Somewhat semi-scale AX-10 build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> Somewhat semi-scale AX-10 build
Page: [1] 2   next >   >>
Login
Somewhat semi-scale AX-10 build - 9/23/2007 5:47:59 PM
webdr
Status: offline
Heres my AX-10 K5 Blazer in the works.
Electronics;
Novak Goat brushless motor and esc
Spektrum DX2.0
Protek RC 7.4v 2 cell lipo
Hightec high-torque metal gear servo
Kreepy Krawler 2.2 narrow foam red/pink
Mud Slinger 2.2 tires
Delrin "holes" rock rings
The body is still in the making but heres a preview.
Still waiting for the kit to arrive so many pictures to come.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by webdr -- 10/9/2007 1:23:16 AM >
_____________________________
Matt G.
RCUniverse Senior Surface Editor
Atlanta, GA
       Post #: 1
RE: Somewhat semi-scale AX-10 build - 9/23/2007 5:55:34 PM
bigmodman
Status: offline
looks like it is gunna be awesome!
when you arent in the mud you arent having fun!!!♠birdy♠customs♠
(in reply to webdr)
       Post #: 2
RE: Somewhat semi-scale AX-10 build - 9/23/2007 6:58:47 PM
Anomie
Status: offline
That body is really nice
Did it start as a Clod body? Or something else? It looks much more detailed than that, actually.
I have a Clod body that's being made into a Blazer and is partially finished. I'll post a pic shortly.
~Reiko~ RCU Car Forums Moderator
Yearning for some semblance of understanding.
(in reply to webdr)
       Post #: 3
RE: Somewhat semi-scale AX-10 build - 9/23/2007 7:35:44 PM
webdr
Status: offline
Its a proline k5 blazer body painted on the outside and scuffed to hell!
Matt G.
Atlanta, GA
(in reply to Anomie)
       Post #: 4
RE: Somewhat semi-scale AX-10 build - 9/24/2007 3:35:06 AM
annie_himself
Status: offline
quote:
ORIGINAL: webdr
It looks like a real full scale body taken off the chassis. Good job.
Saldly, 98% of teens have switched to rap music, if you're part of the other 2% that like real hip-hop put this in your sig.
(in reply to webdr)
       Post #: 5
RE: Somewhat semi-scale AX-10 build - 9/24/2007 9:50:51 PM
webdr
Status: offline
Look what showed up today...
Click for fullsize
Click for fullsize
Matt G.
Atlanta, GA
(in reply to webdr)
       Post #: 6
RE: Somewhat semi-scale AX-10 build - 9/24/2007 11:05:22 PM
webdr
Status: offline
Heres a few more pics of the body, 99% done. I added some genuine redneck stickers and a few rust spots.
Click for fullsize
Click for fullsize
Click for fullsize
Matt G.
Atlanta, GA
(in reply to webdr)
       Post #: 7
RE: Somewhat semi-scale AX-10 build - 9/25/2007 2:25:24 PM
nickrummy
Status: offline
That is a killer job on the body! Care to share your painting technique? I have a K% body sitting around. Waiting to finish up my rc shop because I plan on making a tube chassis for it. I want to make it look like a trail beater like yours. Did you first spray a brown color, then primer grey and then your final color? then sand down certain spots? I thought about painting the brown on the inside and the primer and final color on the outside. That way if it scrapes up while running the rust color won't get scraped off.
(in reply to webdr)
       Post #: 8
RE: Somewhat semi-scale AX-10 build - 9/25/2007 5:39:51 PM
webdr
Status: offline
I sprayed brown on the inside, primer gray on the outside and duplicolor yellow from Pep Boys on top. I then sanded the whole thing with 600 grit and spot sanded to bring the gray through. There are no spots that show through to the brown cause it doesnt look good with the lexan over the brown. All the rust spots are applied with a q-tip then sanded with 600. The lines between body panels are applied with a felt tipped pen, then immediately wiped off, leaving a darker line but not black.
after it dried, Ive found it almost impossible to scratch off. With the primer and the top coat yellow, it has made a shell of paint that I doubt will gouge away in a roll, but we will see.
Matt G.
Atlanta, GA
(in reply to nickrummy)
       Post #: 9
RE: Somewhat semi-scale AX-10 build - 9/25/2007 6:29:59 PM
nickrummy
Status: offline
Exactly what I was planning on doing with the exception of the felt tip pen. That trick will be added though! thanks a lot!
(in reply to webdr)
       Post #: 10
RE: Somewhat semi-scale AX-10 build - 9/25/2007 11:45:39 PM
webdr
Status: offline
Nick, I saw your 3d on the other site. I use C4D also...
Matt G.
Atlanta, GA
       Post #: 11
RE: Somewhat semi-scale AX-10 build - 9/26/2007 7:25:42 PM
nickrummy
Status: offline
quote:
ORIGINAL: webdr
What do you use it for? I don't use C4D much at all. The designers do and I taught myself how to use it just to get by.
(in reply to webdr)
       Post #: 12
RE: Somewhat semi-scale AX-10 build - 9/26/2007 11:55:33 PM
webdr
Status: offline
I just use it to mess around. Some web graphics for work. Heres a roll bar I made for my 1:1 jeep and ended up working out well.
Click for fullsize
Click for fullsize
Matt G.
Atlanta, GA
       Post #: 13
RE: Somewhat semi-scale AX-10 build - 9/27/2007 1:39:20 PM
nickrummy
Status: offline
Nice! Ever mess around with the animation on it? Man that is cool stuff. Kind of a pain but cool.
I went to an on hand software demo yesterday for the new Autodesk Inventor. Man do I want that software......
(in reply to webdr)
       Post #: 14
RE: Somewhat semi-scale AX-10 build - 10/1/2007 11:42:59 PM
webdr
