RE: Matney's ZOOMER
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Matney's ZOOMER Page: <<   < prev  1 2 [3]
Login
RE: Matney's ZOOMER - 10/12/2007 10:33:41 PM
vertical grimmace
Status: offline
The UPS truck was here but I was not I will pick it up on Monday and try to put up some photos and give an initial impresion. What should I call my thread?
(in reply to vertical grimmace)
       Post #: 51
RE: Matney's ZOOMER - 10/13/2007 2:33:43 AM
zeuglodon
Status: offline
Hope that means he shipped a bunch. Mine was ordered about 2 weeks ago. Looking forward to your thread. If mine arrives in time it will be fun to compare notes.
Rick
       Post #: 52
RE: Matney's ZOOMER - 10/13/2007 5:28:13 AM
roadtripessentials
Status: offline
VG,
Call it ,
I finally got my Zoomer Build thread!!!!!
How to go fast if you know how to build!!!!!
You know you want one!!!!!
(in reply to zeuglodon)
       Post #: 53
RE: Matney's ZOOMER - 10/16/2007 6:21:22 AM
vertical grimmace
Status: offline
The Zoomer showed up today. It looks really good. More than I expected actually because the LG were included. I need a little time to round up some material before I start the thread but it will happen soon.
(in reply to roadtripessentials)
       Post #: 54
RE: Matney's ZOOMER - 10/16/2007 6:44:46 AM
z06kal
Status: offline
Grimmace can you post some pictures of the kit?
       Post #: 55
RE: Matney's ZOOMER - 10/16/2007 6:46:07 AM
roadtripessentials
Status: offline
Looking forward to it. It is still on my build list.
Have you made a powerplant choice yet?
Let us know.
Tony
       Post #: 56
RE: Matney's ZOOMER - 10/16/2007 7:13:12 AM
z06kal
Status: offline
Oh yeah and can you measure the diamater of the nose? I want to see if it will fit a 19xx series Neu motor in there. The thing should scoot with 3000 watts on a 7x8 probably break 200 like that.
       Post #: 57
RE: Matney's ZOOMER - 10/16/2007 12:22:30 PM
vertical grimmace
Status: offline
The spinner ring area has an opening of 1.75" and it is designed for a 2" spinner. I will post some pics later today. The Fuselage has a long nose and is a little odd to look at at first. Should be plenty of room for all of the radio and or batteries.
I have deecided to put a TT .46 with ultrathust, Jett pipe on it. There is plenty of room to squeeze many engines in there I think.
What is the best glue to use for installing formers into a fiberglass fuse? This will be a first for me.
The kit came with to small angled aluminum landing gear. Looks like you would glue plates into the wing and mount the LG on them. Exactly what I wanted for the gear anyway. Should be stronger than wires.
(in reply to z06kal)
       Post #: 58
RE: Matney's ZOOMER - 10/16/2007 1:32:56 PM
glowplugboy
Status: offline
You can use polyester resin if the fuse is polyester resin with cloth strips for added strength. You can also use silicon glue, or Goop. If the fuse is epoxy glass, then of course, epoxy can be used as well as the aforementioned adhesives.
Regards,
GPB
       Post #: 59
RE: Matney's ZOOMER - 10/16/2007 4:53:15 PM
z06kal
Status: offline
I would use goop. The awesome thing about goop is it doesn't crack loose when the fusalage is flexed.
(in reply to glowplugboy)
       Post #: 60
RE: Matney's ZOOMER - 10/16/2007 7:07:16 PM
vertical grimmace
Status: offline
I thought one time I heard about Shoe Goo. I have some of that, does it work? Or is it the same as Goop?
       Post #: 61
RE: Matney's ZOOMER - 10/16/2007 8:59:19 PM
glowplugboy
Status: offline
quote:
ORIGINAL: vertical grimmace
"Shoe Goo", "Goop", "PFM", "Marine, Plumbers, Carpenter's Goop", it's all from the same bucket. Just be careful with using too much. It gets heavy.
       Post #: 62
RE: Matney's ZOOMER - 10/16/2007 9:00:35 PM
glowplugboy
Status: offline
BTW, no one ever answered my question early in this thread regarding whether the wing needed to be glassed or not. Carbon strip is mentioned, but nothing is said about glassing the whole wing....
Thanks GPB
       Post #: 63
RE: Matney's ZOOMER - 10/16/2007 10:03:28 PM
z06kal
Status: offline
Hey Vert. The Neu 19 series motor is 2" in DIA. Do you think it will fit in the nose if you set it back a few mm's?
       Post #: 64
RE: Matney's ZOOMER - 10/16/2007 11:03:01 PM
vertical grimmace
Status: offline
It says in the direction sheet to fiberglass the center section with 3 layers of cloth top and bottom. Start with 4", 8" 12". I suppose you could glass the whole wing but it is not mentioned in the instructions. There are some other carbon pieces to be used in the wing. I will discuss that in the build thread.
To fit a 2" diameter motor I think it will have to be moved back about 1" from the current spinner location.
I will start the build thread now.
       Post #: 65
Jump to:
