10 minute flight...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> 10 minute flight...
Page: [1]
Login
10 minute flight... - 9/24/2007 4:42:42 AM
aland25
Status: offline
Ok, I just got done flying my HBK2 for 10 minutes solid. During the flight, on three different occasions - all at different durations of the flight - I noticided the heli experienced a twitch or glitch, where the heli jolted for a half second and then resumed normal flight. Almost as if it lost total power, but just for a fraction of a second.
I am using the stock transmitter, HH Gryo, stock servos, 25A ESC and the 3900 esky motor.
Could it be the transmitter?
Thanks in advance for any help.
Alan
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: 10 minute flight... - 9/24/2007 1:51:21 PM
USHobbySupply
Status: offline
Definitely sounds like a glitch. Other sources of radio transmisstions near by? Batteries in tx new? even slightly old ones (that still show good strenght in the light indicator) can be suspect. metal to metal contact? rx to close to esc?
_____________________________
Michael Bernstein, President, USHobbySupply
Please PM me if I miss you question in a thread
(in reply to aland25)
       Post #: 2
RE: 10 minute flight... - 9/24/2007 2:11:35 PM
aland25
Status: offline
quote:
ORIGINAL: USHobbySupply
I do not know of any other radio transmissions...as this was about 10pm. The batteries are the Dracell 2650 MaH rechargables with solid strength on the battery meter. Check out the picture I included and see if you think the ESC is too close to the rx.
(in reply to USHobbySupply)
       Post #: 3
RE: 10 minute flight... - 9/24/2007 2:12:18 PM
chris6414
Status: offline
Your ESC looks to be within 1 inch of your receiver. Put is up front. Second, if you are using a cheaper PPM receiver, they know to be very good listeners to outside int. I too have the same issue occasionally with my Belt CP and use the same servos and motor. I just swapped out my Dynam 6 ch with a Berg 7P to see if that helps my issues.
       Post #: 4
RE: 10 minute flight... - 9/24/2007 2:34:14 PM
aland25
Status: offline
quote:
ORIGINAL: chris6414
Thanks for your help Chris, I will move the ESC.
The Rx I am using is the one that came with the heli (RTF)
I am upgrade to the Dx7...that should help with the outside int. shouldn't it?
(in reply to chris6414)
       Post #: 5
RE: 10 minute flight... - 9/24/2007 2:35:43 PM
chris6414
Status: offline
Sure should. We have a guy with a DX 6 and he never gets hit
       Post #: 6
RE: 10 minute flight... - 9/24/2007 3:03:06 PM
aland25
Status: offline
Ok,
Another question,
For all using the Dx7
Which Dx7 should I buy?
the one with the Ar7000 Rx or the Ar6100 Rx???
       Post #: 7
RE: 10 minute flight... - 9/24/2007 4:23:24 PM
USHobbySupply
Status: offline
Yup, DX6/7 will cure that one fast!
       Post #: 8
RE: 10 minute flight... - 9/26/2007 11:33:01 PM
fluffhead
Status: offline
quote:
ORIGINAL: aland25
Ok,
Another question,
get the 6100 the 7000 is more expensive, has more channels and more range. Unlikely that youll need the range, or 7th channel with the HBK2
       Post #: 9
RE: 10 minute flight... - 9/27/2007 4:21:47 AM
aland25
Status: offline
quote:
ORIGINAL: fluffhead
quote:
ORIGINAL: aland25
Ok,
Another question,
Thanks for your response.
When I buy the DX7, (micro heli version) will it come with the 6100 receiver with the end pin design?
(in reply to fluffhead)
       Post #: 10
RE: 10 minute flight... - 10/2/2007 2:18:24 PM
aland25
Status: offline
OK, I know it has been a while since I posted, but I wanted to let everyone know, that I found the cause of the issue I was having originally. The plastic gear was wearing down and occasionally if the heli vibrated just right, it would skip a tooth or two.
So I guess make sure you check the condion of the main gear before you fly.
Also, is there an aluminum version out there?
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
Search | Marketplace | Event Calendar | Local Clubs |
