ST 90 Idle problem
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> SuperTigre Engines Support >> ST 90 Idle problem
Page: [1]
Login
ST 90 Idle problem - 9/24/2007 12:38:22 AM
superdave01
Status: offline
Enigine runs fine, transition and midrange is great and the top end is really strong.
Problem:
Idle is fine....... for 1-30 seconds then it stops like like a kill switch was flipped.
It dont speed up or slowly slow down when it dies, its sudden and varies on time.
I feel i have the needles on the money.
Is this a predetonation problems with the fuel im using? Omega 15%, Works great in the 12 other planes and helis i have.
_____________________________
Idiots ignored for free!
       Post #: 1
RE: ST 90 Idle problem - 9/24/2007 4:13:28 PM
Bax
Status: offline
Without seeing the engine, and taking time to set up the carb, we'd not know what the difficulty may be. However, it does sound like the idle's a bit rich and the engine's loading. Here's how to set up the carb:
http://www.rcuniverse.com/forum/m_1579985/tm.htm
You'd only get detonation at full throttle. There is no such thing as "predetonation". Model engines will detonate at high throttle settings if the fuel has too much nitro, the compression's too high, if it's overloaded, or allowed to run too hotly.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to superdave01)
       Post #: 2
RE: ST 90 Idle problem - 9/24/2007 6:43:49 PM
superdave01
Status: offline
The engine does not load up and is not rich, ive went way past rich and way past lean to make sure, been in the hobby for 28 years.
A guy at the field told me he has 2 Supertigres and neither would stay running, He changed fuel to some kind thats labeled "for Supetigre" and he said once he did all is fine, he said he made no other adjustments.
The supertigre 60 i had for over 20 years ran fine on anything i gave it, lst year it threw a rod finally.
The idle on this new one is super stable and does not change up or down, it just dies instantly after 1-30 seconds.
Ill remove and clean the carb i guess but its weird.
(in reply to Bax)
       Post #: 3
RE: ST 90 Idle problem - 9/25/2007 3:42:27 PM
Bax
Status: offline
Please follow the suggested procedure. If you don't, you may likely never get the engine set correctly. 'Tigres do need to be set up carefully, and you must start out with a too-rich idle, get the top-end dialed-in, and then go for the idle. Many people get the idle first and then find out that the engine just won't set up well at all.
       Post #: 4
RE: ST 90 Idle problem - 9/25/2007 6:00:28 PM
superdave01
Status: offline
I always start out rich and peak the top end first.
Using a OS "F" Plug it idles forever so i guess problem solved.
(in reply to Bax)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.407RCU3
