Which Morris Plane?
Tower Hobbies
Logged in as Guest
  Printable Version
50 Size 3D Profile - RTF
Seller:  DAVIS300
Details:   $275.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> Which Morris Plane?
Page: [1]
Login
Which Morris Plane? - 3/22/2003 3:37:30 AM
MTaviat
Status: offline
Which Morris Plane should I get? I have a os50sx for power. I am looking at the the Knife, TopCap, and the Su-do-khoi. Just looking for some input and suggestions. Thanks
       Post #: 1
Which Morris Plane? - 3/22/2003 3:43:23 AM
wgeffon
Status: offline
All good planes but dont forget about the Sledge.
_____________________________
Wayne
(in reply to MTaviat)
       Post #: 2
Which Morris Plane? - 3/22/2003 3:55:24 AM
citation X
Status: offline
I am currently flying a .40 Su-Do-Khoi which if a great airplane, but does not knife edge without a lot of coupling. I think the sledge 540 is a great all around airplane, You should check it out! Ricky
       Post #: 3
Which Morris Plane? - 3/22/2003 6:37:23 AM
BotleRocketWar
Status: offline
Sledge!
Everyone who has gone from a Top Cap or the others to a Sledge says it's better. I have flown all the others and if the Sledge is better, then it's one hell of an airplane! Mine should be here tomorrow...
Brian Richman
BotleRocketWar@Aol.Com
       Post #: 4
Which Morris Plane? - 3/22/2003 2:34:14 PM
lomcevek1
Status: offline
yeah go with the sledge.
       Post #: 5
Which Morris Plane? - 3/23/2003 5:12:44 PM
bob_nj
Status: offline
I'll try to answer your question as you haven't responded to the other suggestions. If you want to learn to hover, do slow upright and inverted flat spins, some decent knife edge, and all around slow and close in flying, the Knife can't be beat if kept as light as possible. The Top Cap hovers too but not as easily as the knife. The TopCap is a bit snappier in tumbling maneuvers and a little crisper in spins etc. I usually add the leading edge vortex/stall strips for better aerobatics. Haven't flown the SuDo but have seen some fly and they are good fliers. Just pick one and start somehwere. Good Luck_bob
       Post #: 6
Re: Which Morris Plane? - 3/23/2003 5:27:27 PM
TERMAGATOR
Status: offline
[QUOTE]Originally posted by mtaviat
Which Morris Plane should I get? [/QUOTE]
Maybe a 60 size sudokhoi, but get somebody else to build it for you......Gator
       Post #: 7
Which Morris Plane? - 3/23/2003 7:52:22 PM
jmulder
Status: offline
Dang skippy get somebody else to build it!!!
       Post #: 8
Which Morris Plane? - 3/23/2003 7:55:04 PM
jmulder
Status: offline
My post count just went from 1058 to 958....Whats up?????
       Post #: 9
Which Morris Plane? - 3/24/2003 6:12:00 AM
krayzc-RCU
Status: offline
i have only flown the morris arf Su-Do-Khoi today as a matter of fact i like this fun fly alot i have an OS-91 on mine so its power heaven. its has alot of fuse for knife edge flight. i would take any of the morris fun fly. topcap the list goes on!
smooth as silk!
       Post #: 10
They're all great! - 3/25/2003 1:04:51 AM
Goinstraightup
Status: offline
I love my Sudokhoi (Kit) with JR radio and OS 46FX power. I have a knife on order. There are some great threads on the Sledge right here in the Fun Fly forum. I don't think you could go wrong any way you go.
       Post #: 11
Which Morris Plane? - 3/25/2003 1:16:30 AM
Texas 3D
Status: offline
Well, I love my Morris GeeWhizBee but I am starting to like the Sudokhoi a lot. I got one from Gator in a trade, and flew it yesterday on a 46FX with tower muffler. Easiest plane I have ever tried to tork roll.
I flew it a couple of times until the elevator stab broke in flight. It did not fly as good with only one elevator half as the pro twister did here in Houston, and went in. Fortunately just the landing gear broke. No problem. Will use another gear I have, and the elevator should be fixed in no time.
The Sudokhoi is now my official beater plane. I don't think it will survive very long LOL But once it goes in, I will put my Sudokhoi ARF together and keep flying a Sudo.
Ulf
       Post #: 12
Which Morris Plane? - 3/25/2003 5:59:56 AM
Constrictor
Status: offline
One reason Gary's twister flew with half a stab gone is that it has dual pushrods going to the elevator due to a mishap where the torque stick broke so the elevator halves were seperated. If you have a typical plane where the pushrod is on one side if the wrong side breaks you are screwed
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
