SSE maiden flight
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> SSE maiden flight Page: [1]
Login
SSE maiden flight - 9/24/2007 1:20:43 AM
troposcuba
Status: offline
well, finally got the SSE arf up there today. pretty uneventful. i flew my fun51 around a bit first to warm up. I was a little surprised that the SSE seemed a bit calmer than the profile plane even with the throws set a bit larger than the manual states. 2 clicks of down ele and she was perfect. now i just have to wring it out and see what i can make it do.
oh yeah, the new .55AX on it didn't even hiccup either. course i have run about 6 tanks of fuel through it already (5 on the stand, and one horsing around in the yard before i flew the plane. good thing too, the clevis popped off the rudder in the front yard playing around with the ground handling. that woulda sucked on the first flight. seems i forgot to push my little piece of fuel tubing on the clevis. oops. so i think that might have saved the plane.
anyways, cheers everyone.
_____________________________
at 'em boys, give 'er the gun!
       Post #: 1
RE: SSE maiden flight - 9/24/2007 12:07:12 PM
yel914
Status: offline
Congrats on that maiden! Photos?
WACO Brotherhood #24
(in reply to troposcuba)
       Post #: 2
RE: SSE maiden flight - 9/24/2007 5:33:12 PM
troposcuba
Status: offline
I haven't taken any, i figured it was bad luck to take pics before it flew. besides anyone that has seen the SSE arf has seen it. i will get some pics up. but it is pretty much plain jane. i didn't sticker it except where i accidentally put the switch in the way of one of the servos and had to fill the hole back up with epoxy. it got a sticker to cover the hole.
pics soon to follow.
(in reply to yel914)
       Post #: 3
RE: SSE maiden flight - 9/25/2007 12:22:35 PM
yel914
Status: offline
Please post closeup of sticker!
       Post #: 4
RE: SSE maiden flight - 9/25/2007 10:47:39 PM
troposcuba
Status: offline
quote:
ORIGINAL: yel914
can't do that man... you would then see about the shoddiest (is that a word?) part of my assembly. the only other 2 regrets in the assembly (notice i didn't say build, since it is an ARF.) Were snapping the screw off in the blind nut in the tail for the empennage support wires due to epoxy in the blind nut, and ugly masking tape in the wedge block that i epoxied to support the throttle cable. i couldn't get the masking tape that i put in there to keep the epoxy application clean out of the epoxy since i waited too long to remove it not wanting to break loose the epoxy. so now i have a bit of bright green tape stuck in there forever.
sounds picky actually since you can't see the inside and it flew beautifully... better than i expected for a first flight by far!
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU3
