surfaces flat?
8) Does the design prevent gasoline puddling in the crankcase?
9) Are the carb membranes resistant to US and European oxygenated gasoline?
10) are all engines clean inside and not full of silicone gasket debris?
11) do you use low quality fancy chromed bolts and studs, or high quality zinc plated items?
11a) Does the thread on the bolts match with the tapped threads tolerance range?
12) will the supplied tools be up to the job? (allan keys, spark plug wrench, prop drive wrench)
13) Are the mufflers made of very soft, or medium hard aluminium that will resist bolt torques?
14) will the long muffler stacks not tear off by engine vibration?
15) what ignitions do you fit? Timing data? Life expectancy?
16) do all bolt length in the aluminium follow the rule that the bolt screw thread engagement should be at least 2 times bolt diameter?
17) is the crankcase CNC machined or cast?
18) if cast, is it done in ductile material, or brittle for best cost effective casting?
I could go on, but this should do for the moment.
< Message edited by pe reivers -- 9/22/2007 8:12:18 PM >
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
(in reply to johnnynb)
       Post #: 2
RE: gasoline engine business for airplane - 9/23/2007 4:11:16 AM
Rfabbre
Status: offline
Jphnnynb,
Do you have a website? Picture of your 50cc engine? Minimum order quantity?
Thanx Rich
(in reply to pe reivers)
       Post #: 3
RE: gasoline engine business for airplane - 9/24/2007 2:39:34 PM
johnnynb
Status: offline
Jphnnynb,
Thanx Rich
Dear rich
this is our website:www.rcgf.com.cn
and we will very glad to hear from you and talk about engine business.our minimum order is five pcs
this is our email address:rcgfservice@yahoo.com.cn
(in reply to Rfabbre)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU3
