mrasmm
Joined: 1/9/2007 From: Sometown, Northern Utah, USA Status: offline
quote:
ORIGINAL: shufflez And Mrasmm, i'm now using WD40, which works fine, but it 'collects' quite a lot of dust and other stuff. Is the teflon stuff less prone to have that problem? I've tried the 'doorlock lube' stuff, with graphite, which works but seems to wear off quite fast causing friction (probably due to the graphite) ? yeah, the teflon stuff definately is alot better. It is dry and more like a film rather than a powder so it doesn't come off all that easy. Read this review for more info quote:
ORIGINAL: BryFlyGuy67 I would like to hear the brand names of the Teflon lube. Teflon lube and other "dry" lubes are perfect for a Heli, since they go on wet and then dry. I have not worked with Teflon lube, but I have used many graphite-based ry lubes in other applications to good effect. The brand I am using is dry ice and it works great. It doesn't really matter what you get as long as it goes on wet and then dries and doesn't have a pretolium based propellant, so basically you have to dap or squirt it on rather than spray it on like wd40 or something. dry ice review http://www.rcuniverse.com/magazine/article_display.cfm?article_id=784 quote:
ORIGINAL: stump3r As far as cooling goes I have the heat sinks on, vented canopy etc. the only thing i haven't vented is the 4in1. Guess I could get rid of more weight as well. If you think you'll be cont drawing 4A or more then you'll just need to heatsink the FET's (parts marked 7313, if I remember right the parts are 8 pin dips), an dthey can handle up to 6A each cont when they have a heatsink on them.
_____________________________
I don't always check every thread I respond to, so feel free to PM me
