Lead acid battery problems    Gallery
Logged in as Guest
    Search This Thread
Printable Version
THE "ORIGINAL" FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $230.00   |  2/4/2012   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Lead acid battery problems
Page: [1]
Tower Hobbies Today's Special Offer! Brands Products
Login
Lead acid battery problems - 9/23/2007 10:16 PM
9c
Score: 100
Last Login: 6/24/2009
Status: offline
hello everyone,
I have a 2 year old 12V 7.5A hobbico "flight box" battery. After charging with a 12V .5A "wall wart" charger yesterday for 18 hours, i went to the field and tried to start my helicopter, but to no avail. The starter wouldn't even turn over the enging one time. I'm positive the engine wasn't flooded. After i hooked it up to my mini-vans starter batter (car battery), the starter easily turned over the engine, and started. After i came home i discharged the flight box battery with a Triton Jr. (no small feat, it discharges at a max of like .3 A for this battery) and it only had around 200 miliamps left in it. is it just me? or does 7.3 amps of power go away in trying to start a .50 size helicopter engine just once? what going on here, and can anyone help?
Hide Signatures
       Post #: 1
RE: Lead acid battery problems - 9/23/2007 10:53 PM
Red Scholefield
Score: 191
Last Login: 2/9/2012
Status: offline
quote:
ORIGINAL: 9c
hello everyone,
There is a good chance that your 2 year old battery has breathed its last. You might give the Triton a shot at it, but don't be surprised if it doesn't get well. A 2 year life on these batteries is not at all uncommon. You might try another source as these are as common as dirt in the battery world. Some place that sells emergency lighting batteries. Also much to my surprise I found them at Farmer's Tractor and Supply. I guess they use them for electric fence or gate openers. Anyway a farm supply place might be a good place to look. Office Depot might be another source as these are the same batteries they use in computer UPS systems.
_____________________________
Red S "AMA 951 since 1958
Hide Signatures
(in reply to 9c)
       Post #: 2
RE: Lead acid battery problems - 9/24/2007 1:28 AM
mrasmm
Score: 105
Last Login: 3/10/2011
Status: offline
once you get a new pack a good way to prolong its life is to put the SLA on a float charger. You can get one from harbor freight for 6 bucks, or a better quality one from walmart for about $20 bucks or so. I put all my SLA's in a bank on a float charger, and that just keeps them in top condition and keeps the plates from getting too low of voltage which keeps the plates from suplating. They'll last alot longer that way.
Basically if the volts go to low on any lead acid battery the suplur perminantly deposits in the lead which decreases the acid (ie sulphuric acid) which slows down the electrochemical process, and it also ruins the patch of lead where it perminantly gets deposited which decreases surface area which is basically is the Ah and CC.
I don't always check every thread I respond to, so feel free to PM me
Hide Signatures
(in reply to Red Scholefield)
       Post #: 3
RE: Lead acid battery problems - 9/24/2007 4:01 AM
Red Scholefield
Score: 191
Status: offline
Float keeps them from going dead (below 1.8 volts/cell), but if you watch the voltage and charge when it gets down to 12 volts (no load) you will get even better service out of them. Fortunately the self discharge is fairly low, so a fully charged battery should last for 2 or 3 months minimum before you need to charge it.
Hide Signatures
(in reply to mrasmm)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
0.844RCU1
